The companies that make conventional fin/tube heat exchangers for e.g. single phase air to liquid publish performance curves to assist with design. Is this type of information applicable/available for refrigerant condensers? Typical info. on the performance chart is the relationship of air cfm on the x axis and kW/ITD on the y axis. Each line is a constant water gpm. One sees that after the air cfm goes above a certain point you don't get much more heat transfer, a look at similar charts for micro-channel constructions might give us a better idea re. effect of more air flow (added fans). As a first pass the rear deck lid condenser could be considered single phase, which seems likely considering most that are posting here mention the system is condenser constrained.
Anyone have complaints of/about the adequacy of the fully operational Porsche A/C system of this era cruising on the highway hour after hour...? AND: Are you aware that almost EVERY modern day passenger vehicle with A/C will AUTOMATICALLY shut-down the A/C if the engine coolant temperature level begins to rise too close to boiling..? How many owners of these newer cars, say, in "Houston" like climatic conditions, have had to endure periods of no A/C on a hot/humid day in stop and go traffic..? |
The AC on my 2010 car NEVER shuts off in the Hot Houston heat and Humidity. It blows ice cold hour after hour even in stop and go traffic. So I am not sure that you are correct...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
If that were true Zims, Rennaire, Griffiths, RetroAire would all just sell a couple fans and call it a day. But Ill take your word for it...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 08-05-2011 at 08:39 AM.. |
40 degree vents temps all day long on R134a in HOUSTON.
Dont be impatient in your replies. No I dont have time to read 10 pages of relies. I skim the info and ask things that come to mind. We are your customer. replying in a harsh way to recommendations will ensure that you are quickly out of business..... I have genuine interest in the rear deck condensor. Its the one weak link I have left... and one that rennaire, griffiths, zims have not addressed adequately. I agree with wwest that adding fan (s) in your rear deck kit would be a slam dunk in hotter climates.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 08-05-2011 at 09:06 AM.. |
There are several things going on in the background related to what I am doing and I have been more than extremely busy I can’t say much about here publically
However I have made a non exclusive agreement with a well known 911 aftermarket A/C parts company interested in my products and have shipped them a couple of my PFC’s for testing purposes. FYI This shipment caused a slight delay in me getting other orders out but it’s now finished and I can resume filling outstanding orders, if you have been waiting this is the reason why. |
Hey Reid, reply when you can about that "Pelican" price. Enjoying this thread, & learning a lot.
I would have posted my email address here, except I dont want the spam from the Nigerian Bankfraud money scammers and other types of spammers that snag emails from trolling forums and blogs. ![]() Reid Last edited by KelogGes; 08-08-2011 at 09:25 PM.. |
PLEASE READ THIS [PDF] A/C System Components
I found this today on the internet looking for something else This will greatly help you SIMPLY understand many of the things related to your A/C system components you have in your 911 !!! AS WELL AS THE TECHNOLOGY OF ALL OF THE MAIN A/C COMPONENTS IN BOTH OLDER AND MODERN CARS IN USE TODAY NOTICE ALSO WHEN IT TALKS ABOUT CONSENSERS what it says about older technology Serpentine condensers verses Parallel Flow condensers!!!! NOTE: I have noticed one error in this related to (TXV) thermal expansion valve; it is basically correct except where it says/shows the refrigerant entering ENTERS THE TXV (TXV= thermal expansion valve); should have been the other end of the 2 ends of TXV valve; where it shows refrigerant entering and exiting the valve It appears incorrectly labeled backwards ! Note: HINT HINt HINT; Superheat Adjustment if the (TXV) thermal expansion valve allows adjust to the temperature inside the evaporator to make it warmer or colder, and that that can give colder air-vent temps down to and below freezing; ; if set correctly AND you have adequate efficient condensation coming from your condenser/condensers !!!!! This is normally pre-set on most A/C systems for approximately 54 degrees F average temp, and can be adjusted colder depending on the quality of the TXV valve AND IF THE TXV VALVE IS RECEIVING ENOUGH LIQUID REFRIDGERENT FROM THE CONDENSERS!!!!) PLEASE READ THIS [PDF] A/C System Components click here >>> www.peopleu.com/course.../lot01.../AC%20System%20Components.pdf |
