I've seen that done also with 30 amp relays, with good results.
Member 911 Anonymous
Or could I take a existing fuse block and transplant/swap it, i.e. a low 5 or 8 amp block and place the "springless" block there? Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 05-26-2011 at 10:54 PM.. |
Can't visualize the "out-riggger" set up?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
It's wire in parallel with the stock relay, and sort of operates as an adjunct, but you abandon the old relay. The fuse block can be replaced wholesale.
I need to replace my ac switch, or I'd have scanned mine with my infrared, and have given you my reading as a data point for you. Hopefully this weekend I'll have time to do it.
I think that fuse runs the clutch. I wonder how many amps it's drawing. You say it heats up pretty fast?
Swap blocks...sure, but not an approach I would take. |
Problem solved. A/c relay not working. Nice that many are interchangeable.
Thanks again.
Mike 82 sc
Hey Rusnak, the fuse get's so hot it literally melts the fuse and shrinks then cuts the AC off. The other day while driving around on stage 3 "HI" I smelt burning plastic followed by a flickering AC Blower, System literally going on and off by itself. Jumped out and the fuse melted yet again loose in the holder. WWest, thank you I will try to find a new block, I assume our panels have three blocks so the first one is the one I need or can just the holder be replaced. I will search it out. Hell, or go ghetto and do the outrigger, I would if it can handle the heat???
BTW which realy? In smuggler's box? Panel?
I ended up going to Morro Bay last weekend, so no worky on my ac. Hopefully I will get it working and observe my fuse temp. I wonder how many amps you're pulling and if it'll melt again.
Oh yeah pretty constant on stage 3 , "HI" the fuse will melt. I will take pic and post
Draco, why don't you simply put an amp meter on the evap motor lead?
I went ahead and ordered a New Block only $21 plus 2 new rails $1.90 each. Well, we will see.
Keep it in your tool box. You'll need it another day. |
Shoot, I've three or four multimeters. I'll let you borrow one - put it in the mail.
If he's testing the total load on that circuit he'll need an "amp meter" or an adapter for the MM that's good up to 30 amps. Most general purpose "multimeters" don't handle current readings up to that range without an accessory adapter. A simple analog panel meter comes in handy.... and batteries are not required !
Thank you Gentlemen, I will visit the Electric Supply Store. like said I may need later
