Clunk noise
I've been looking at posts that identify a clunk noise while driving. I have a stock '82 SC. While I'm driving I can hear the clunk noise seemingly coming from the front wheels or shocks. I've taken the front bearings out and greased them, then tightened them according to spec. They looked perfect. I also just had the car on jack stands and pulled/jerked up and down, back and forth on the wheel, but I couldn't get any movement or noise. Is there something inside the shock that could be loose? How do I check it? Any pics would be great!
abit off center
What front struts do you have?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Inserts coming out of the struts?
good for a clunk. Bruce |
roll bar bushings or mountings?
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Member 911 Anonymous
If front, raise the car remove the suspect side and grab the strut, pull back and forth, if loose the strut nut if applicable needs to be tightened or the top strut nut. I would check both sides for movement.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
+1 on roll bar bushings or mountings...
Kurt |
WUNDERWAFFE
I had the similar issue, It was the spindle on the strut. Had to replace strut.
Hope this helps,
Charlie 1986 Carrera |
Maybe the rubber for the torsion bar mounts have had their days. Being an 82....
74' 911 w/3.2L (sold) 95' 993 C2 Triple Blk Cab. 02 Honda Superhawk (sold) 2018 Toyota Tundra Limited 2004 CRF250X |
It seems that it could be the:
- Torsion bar - Sway bar - Strut I need to do more investigation. |
I, too, am hearing a NEW similar sound from my right side,..but only when I apply brakes...will be looking this weekend....
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