No offense but I honestly have no interest or time for discussing what you seem to be into; perhaps you can find places on the internet that share your high end scientific interest, I doubt you will find it here at pelican forums? search the internet using Google for scientific analysis of air-conditioning systems if that is your interest The Technology I am using IS WELL PROVEN AND VERIFIED By peer review from the world’s leading scientists and detailed info regarding this is all over the world & internet! In multiple scientific papers and patents as well as higher learning institutions but all you really need to know is Micro-channel Parallel Flow condensers are approximately 30 to 45 percent more efficient than any previous technology that came before it; and it is consider currently the latest technology until a newer technology is discovered in the future; One place you might try are any of the leading large A/C Corporate Manufacturers and view their test data the publish along with their patents; all the companies have switched to this technology for R-134a! FYI; The very latest technology for automobiles being installed today BY OEM AUTO MANUFACTURERS; no longer use R-134a or Freon gases you may know about; they have started INSTALLING AND using super high pressure systems using CO2 gases and ALL OF THE COMPONENTS for these new auto A/C SYTEMS INSTALLED TODAY would require you to remove your current complete A/C system COMPLETELY and install this new technology for every part of it from scratch, he he he; CO2 A/C systems work with an A/C compressor that compresses CO2 gases to liquid at pressures of several thousand pounds per square inch; not a couple hundred pounds per square inch at most that R-134a ONLY NEEDS You might be interested in internet searching for “CO2 A/C systems” My current interest is making custom condensers using latest technology for Ferrari’s and other exotic cars and big rig trucks that suffer like 911/930 1963-2004 warm A/C Porsches OH just a thought; maybe some of the A/C techs here at Pelican in the many different treads here might share some of your interests, there are some really good ones here too, but to my knowledge they have not found the forum thread I started Reid |
Howdy Kuehl,
Thank You for reading & posting Here!!! I noticed some time ago you had subscribed to the tread I started and I think I know who are (smile) It’s an honor to have you here; I have greatly admired and respect your many years service in doing what you do!!! as to your post reply "???" I have become so darn busy lately doing several things related to what I am doing for current product pre-production and other new products, prototyping etc., that my available time for other things like detailed discussions here has become more and more limited and I am now forced having to limit time spent for my post replies here I bet you’re pretty busy right now too Perhaps it’s time we should get to personally know each other (smile) Best Regards Always, Reid |
Welcome to the PP forum. You will find plenty of insightful information here in past posts provided by your readers as well as the host. While you travel down the road be sure you are buckled up, have a destination in mind and you are well hydrated, water for the road, Becks or Tanqueray afterwards works. If you would like to visit us feel free and we will setup a tee time that is convenient. Tally ho! Griff |
I left a hint for a reason I suggest you open your mind and start thinking outside the boxI suggest you learn about "thermal expansion valve superheat adjustment" if you want COLDEST VENT TEMPS or understanding how to get them, as well as learn about adjustment of that other temp nob limit switch that controls your compressor clutch next to your fan speed switch and its full function; you can find posts here at Pelican or search the net Last edited by KelogGes; 08-14-2011 at 05:53 AM.. |
High fan speed does not make vent temps colder
FYI; HIGHER FAN SPEED DOES NOT MAKE YOUR AIR VENT TEMPS COLDER!!!
