what is this part
I am trying to figure out what part this is, I am looking at the rubber part next to the oil filler neck, it seems to be cracked but I cant figure out what part number it might be or if it is just a piece of rubber connector. Since it looks like it is about to fall apart I don't want to take it apart until I have the replacement.
1989 Cabriolet 1970 911E Sold |
Its the oil line breather hose I presume you are talking about
I guess that's what it is, I found the diagram looks like there is a rubber sleeve and a valve both NLA, is it an air check valve of some sort?
rubber sleeve 930 207 243 01 valve 930 207 229 00
sudo apt-get purge 930
Yes, a check valve to keep your idle up when you take off the oil cap to check oil level.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
muck-raker
David,
I'm not at home to reference the part name or number, but I recently replaced that same part. You should be able to contact your nearest Porsche dealer and provide the part number. It is a special order part that will set you back about $15-$20 dollars. I ordered mine through a Porsche dealer in Phoenix. Hope this helps.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations ![]() |
Thread Tools | |
Rate This Thread | |
