LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
RETIRED
Joe Bob's Avatar
What have YOU fixed on your ride? No check book mechanics.....
I started listing my mods in another thread.....then I started on what I have fixed.....
FIXES
Blew 2nd after my 3.6 install. WEVO mods followed. Rebuilt 915 with help
3.6 r&r sealed everything
standard maintenance, oil, valves, brakes
trouble shot dead DME....ended up being bad switched power input
installed Recaros, made custom sliders
installed roll bar
fabbed tow hitch from scratch
installed dual oil coolers, fabbed lines and installed finned lines from Chuck Moreland
replaced incandescent bulbs with LEDs
steering bushing
interior door switches and fixtures
fixed washer pumper, lost headlight washer
AC delete
Head light flasher/stalk
New CVs and axles
New spring plates and bushings
Welded/repair rear sway bar mounts
Shifter bushings
Removed center console
MODS
TRE glass front bumper, fenders, hood, 73 RS back date
duck tail
7 and 8 Fuchs
Carrera sway bars, 22/29 t-bars
Sport engine and tranny mounts
dual oil coolers
3.6 with injection, early Timmins kit......LOTS OF CHANGES
Wevo shifter and trans upgrades
RS carpets, Leather Recaros, dropped driver ride height 3 inches
Konis
R tail lights, LED back ups
H4s, Cibie H1s
Light relays
993 gauges
Roll bar
Wiper relocation/single wiper
AC delete, heat backdate
Euro ride height
Corner balance
993 HEs, 3 inch single outlet
No Bad Days performance chip
Probably more.......
Oh yeah,
Ash canned crappy VDO clock, replaced with head Temp and Volt Meter
Upgraded tunes with IPOD input
dual marine blowers for heat ($20 bucks each, eh)
ash canned crappy paper heater tubing with aircraft SCAT
Optima Yellow Top, Marine fittings with kwik disconnects
Permanent Battery Tender pigtail
Elephant Racing finned oil lines with air assisted blow down
de chromed, de badged
930 steering wheel
2012 ML350 3.0 Turbo Diesel
Old 03-20-2011, 05:50 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
see my sig
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 03-20-2011, 05:51 PM
Wash. State
nesslar's Avatar
All the easy stuff (sorta):
Repaired odo (today; He** yes I'm proud), replaced body parts (rocker, bumper pad, installed H4s, swapped to Euro rear lenses), added a hood strut, oil, valves, idle, swapped out to sport seats (OMG what a diff.!!!) and OEM 930S steering wheel (fantastic), swapped out chin spoiler and turn sig./hi-low switch, went to newer, nicer lug nuts (+ a second lock on each wheel), adjusted Targa top several times, fixed rear seat straps, adjusted ride height, added front coco mats, slapped a 40 year old hood emblem on (love that), mirror bras (OEM with Porsche "shield"), ripped out most AC krapp, and checked the air in the tires . Oh, and made friends along the way, like my buddy JB.... Bought some shirts, too............I know, easy sh*(, but all good. I'm no wrench.
Out with the old: (Yes the new is working perfectly. Funny how that "Peanuts" comic is right there; not a staged shot, I swear!)...
Old 03-20-2011, 06:22 PM
pete3799's Avatar
Shifter bushings and made a spring loaded gate.
pulled ign. switch and fixed it.
fixed door switches (lights)
dropped motor and trans. fix oil leaks and new (to me) oil cooler.
Rear susp. bushings.
Rebuilt all calipers.
made a new window (spring) pivot pin
Repack and replace CV boots (all)
replaced odometer gear
tune-up
fixed head light switch (on the column)
I'll quit here but there's lots more little stuff
Pete
79 911SC RoW
Old 03-20-2011, 06:44 PM
1980 911 SC
A few of my projects over the years
1. Replaced engine blower fan and squirrel cage for heat
2. Removed and replaced 915 Transmission with fresh rebuild
3. Engine compartment noise deflector installed
4. Heat exchangers, both heater hoses to body
5. Replaced valve cover gaskets, all new hardware
6. Repair backup light switch
7. Replaced both half shafts
8. Replaced clutch cable
9. Clutch helper spring
10. Sway bar bushings
11. Removed engine, cleaned and de-greased engine mounted oil cooler
12. Engine compartment hood struts
13. Installed third eye brake light
14. Oil and filter, strainer kit
15. Ignition wires, rotor , distributor cap, spark plugs
16. Front hood struts
17. Installed Carrera chain tensioners
18. Replaced brake calipers, rotors, all brake lines.
19. Installed H5’s
20. Installed Dansk sport muffler
21. Oil breather gasket
22. Oil pressure gasket
23. Oil pressure sender unit
24. Momo steering wheel
25. Aluminum floor boards
26. Removed and repainted fuel tank
27. Replaced both front fenders ( paint done by a Pro)
28. Replaced front bumper smile
29. Installed front spoiler, installed Duck tail
30. Cut out and welded in new front bumper shock supports
31. Removed entire A/C unit
32. Installed Carrera oil cooler
Thats all I can remember right now. I still have a room full of new parts to be installed.
