-   -   New 2.8 RSR Evocation (http://forums.pelicanparts.com/porsche-911-technical-forum/600186-new-2-8-rsr-evocation.html)
tof2.7 10-31-2011 03:17 AM
Since 12 I had a hard time with the Oil cover which continued to run away on a weld and the only means found to stop the problem after two dismantling with every time drain away of the cover, was the cold epoxy weld.
The cover finally went back up and i have started the "beast"
Warm a good quarter of an hour in Fog!!!!! (Between the paint of the silencer which began to cook and wd40, penetrating oil X and a bottom of oil Y which sank on heat exchangers during work in .......) it was style " Indian smoke signal " in front of house. :D
Of the blow I doubled effort and I put myself in mode "Putty"!!!!
Front bumper before
I had made a wire netting for the hole of the front but I was not satisfied with the depiction and with the finish
http://img15.imageshack.us/img15/1490/chocav8.jpg
Thus dismanteling
And complete sanding to obtain plan flat on the back.
http://img253.imageshack.us/img253/1270/mastic1.jpg
http://img195.imageshack.us/img195/6205/mastic2.jpg
after I drew places or I am going to add blocks to fix the new railing.
Then organized blocks in putty (sauerkraut in french) and sanding to level quite
http://img195.imageshack.us/img195/2480/mastic4.jpg
Implementation of the railing and the fixation (like that knockdown for the paint.
http://img401.imageshack.us/img401/8271/mastic5.jpg
And now one bumper at once more nice.
http://img708.imageshack.us/img708/8531/mastic6.jpg
The finish is better as well.
http://img525.imageshack.us/img525/5145/mastic7.jpg
http://img440.imageshack.us/img440/6887/mastic8.jpg
And for this attractive painted railing you said where i have found it ......
And indeed to the waste reception center :lol:
In fact they are tablets of one IT table
http://img18.imageshack.us/img18/1054/tablefi.jpg
We are DIY or not!
tof2.7 10-31-2011 03:18 AM
I took advantage to block the some hole which there was in Ducktail
before
http://img713.imageshack.us/img713/285/poncage1.jpg
And hanging
http://img850.imageshack.us/img850/3541/mastic3.jpg
I did not finish because I had hidden the phone at the time of the sanding but it is top.
Tomorrow holiday and with the weekend of November 11th I should have gone back up everything for road test and then we re-dismanteling for the epoxy paint the inside of polys.
tof2.7 11-03-2011 01:27 AM
Well finalization of the reassembly
For takes the lead or to catch up the delay, I decided to spend some evenings in the garage!
We attack of the blow details
Of all the polys, adorns it rear bumper seemed to me more light than the rest.
I thus spread it with two coat additional of fiber.
I took advantage of it to flood in the putty of the nuts for the fixations of adorn inaccessible bumper, example the top of adorns bumper which passes under the back crossbar will be fixed to this last one by three saw. At the beginning I thought screwed him but I think that it would not have liked in time I thus have preferred to leave on the bolting.
Attention picture before sanding.
http://img716.imageshack.us/img716/3541/mastic3.jpg
http://img266.imageshack.us/img266/2480/mastic4.jpg
I stopped aligning wings and hood (with the deleted holes of badge)
http://img42.imageshack.us/img42/6205/mastic2.jpg
I attack the alignment indicator block + railing + corner of the hood and there the material thus is missing I reloaded in the putty, by sanding I am going to reach coast wished.
http://img443.imageshack.us/img443/1270/mastic1.jpg
vintagecarlover 11-03-2011 07:53 AM
wow, great skills. i watch and learn,...
tof2.7 11-03-2011 09:05 AM
but i have no particular skills, just a dream to live and not so much money i would like to have, so the alone way to have my replica is to have idea and make the max by myself. Sure that a professional will make a better work but in final when i will drive it , it was myself big boy toy ;):)
stv951 11-06-2011 09:59 PM
Originally Posted by tof2.7 (Post 6348151)
I couldnt agree more. A work to be proud of when you drive it ;)
Are you happy with f-s-h body parts quality ?
I am also in Europe and i am considering using them to buy some body panels.
Where else do you buy parts from ?
