alternator rattle problems?
Hi everyone I have a 911 w/ 2.2 and the alternator is starting to rattle. It has a Bosh 55amp external reg. I removed the belt and the rattle went away. So I removed the alternator and fan from the housing thinking it might be the barrings. There was no drag or noticeable play in the shaft up down in out? I noticed that I only have 3 shims. 2 inside 1 outside. Reading the threads do I need 6 shims? All help is greatly appreciated.
Thank You Bob.
1975 Targa W/ 2.2 1971 Sunroof coupe 2.2T Gone but not forgotten |
Member 911 Anonymous
on the 3.2 one needs 6.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I had a similar problem, it's your lack of shims.
It can lead to all sorts of problems.... Info here: Pulley Shims, Wrong Config? My thread: Pulley alignment question |
Bad news, The Fan is notched and the pulley. can I weld in the void then mill/ machine down to a flat surface on the fan?