Life's a Beach
Old 03-20-2011, 06:48 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
brake rotors and pads, rear shocks, oil and filter countless times, modified airbox cover! sounds faster! installed strut tower brace, installed new front smile on front valence. pulled injectors to be rebuilt and flow tested, replaced. installed new fan belt. put in steve wong chip, clipped the brown wire (actually noticed a difference on that. cool) replaced cracked fuel line on top of engine! that was a ***** with the engine in the car! switched out stock seats for sport seats. replaced burnt out front wheel bearing and cracked hub.
I left plenty of other stuff to the mechanics because I know my limitations
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 03-20-2011, 07:00 PM
Member 911 Anonymous
DRACO A5OG's Avatar
OMG, only 32?
I stopped counting,
Recently I fixed my scratchy steering wheel. I replaced the "wiper switch" with Zimm's repro and found it still made the annoying scratching noise.
I noticed the scratching only occurred at the top 1/4 section of the steering wheel, consistently.
I removed the steering wheel. Observed the switch and it seemed fine but then I ran my finger along the steering wheel's copper contact. I took some emery cloth and smoothed out the 1/4 copper contact section and even the edges. Well that did the trick.
My deduction: since the steering wheel sits most of time on the 1/4 section of the copper contact,, road vibration would cause the switch to rub up and down on the copper contact inadvertently cause scoring and scuffs on the contact which results in the "scratching noise".
Sorry for the hi-jack, just wanted to share.
Jim
'85 Carrera Targa
PCA/POC
Senior Advisor
James Brown's Avatar
This is what I haven't done, replaced glass, removed doors, removed fuel tank, rebuilt front suspension, rebuilt rear suspension, removed dash, replaced brake booster.
It's a smaller list!!
08 Cayenne Turbo
Old 03-20-2011, 07:04 PM
Haven't had much to do yet.
Replaced stock seats with corbeau targas and made my sliders.
Replaced motor mounts
And since I just ordered my rs door panels ill be putting those in when they get here
Old 03-20-2011, 07:08 PM
Wash. State
nesslar's Avatar
Quote: "It's a smaller list!!" LOL....
Old 03-20-2011, 07:11 PM
RETIRED
Joe Bob's Avatar
High light any mod or repair that is out of the ordinary.....
Old 03-20-2011, 07:14 PM
Senior Advisor
I really like those guys that can straighten out and cut and paste body parts, that's art. Any one done that?
08 Cayenne Turbo
Old 03-20-2011, 07:18 PM
DRACO A5OG's Avatar
Ok, I'll bite:
Bilstein HD Insert/Boge Strut slop housing fix with 8 gauge copper wire
Oil Level Sender Unit Repair without replacement
Starter Refresh Service without replacement
Heat Exchanger Inlet and SS tube re-rounded on my driveway safety post and a sledge. ( it was squeeshed somehow )
'85 Carrera Targa
PCA/POC
Old 03-20-2011, 07:19 PM
RETIRED
Joe Bob's Avatar
Yeah, list your rust repairs.....
pete3799's Avatar
They rust?
Pete
79 911SC RoW
Old 03-20-2011, 07:23 PM
Senior Advisor
they bend!
08 Cayenne Turbo
Old 03-20-2011, 07:25 PM
DRACO A5OG's Avatar
they leak?
'85 Carrera Targa
PCA/POC
Old 03-20-2011, 07:26 PM
just me
paulgtr's Avatar
they get into accidents before you buy them?
muck-raker
kidrock's Avatar
Originally Posted by DRACO A5OG View Post
Ok, I'll bite:
Oh please Jim. What about all the stuff you've done with your AFM? You could probably tear one down and put it back together in 15 seconds with a blindfold.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 03-20-2011, 07:31 PM
Green 912's Avatar
Only one line item. From^......To v
Old 03-20-2011, 07:33 PM