This thread is a great inspiration to me
tof2.7 11-08-2011 12:57 AM
Hi STV
i have made a private message for answer you :)
thanks for your support. ;)
tof2.7 11-09-2011 04:22 AM
Hold a small comment of " madman " on the detail which I am going to add to the beast! In a more or less close future
Leg of preservation of the headlight
http://img408.imageshack.us/img408/1132/attachphar1.jpg
http://img580.imageshack.us/img580/3645/attachphar2.jpg
Spare wheel with wheel rim (even finishes as 4 others) in 4,5/5,5 to see with the least wide possible tire and the beautiful belt leather three parts
http://img508.imageshack.us/img508/9411/attachroue2.jpg
http://img585.imageshack.us/img585/9575/attachroue3.jpg
http://img62.imageshack.us/img62/1797/attachroue4.jpg
http://img685.imageshack.us/img685/203/attachroue7.jpg
A bar anti link like that
http://img9.imageshack.us/img9/9702/barantirapp1.jpg
http://img27.imageshack.us/img27/336/barantirapp2.jpg
change the place of the battery
http://img263.imageshack.us/img263/4753/batterie2r.jpg
My pull for the inside with the "fire" on the handle.
http://img502.imageshack.us/img502/5664/cablfire.jpg
No sky-roof but first-class paint and plate of this type
http://img191.imageshack.us/img191/2213/cieldetoit.jpg
All the openned keep the color "grey atlas" (almost black) and paintbody much more clearly (a fino that has still changed but secret)
http://img211.imageshack.us/img211/7200/couleurm.jpg
Cut outside circuit and change the place of the inside on dashboard
http://img802.imageshack.us/img802/5...pecircuit1.jpg
http://img254.imageshack.us/img254/6932/tdb6.jpg
Make my carpets plastic for the front
http://img6.imageshack.us/img6/7724/pelrsmat1.jpg
Make and put support back windscreen
http://img197.imageshack.us/img197/1319/image2pew.jpg
Baguette of hood before type 964rs
http://img835.imageshack.us/img835/562/soutiencapo.jpg
tof2.7 11-09-2011 04:24 AM
To find lights of styles for the numbers (I still think about it!)
http://img171.imageshack.us/img171/1931/eclairagey.jpg
http://img713.imageshack.us/img713/7...anger1800x.jpg
Modify of the support of stopwatch with cap
http://img525.imageshack.us/img525/8199/chrono2.jpg
To move the higher filling of gasoline on the hood but not not block the current hole in the fiber, but with a shutter of the style (we see bad!)
http://img204.imageshack.us/img204/7990/obturateur.jpg
........... And if that scratches me somewhere else I speak to you about it :D
Horrido 11-10-2011 11:58 AM
Your project is an inspiration for my modest efforts.
Thanks for sharing so much of it.
:D
tof2.7 11-14-2011 04:50 AM
Thanks Horrido
For the legs of headlight
Thus we leave the size
http://img88.imageshack.us/img88/4286/fixphar1.jpg
We cut and one grindstone in the shape
http://img713.imageshack.us/img713/3116/fixphar2.jpg
we attack the polishing
http://img526.imageshack.us/img526/9205/fixphar3.jpg
and one obtain a nice result
http://img189.imageshack.us/img189/5074/fixphar4.jpg
http://img33.imageshack.us/img33/516/fixphar5.jpg
then mounted
http://img221.imageshack.us/img221/1089/fixphar6.jpg
And as we had on beautiful Sunday morning in the North of France, direction "the esplanade of Lille", for one test of rolling with polys.
http://img24.imageshack.us/img24/8204/img7872w.jpg
http://img840.imageshack.us/img840/1...830800x600.jpg
http://img411.imageshack.us/img411/5...843800x600.jpg
http://img843.imageshack.us/img843/8...874800x600.jpg
Well some more of adjustment on indicators (the plate turns in painted time, because it will receive a plate in sticker on the hood ) the behavior is very good and the noise is top.
tof2.7 11-15-2011 05:12 AM
Yesterday evening i was irritated by some persons of my job .... :mad: .... then two choices to take a "xanax" or to spend one hour to do odd jobs on "the beast"
solution 2 was choosen.
Yesterday in full light I noticed that at the level fronts bars we saw good behind and that I had never noticed it on classics.
René on visit at the house gave me the reason, classics has tubs to battery which darken the back.
I thus worked on bars
A piece of bar, an electric pair of shears and it is left.
http://img221.imageshack.us/img221/1428/grille1g.jpg
http://img27.imageshack.us/img27/5219/grille2i.jpg
And two beautiful bars
http://img140.imageshack.us/img140/6854/grille3f.jpg
For the color I would see in the reassembly, black, dark gray, light gray!!!
