9112.2t's Avatar
alternator rattle problems?
Hi everyone I have a 911 w/ 2.2 and the alternator is starting to rattle. It has a Bosh 55amp external reg. I removed the belt and the rattle went away. So I removed the alternator and fan from the housing thinking it might be the barrings. There was no drag or noticeable play in the shaft up down in out? I noticed that I only have 3 shims. 2 inside 1 outside. Reading the threads do I need 6 shims? All help is greatly appreciated.
Thank You Bob.
1975 Targa W/ 2.2
1971 Sunroof coupe 2.2T Gone but not forgotten
Old 07-02-2011, 10:01 PM
Member 911 Anonymous
DRACO A5OG's Avatar
on the 3.2 one needs 6.
'85 Carrera Targa
PCA/POC
Old 07-02-2011, 10:07 PM
I had a similar problem, it's your lack of shims.
It can lead to all sorts of problems....
Info here: Pulley Shims, Wrong Config?
My thread: Pulley alignment question
Old 07-03-2011, 04:19 AM
9112.2t's Avatar
Bad news, The Fan is notched and the pulley. can I weld in the void then mill/ machine down to a flat surface on the fan?
1975 Targa W/ 2.2
Old 07-03-2011, 09:58 AM
