G50 G50 is offline
'84 - '88 Carrera cheap(er) DME speed and reference sensors available
I know this has been discussed here before, but just to put it all in one place in case it helps anyone -
The Porsche DME speed and reference sensors (the ones that read off the flywheel) are currently around $150 each.
These are just Bosch parts, similar to what is used on other cars.
I replaced mine today with sensors for an '87 BMW 535i, the Bosch part number is 0 261 210 002, called a "Reference Sensor." (BMW used this for a lot of years and on a lot of different models, 3, 5, 6 and 7, but I give '87 535i b/c I know that works)
This is the exact same part as the Porsche part, except it is maybe 1/2 inch longer, which is no issue. Bolts up exactly the same, for around $70 each.
Old 05-13-2011, 05:53 PM
howard freeman's Avatar
0261 210 001 is the bosch #. Same as 84-87 325e &528e M20 eta engines.
Howard
Howard Freeman
80 911 SC & 74 914 1.8
79 930 & 83 SC coupe,03 996 TT,02 996 C4
03 X/5 3.0. 370,186 miles now Sons daily driver
10 X5 3.0I 224,515 miles
Old 05-13-2011, 06:01 PM
fxeditor's Avatar
Thanks for posting this!
Michael
-- '87 Diamond Blue Coupe
-- '92 Miata
-- '06 Scion XB (the wife's)
-- '01 Audi S4 (Sold)
-- '17 Tesla Model S60
Old 05-13-2011, 06:19 PM
G50 G50 is offline
Here's the box the ones I installed today came in.
Old 05-13-2011, 06:49 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Here is another alternate part: 1996 Ford Taurus O2S 3 wire 1/2 price just splice the wires :-)
'85 Carrera Targa
PCA/POC
Old 05-13-2011, 07:23 PM
muck-raker
kidrock's Avatar
I picked up the exact same sensors about 4 months ago for $55 each, with free shipping.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-13-2011, 07:53 PM
I need to check the PN but the ones I got turned out to be exactly the same as the originals, but without the DG and BG tags.
Old 05-13-2011, 08:57 PM
Mo money = mo parts
I did the same thing two years ago - BMW part numbers. You can buy a new head temp sensor with the difference.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 05-14-2011, 04:08 AM
304065's Avatar
This is a great shot. . . "I saved so much on sensors I bought a Leica!"
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-14-2011, 04:10 AM
The parts are interchangable so the factory stocking the box wouldnt know which would be your use, DG or Bg.
I m glad that BMW can make the sensors at half the price of Porsche.
Bruce
Old 05-14-2011, 04:38 AM
dshepp806's Avatar
For the guys who've seen these replacements, has anyone scoped the output signals, comparatively? Also,..I understand the cable lengths are adifferent, but is the cable the same? (Manufacturer, diameter, internals (specs),etc.)?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-15-2011, 04:43 AM
abit off center
cgarr's Avatar
I just used the one G50 did above at about half the cost in my 86 and it was a direct plug in and only about an inch longer, that was it!
______________________
Craig
G2Performance
Old 05-15-2011, 05:46 AM
muck-raker
kidrock's Avatar
Doyle,
I researched a couple of older threads that go back to around 2004 or 2005 that answer all the questions you ask....the short answer to all is "yes", they're pretty much exactly the same. A bunch of guys have been using the BMW replacement (Bosch) successfully for quite a while now.
STONE
Old 05-15-2011, 07:33 PM
muck-raker
kidrock's Avatar
STONE
Old 05-15-2011, 07:37 PM
Grappler
Rodsrsr's Avatar
I've had my BMW type sensors in for a few years now with no problems at all.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 05-15-2011, 08:03 PM
DRACO A5OG's Avatar
Just take care how you install these or any sensors. As per Tony Callas, Callas Rennsport, these sensors are liken to light bulbs and if you twist them in you will break it and have to start all over again with new ones. Ask me how I know
'85 Carrera Targa
PCA/POC
Old 05-15-2011, 08:07 PM
dshepp806's Avatar
Originally Posted by kidrock View Post
I recall that discussion,...pretty much interests in what the signal level outputs were (scope) and was there was any difference in cable fabrication/materials.
STILL,..a HUGE difference in price,..and thanks to all who shared this. Think I'll get some of these pups ordered for my personal stock.
BEST!
Doyle
Middle Georgia
Old 05-15-2011, 08:25 PM
G50 G50 is offline
Doyle,
Yes, I researched those, too.
I'm confident they are the same parts with the same outputs, etc. These are all Bosch DME sensors, feeding very basic signals to Bosch DME brains.
I had my car California smogged the day after I put in the BMW sensors, and it passed with flying colors (as it always had in the past). The smog numbers are exactly the same as they were 2 years ago with the original sensors. The car also runs exactly the same.
Old 05-16-2011, 09:57 AM
AlfonsoR's Avatar
Good to know guys. Thanks.
Old 05-16-2011, 03:19 PM
RETIRED
Joe Bob's Avatar
Any hints on installation besides being carefull not to twist?
2012 ML350 3.0 Turbo Diesel
Old 05-30-2011, 10:41 AM
