I AM NOT PROMOTING THESE DEVICES TO ANY ONE!!! I ONLY GAVE VERY LIMITED INFORMATION ABOUT!!!
My post was only factual information of something that will work EXTREMELY WELL to pull an acceptable A/C SYSTEM Vacuum and included disclaimers, and furthermore specifically stated I will not discuss how the use them for A/C purposes; because they are illegal for me to use them on an automotive system because I am Licenesed, but might not be for some of the readers here depending on their local government laws!!! I agree with you that anything that comes from harbor freight is CHEAP Chinese Throw away CRAP but I emphatically disagree with you that any simple air powered vacuum pump using the same exact technology is a piece of crap!!! They are one of the best hundreds of years old inventions in the world!~ Maybe you just got a defective one as often times happens with China crap? And if it was defective you could have easily exchanged it or returned it and tried another one. I am rather surprised it did not work really good for you, the design is almost full proof as there are no moving parts in it. I have given a few of these away to friends who are refrigeration or mechanical technicians and they all tell me the love them to pull down a refrigeration system that has be already opened. Respectfully to the readers here Do you EVEN Know what an EDUCTOR or EJECTOR IS??????????? Did you know Snap On tools has a similar technology device they sell that costs I think a bit over $300 or do as compared to the one I posted that is sold for less than twenty bucks? I am a marine engineer & I have been using similar devices in the marine engineering industries for more than 30 years for all kinds of applications, not just related to A/C; ANY mechanical engineer on the planet knows about Educators & Ejectors in their first year in school It’s obvious most people are rather ignorant of the value and hundreds of years use of vacuum ejectors! i.e Have you ever even seen or know about an ammonia refrigeration/ice making/freezing or A/C system???? Respectfully Apparently several comments here people are unfortunately ignorant of refrigerant evacuation and transfer equipment & methods used worldwide for the last 200 plus years. i.e. Ammonia was among the early refrigerants used in mechanical systems, and it's the only one of the early refrigerants to secure a lasting role as a refrigerant. Mechanical refrigeration was developed in the 1800s based on the principle of vapor compression. The first practical refrigerating machine using vapor compression was developed in 1834 and by the late 1800s refrigeration systems were being used in breweries and cold storage warehouses. The basic design of the vapor compressor refrigeration system, using ammonia as a refrigerant in a closed cycle of evaporation, compression, condensation, and expansion, has changed very little since the early 1900s. How do you think from 1834 before electricity and electric vacuum pumps was invented moisture was removed from ammonia refrigeration systems??? Answer educators and ejectors! when I am working on what is in the maritime industry called a “DEAD SHIP” (no generator no electricity, no engines, no battery , NO NADA except the compressed air stored for emergencies as well as for starting the main engines or generators in usually 2 large 350 ppsi air tanks) , on a dead ship in emergencies how do you think I transfer HEAVY BUNKER FUEL or diesel oil, remove the water in the bilges to keep the vessel from sinking in an emergency, transfer extremely dangerous liquid & gas cargos that absolutely cannot be pumped with a pump or the transfer would destroy the pump. Speaking of pumps how do you think I prime pumps that have lost their prime and are not self priming pumps or are self prim but wont self prim due to seal damage on a DEAD SHIP????????????????? Give up YET? YEP the same exact same 300 plus year old technology you state here DOES NOT WORK AND IS JUNK you can make with a couple of pieces of any kind of pipe or tubing and put a T in the line and do some amazing things AND LAST BUT NOT LEAST ya ever heard of this little company called PARKER, that is one of the largest A/C manufacturing companies in the world? And do you know what this is made by this little company called PARKER>>>Parker - VACUUM EJECTORS Open your minds instead of slamming it shut because you are ignorant of something very useful, and go do a little reading about educators and ejectors they are one of the simplest inventions of all time, rarely clog and if they do they are extremely easy to clean, are easy to make yourself, they will last almost forever, and furthermore have hundreds of uses you will be amazed at if you learn about them including the ability to pull an excellent vacuum on an A/C System. Best regards, marine engineers do it better in the water Last edited by KelogGes; 05-28-2012 at 04:39 PM.. |
Good luck Reid.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Banned
As a registered techincian, it would seem to me like you should only ever suggest the legal recourse for any DIY AC install. Yet another reason why folks should only choose an established, reputable Porsche aftermarket AC provider. Like Rennaire or Griffiths. Both of which recommend high vacuum on the system, using modern vacuum-producing technology. |
![]() Tap the ruby shoes 3 times. Welcome to Kansas. ![]() Quote:
![]() Quote:
![]() Quote:
![]() If you are right, take the humble side -- you will help the other fellow. If you are wrong, take the humble side -- and you will help yourself. |
Personally I strongly believe Serpentine a/c Condensers for 911 Porsches Obsolete compared to the Parallel Flow Micro-Channel technology I use!
