What bracket is this?
I'm removing my old Rear Sway bar brackets to make room for a pair of the Wevo items.... bit tricky getting the old ones off.
Can anyone tell me what this bracket is for? I'm thinking of removing this also as it will make it a lot easier to get to the Sway bar bracket.
Its located left rear and attachs to body and torsion tube.... could it be a fuel pump bracket?
1973 911 Coupe.
Brent
Christchurch, New Zealand.
Project: 1973 RSR Clone build http://forums.pelicanparts.com/porsche-911-technical-forum/576125-nz-73-rsr-clone-build.html
Old 04-29-2011, 09:17 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Sway Bar? Oops nevermind. never seen that before, an after market mod???
'85 Carrera Targa
PCA/POC
Old 04-29-2011, 09:24 PM
AutoBahned
RWebb's Avatar
fuel pump
Old 04-29-2011, 09:29 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
fuel pump
yup..
Old 04-29-2011, 09:40 PM
Looks like the support for the fuel pump.
Old 04-29-2011, 10:24 PM
Thought I would be mounting the fuel pump at the tank.... I don't see a problem in removing, what do you think?
Would it be removed on a 73 RSR?
Brent
Brent
Old 04-29-2011, 10:34 PM
Almost Banned Once
sc_rufctr's Avatar
Brent
Not sure about the 73 RSR... It's your car. Mount the pump were ever you like.
BUT What I would do is remove it gently. Don't just hack it off. Drill out the spot welds (if it has any) and use a chisel to break it free.
Then spray some oil on it and store it somewhere dry in your garage.
- Peter
Old 04-29-2011, 11:31 PM
Just a safety tip reminder. Jack stands "can" fail, so most of us (I hope) place the wheels/tires (or something) underneath the tub when she's up in the air like that.
Old 04-30-2011, 03:13 AM
AutoBahned
RWebb's Avatar
fuel pump up near the tank on the F. X-member will be better for reducing heat soak problems
Old 04-30-2011, 10:28 AM
Brent
Brent,
The RSR didn't have that bracket since the fuel pumps were up front.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-30-2011, 11:07 AM
Registered speed offender
78SCRSMAN's Avatar
I wear a crash helmet just to be on the safe side.
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Old 04-30-2011, 01:02 PM
Steve,
Thanks, that's the answer I needed!!
Others;
Good point re the Axle stands.... On a side note, we had a large Earthquake here on the 22nd of Feb, when I went to the shed to check on the car and stuff, I opened the door to find the cra on the floor, earthquake had rocked it right off the Axle stands !!!!
Originally Posted by Steve@Rennsport View Post
Brent,
Brent
Old 04-30-2011, 02:30 PM