I got down in realized also one of both day idea
Then at first a piece of plexi
http://img40.imageshack.us/img40/8626/fusible1.jpg
We cut and we make notches placed well (important)
http://img708.imageshack.us/img708/9365/fusible2z.jpg
And then .................. I let you guess :D
tof2.7 11-18-2011 12:04 AM
the answer : the plexis (Lexan to be exact)
Parts to be modified:
http://img833.imageshack.us/img833/8...1117103410.jpg
Cut of the more
http://img69.imageshack.us/img69/6062/fusible5.jpg
Sanding, adjustment and cut of the last piece of Lexan
http://img100.imageshack.us/img100/8938/fusible6.jpg
Assembly(fuse box)
http://img10.imageshack.us/img10/3851/fusible9.jpg
As behind there is electric cable and fuses, I put of the thermo self-adhesive girdle on all saw them.
http://img6.imageshack.us/img6/8029/fusible7.jpg
http://img718.imageshack.us/img718/1510/fusible8.jpg
Assembly(cover to box of webasto)
http://img141.imageshack.us/img141/3627/fusible10.jpg
There is not more than has to rise
http://img6.imageshack.us/img6/6677/fusible11.jpg
But before I have to file one of the edges of the lid of chest to adjust it at the top and to polish the edges of the plexi. the frame will be painted at the same time as inside of polys with the epoxy paint.
With this plexi we shall see well the beautiful battery gel and its support but it will be protected well.
tof2.7 11-21-2011 06:07 AM
Well this week not motivated (sad persons at job have mad my week end is not good)
Thus two three little gifts.
Put back in place ready parts with Lexan to see if it be going to make good
The fuse mask box.
http://img267.imageshack.us/img267/7...1119144720.jpg
The webasto place cover
http://img265.imageshack.us/img265/1...1119144711.jpg
Railings
http://img714.imageshack.us/img714/5...1119162744.jpg
http://img100.imageshack.us/img100/4...1119162812.jpg
And I attacked the crutch of the before hood .
The stalk and the axis
http://img256.imageshack.us/img256/9...1120184828.jpg
http://img51.imageshack.us/img51/974...1120184841.jpg
http://img810.imageshack.us/img810/3...1120184904.jpg
911Freak 11-21-2011 04:23 PM
An original take on many levels, I like it!
Keep up the good work!
Cheers from sunny California (the other wine country)
Jason
tof2.7 11-22-2011 01:34 AM
Well I finished hood support an just have to found the system to block it
like that :
http://www.castorama.fr/images/products/h/h_976800.jpg
And a nice tip.
http://img233.imageshack.us/img233/9...1121171300.jpg
http://img51.imageshack.us/img51/824...1121193034.jpg
http://img208.imageshack.us/img208/7...1121193046.jpg
I have just to fix it now
tof2.7 11-23-2011 01:50 AM
When I bought the second-hand ducktail there were holes on the edge for the plate light but not these last ones. The being froggy one "G type" on the base it was necessary myself to put in search of an adequate part knowing that the old owner of the ducktail had made "wide" openings on the slice 25 mm in width and 80 mm in length.
Thus listening to only my courage I threw myself into the mud of a car scrap yard with my small meter-ribbon. After 10 minutes of an empty research, it appeared to me, a magnificent Citroën Xantia (french car) green English which had made a barrel. Measure taken I obtained 25*80 and swamp with luck the hood was opened on all the length giving access to the scouts.
Costs : 5 $
A colleague
http://faimg1.forum-auto.com/mesimag...antia%202b.jpg
:) (will need that I think of making them a sign when I would double them:D)
After cleaning
http://img811.imageshack.us/img811/2...1122214323.jpg
http://img35.imageshack.us/img35/304...1122214422.jpg
And presented, it will just be necessary me to block the hole which had made the old owner.
http://img41.imageshack.us/img41/514...1122205928.jpg
And I finished my block bar for the front hood.
I reduced the length of tube who receive saw it of preservation of the kneecap on the leg of fixation
http://img821.imageshack.us/img821/4...1122212913.jpg
With my clip
http://img27.imageshack.us/img27/802...1122212752.jpg
http://img64.imageshack.us/img64/926...1122212720.jpg
There is really a lots of details to be settled before making the final painting)......
tof2.7 11-24-2011 12:37 AM
so the block bar for the front hood is fixed and works good.
http://img444.imageshack.us/img444/7...1123190912.jpg
http://img163.imageshack.us/img163/8...1123190930.jpg
http://img163.imageshack.us/img163/1...1123190940.jpg
http://img406.imageshack.us/img406/4...1123191030.jpg
http://img64.imageshack.us/img64/652...1123191015.jpg
it will be more cool to work on the support for the tank cap...
tof2.7 12-08-2011 12:37 AM
after two week with no job on the RSR, because some trouble at work, the crisis have catch our factory and i don't know if i will guard my job or if i will lose it. I will know the decision for the end of this month.
for winting last night (all the night are very long now , by thinking...) i have working on the car and it was a good therapy for the head.
i have workin on the hole of the light on the ductail , reduce it , and begin the lectric wireless.
http://img64.imageshack.us/img64/2113/cablage2.jpg
http://img812.imageshack.us/img812/3626/cablage1.jpg
http://img28.imageshack.us/img28/7271/cablage3.jpg
all is protected by black thermo and i will found new quick connect , and so if we have to dismantled the ductkail we have just to disconnect.
