jwakil's Avatar
If points gap is correct, should dwell also be?
I'm trying to adjust my distributor with points. If I get the gap correct, does that imply that the dwell angle should be fine? I'm trying to decide if I need a separate dwell meter.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 02-18-2011, 07:17 AM
HarryD's Avatar
If you get the gap correct, the dwell "should" be within range. The dwell meter will serve to fine tune the setting.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-18-2011, 07:24 AM
Senior Member
Superman's Avatar
Harry is correct. However, no matter how close you think the gap is, the dwell angle will almost certainly be incorrect. A dwell meter will tell you how close you got it when you set the point gap. Also.....dwell meters can be had for peanuts. Thrift stores, pawn shops, garage sales, etc. Better yet, do yourself a big favor and upgrade to an electronic ignition trigger.
Mocha 1978 911SC. "Coco"
Old 02-18-2011, 08:02 AM
Bill Verburg's Avatar
point gap determines dwell, the wider the gap the lower the dwell.
The more precise measure is dwell.
Set the gap w/ feelers then zero it in w/ dwell.
since the primary issue w/ points as implemented in a Porsche CDI system is rubbing block wear and the resulting decrease in point gap over time, it's best to set up the gap on the high side, which is on the low side for a dwell measurement
Bill Verburg
Old 02-18-2011, 08:04 AM
To add to Bill's response: Every 1 degree of dwell change also changes the ignition timing by the same amount. Thus, as the rubbing block wears, the point gap becomes smaller and the ignition retards (e.g. 5ºBTDC > 4ºBTDC).
Sherwood
Old 02-18-2011, 01:30 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
yes, and dwell affects timing, but timing does not affect dwell...
Old 02-18-2011, 08:01 PM
Question
Don't mean to high jack. However, what is this electronic ignition trigger you speak of ?
Old 02-19-2011, 11:28 PM
HarryD's Avatar
Good question. I presume we mean someting like Pertronix (Pelican Parts.com - Pertronix Ignitor) or other electrical item to replace the points with an electronic triggering device.
Harry
2020 MB E350 4Matic
Old 02-20-2011, 11:50 AM
Thanks HarryD. I remember something like this in the 70's for muscle cars.
Old 02-20-2011, 06:29 PM
RETIRED
Joe Bob's Avatar
Pertronix while a good idea, are failure prone, hence the recommendation to carry points with you on the road.....
2012 ML350 3.0 Turbo Diesel
Old 02-20-2011, 11:15 PM
