LinkBack | Thread Tools | Rate Thread |
muck-raker
Joe Bob, I somehow got lucky. There was enough oily mess to where the sensors slid out with the slightest manipulation, just a slight back-and-forth jiggle combined with a gentle pull on the bases. I think I may have loosened an allen head to get them out, I don't remember if I completely removed it though.
I didn't even need to remove the retainer bracket, nor did I need to adjust the bracket or sensors upon reinstallation. The suckers just slid out, then gently slid back in again. Just make sure you slide 'em in all the way, just the way she likes it. ![]() I bet you can give these things a small douching of PB Blaster to get 'em to break free.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Just take the bracket completely off, a clean it. Use a remote starter to bump the flywheel around, and check and clean the reference bolt. A very thin dab of clean grease may help installation of the old sensor, with a washer glued on there to set the spacing. Remove old sensors. Install the new grommet, then the connectors, then the new sensors.
RETIRED
So.....the 3.6 sensors.....same as the 3.2s?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
Reason I ask, while the 3.2 and 3.6 share a similar EFI, the part number for the 3.6 sensor is different. 996-606-105-00-M14
83 911 Production Cab #10
That is the thread I PM you about, coincidental that ir resurface on the same day... Thanks for the info (event the "code" one ![]() ![]() )Is there a specific torque to secure them to the holder? Cheers J.J. P.S. Who knows, you might even enjoy the show in Albuquerque
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Member 911 Anonymous
Just make certain they are the same OD as the original that you pulled and it will press in with a bit of lube.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
muck-raker
JJ,
I'm super lazy and don't want to walk out to the garage to open up the Bentley to give you the torque specs. ![]() I didn't even refer to the torque value when I installed them. In fact, I don't remember if I even needed to loosen or tighten any of those Allen bolts under there, but I may have. Just snug them up without giving yourself a hernia, what I like to call "Harley tight". Maybe about 16-22 ft. lbs.
(man/dude)
Do the sensors commonly fail?
I have my engine and trans out, this would be a good "while I'm in there" thing to do. And $100.00 is like spitting in the ocean at this point. |
bump to subscribe
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
![]() ![]() ![]() You should be able to get the pair for $110 delivered at the border (US side).
muck-raker
Also, when replacing, make sure that each sensor is plugged into the correct socket in the engine bay near the left-hand intake manifold. It would suck to have a no-start issue just because of incorrect installation.
Diss Member
For $100 you can get a good used oscilloscope and just test the sensors without guessing blindly, plus you can use it for other stuff. You just need to see a 2.5 volt peak coming out of it.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
I've got an 1984 Targa that appears to have a bad sensor also. I can barely see the sensor never mind get a wrench on them. Is there a trick to getting at these suckers???
From top or underneath?? |
Disconnect rear strut, raise the driver side, place jack stands and chocks, remove rear wheel. you will see the two wires going into a bracket attached to the trans held by allen bolts. I would PB blast them or a good penetrating oil then remove. Just mark the wires there and at the mounting bracket/connectors in the engine bay. Of course remove the heater blowerr plastic hose to gain access to the connector mount/assembly. BE CERTAIN YOU DO NOT TWIST THE NEW ONES IN, Before complete removal check the Diameter of the old ones compared to the new ones. Jim
Welcome to the club. Beside needing pics of your car (does not matter whether it work or not), we need to know (as a nosy group that might send you down the Garden Path) why you you thinks that it "appear to have a bad sensor also"?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 06-08-2011 at 04:21 PM.. |
Post # 1... Unless he is holding back, you might have lost him somewhere ![]() ![]()
Maybe
Oh well we tried.
Another BMW part user here - only wish I knew about the CHT (from Gregwils above) before I bought mine last year.
Wires appear white on my originals mine because the insulation crumbled off. Even after marking I succeeded in swapping the connectors - what a maroon.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Thanks guys for all the replies. I just got back to a working computer.
The reason I thought it was the sensor is because I wasn't getting any power to the fuel pump. I jumped the fuel pump and still no start and then I checked the plugs and no spark either. All my internet searches indicate it was the crank sensor. The car has been sitting in the garage for over three months but I will try to tackle it next week and hope I am right. Bob |