Every new car automotive manufacture in the world to the best of my knowledge has abandoned Serpentine a/c Condensers and switched for good reasons to Parallel Flow Micro-Channel technology ! I offer this proof to ANY Nay Sayers as only 2 examples of respected Scientific Test Comparison Studies and Examples among thousands of readily available worldwide via the internet that definitively render Serpentine Old-fashioned less efficient technology compared to Parallel Flow Micro-Channel Condensers technologies http://docs.lib.purdue.edu/cgi/viewcontent.cgi?article=1640&context=iracc http://docs.lib.purdue.edu/cgi/viewcontent.cgi?article=2025&context=iracc If you disagree with proven scientific facts prove it with scientific facts in a friendly way! |
Note: in test examples> http://docs.lib.purdue.edu/cgi/viewcontent.cgi?article=2025&context=iracc
CTHX = continuous tube (serpentine) heat exchanger PFHX=parallel flow heat exchanger Quote:
Reid, Unless I have missed something no one here has cast any doubts about the workability of your design project, nor the probability that your new design will improve the efficiency of ANY previously installed rear deck lid or front lip condensor.
That being said I suspect that the market has passed you by. Given th obvious limitations of the factory design regarding the location of those 2 condensors I would think you would have gone directly, as others already have, to a design using a "fender" location but inclusive of a good fan. |
1. cost? for each component? as well as in the kit? What is included in your kit? For example, If I change my condenser, Ill also need a drier and expansion valve. Will you sell the drier or will you have a vendor you work with on that? It would be pointless to change a condenser and not change old leaky hoses and o-rings. I guanantee you Reid, if you sell a condener, and a user doesnt get the performance you are advertising, they WILL blame you and your condenser. That is why Griff and Rennaire sell kits and why they disacourage small incremental changes unless everything has been upgraded already. Good way to gain a poor (word of mouth) reputation... not to mention lawsuits and returns.
2. weight? 3. selling points over a well designed kit by Griff and Rennaire who have already proven 35 degree temps WITH 95 degree ambients and "OLD" technology. for anyone who has ice cold AC in a hot climate and has spent $$ why would they dump a working system? Just because its newer technology? 4. What problem are you trying to solve? Does your product solve that problem? Poor vent temps are not a problem... Griff already solved that. So what is the problem this addresses? Is it the Griff cost? Can you really make a product that will last 10 years, provide 35 degree vent temps, and charge the consumer less than $289? 5. Have you done a market study/analysis? How many pre 89 911's are registered today, how many have an aftermarket kit like Griff? How many of the owners have owned their car for over 5 years (they probably wouldnt spend the $$ if they havent spent it in the first 5 years). What is your breakeven point for production numbers? Assume a $300 price point. 6. Have you prepared a technical Q&A with ALL questions answered? 7. Filter vs No Filter? if you site a list of filters from 20 years ago that doesnt fit a car made after 1998, you lose credibility. If you site AC manufacturers and words like "every" and "all" when in fact 5 of the 6 top manufactures (Toyota, VW, Honda, Ford, Chrysler) use no such device, you lose credibility. In fact, the ONLY car manufacturer that actually uses a filter in a post 2005 car is GM. 8. Fans vs No Fans? 9. Proof of your products superiority? if you site research for Serpentine Vs Yours and it doesnt even compare Serpentine but rather tube and fin, you lose credibility. 10. Non-Barrier hose issue? you give us pictures of a chinese vacuum pump and just tell us to add refrigerant every year? Seriously? That is not a solution. We keep asking the same questions over and over again. and we keep getting NON-ANSWERS and research that doesnt even relate to the questions. We are not idiots Reid. We can read. We can google. We can ask a Pro who has done this 1000 times. How many times have you done this? As much as a hard time as I give WWest, the guy actually designed an AC system. So stop trying to snow us by jumping from topic to topic and answer the questions... nuff said.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 05-30-2012 at 03:41 PM.. |
Flat Six
You seem to be fixated on the PFC efficiency issue w/o responding to the (very legitimate IMHO) questions others have raised re: the systemic efficiency of your HVAC system or its effects on other (e.g., intake air temp or engine cooling) systems. Until you stop ignoring these legitimate issues I can't view your claims with much credibility.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
This is really the only problem no system really solves... And it seems his "solution " will actually make this worse... A solution in search of a problem is what I see...
Thanks for the link. That's a great experimental test of PFHX's. Since you brought this study up, I assume you would like to discuss the results. Out of the 6 PFHX's that were tested how many of them actually performed better than the CTHX as a condenser? (scientifically speaking of course....)
Paul 2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS. |
Due to several requests from 911 owners over the past year from hot climates with extreme ambient heat, and much consideration, I have decided to custom manufacture a new product line of State of the Art DESERT DUTY Parallel Flow Micro Channel condensers for Porsche 911’s
When I decide to make them available to the public in the future they will be made available either in a choice of single or dual core PFC No more information regarding this announce is available at this time |
![]() Here is a good summary... "However, there still exist the engineering problems such as condensate drainage, refrigerant distribution and frosting control to be solved in order to extend PFHX’s application to evaporator and heat pump in future."
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 05-30-2012 at 06:20 PM.. |
LOL. Just LOL
Reid, pretty sure Rennaire has the "desert duty" name trademarked. Im sure Jeff or Cab would have something to say about this. Id be careful. maybe you should call it a Fender Cat instead. Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 05-30-2012 at 06:11 PM.. |
Banned
Aaaaand, we're back to the beginning of the circle. Shall we go around one more time? |
Howdy Flat Six, I was not ignoring you!!! You asked a very important question!!!!!!!!!!!!!!!!!!! I am sorry I missed your question, there have been so many people just posting off topic things & crap here lately and others adding to the crap reposting quoted over and over it has gotten very difficult to read this tread for not only you, but also even me! If you had read all my posts to this tread from the very beginning and kept reading you would not have to ask this question related to oil temp, and heat rise caused by the PFC’s, because I specifically address this issue more than once. regardless On my 1975 911 last summer, In 92-95F ambient temps @ 99 % humidity and air vent temps constantly putting out in the low to mid 30s using R-134A, the engine compartment heat rise and engine OIL Temps was negligible heat rise over stock Porsche OEM components running R-12. Engine Oil temps always remained at no more than upper temp safe levels in all types of driving i.e. extended highway, expressways, road ways, side streets including stop and go driving. Furthermore in the 2 other 911’s Justin Stokes did installs of my PFC’s and testing (pictures are posted in the tread) again the heat rise to the engine oil temps was Negligible oil temp heat rise that remained within normal safe ranges. If you need to talk to Justin Stokes owner of Stokes Automotive here in Fort Lauderdale I can arrange this for you! |
Why dont you check facts before you say things that are false hellooooo BTW I have no intention of using the words desert duty for a product name!, where you get these ideas is beyond me!!! Last edited by KelogGes; 05-30-2012 at 07:41 PM.. |
There are many different aircooled 911s out there , with varied equipment levels and states of tune. The scientists amongst us would concur the sample size is far too small to be meaningful. Your exciting results remain anecdotal at this stage.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