You will get the coldest vent air temps using the LOWEST SPEED EVAPORATOR FAN SETTING; "ALWAYS use a thermometer for IN THE AIR FLOW to get true air temp readings" NOT a Laser Temp Gun or you only get "surface temp readings" NOT air temp readings!!! A common way some people use to make false or misleading claims for coldest A/C air vent temps and you can tell when "they show a Laser Temp Gun digital display" in advertisements instead of using a thermometer that can actually measure and show air temp !!! A laser temp gun can not measure air temps it can only measure surface temps!!! You can USE A Laser Temp Gun to surface test TXV's and evaporator core and condenser surfaces quickly! (but know that most of these laser temps guns are not always accurate unless you test verify them using a thermometer, I have read that most cheap Laser Temp Guns are not very accurate and therefore give false temp readings; mine are all verified) You will get the coldest vent air temps using LOW SPEED FAN SETTING; and "ALWAYS use a thermometer IN THE AIR FLOW to get true readings" NOT a Laser Temp Gun or you only get "surface temp readings" NOT air temp readings Air going through your evaporator from the cabin and back out to the cabin needs enough time to “absorb cold by giving off heat” in the evaporator, if it moves too fast going through the evaporator it will not get as cold as it can on lower fan speed and as a result air vent temp will be warmer on high fan speed! Yes the cabin air will have more mass volume of air; do to faster fan speed giving a higher CFM OF AIR (cubic feet per minute) exchange rate and this will help drop the cabin temp faster as it starts cooling the cabin air down when it is hot; but the vent air temp will not get the coldest unless on low speed where it can move slower allowing the air more time to give off heat and become colder (Note: to those with advanced technical refrigeration theory knowledge and expertise; my statement was written only with the intent to over simplify understanding, for those without knowledge that do not understand or know anything about technical refrigeration theory and you are welcome to chime in and correct me as you deem necessary) Last edited by KelogGes; 08-14-2011 at 07:34 AM.. |
Heat exchangers, disregarding other factors, are at their most efficient when the two mediums are at the greatest temperature differential. In this case since the Evaporator CANNOT be cooled below 32F and remain operational very long so that is the lower limit for that side of the equation. Next we move on to airflow VOLUME. Why has no one addressed the issue of that tiny evaporator airflow inlet duct and how well the inflow is "baffled". Last edited by wwest; 08-14-2011 at 08:32 AM.. |
But... More airflow can, MIGHT, mean MORE cabin cooling provided that the overall system capability can keep the evaporator very near that 34F without the compressor cycling off. If the compressor cycles off then you're not WARMING the evaporator core as rapidly as the overall system has the ability to keep it cooled, cooled to 34F. Last edited by wwest; 08-14-2011 at 08:57 AM.. |
There is no need to 'adjust' a TEV, the difference in superheat between an R12 TEV and a R134a TEV is 'nominal'. You can get yourself in more trouble by 'playing' with the valve. Those whom have noted a difference between a stock set valve and an adjusted one need to look at other variables for any changes they may have observed, such as 'was the improvement caused by a change in super heat setting or simply because the system was purged of air or had a different refrigerant charge than before (this is the most common reason for a change). We have spent literally hours discussing this phenomenon with Parker's TEV Engineering group and they concluded that there is no benefit, if this was the case then Parker would make an adjustable valve for the market. There is one area where there are a few benefits and that is with systems that use an orifice tube rather than a TEV. If you want to prove this reality wrong then simply test your theory in a lab environment. |
On a LH drive 'factory' Behr brand (evap) system there are 2 air inlet to the evaporator box, one under the driver's side foot board and one under the passg. side. Discussing the passg one would assume the factory carpets and any added carpets might reduce the air flow into the evap box, and there has been suggestion that the factory fan speed control resistor pack in the same intake plenum might reduces air flow. Logically it makes sense however in practical terms (testing) there is little if any difference if you remove the carpets or remove fan speed control resistor pack. If you wish to determine how much of a change there could be then simply place an anemometer (device to measure air speed) in front of a vent and an amp meter to the evaporator motor. If you see a 'measureable' improvement with the anemometer then you proved your theory. If you see an increase in amp draw (motor driven fans typically draw less current when their intake is blocked and more current when they have more air to pull or push) you also proved your theory. With the regard to 'vents' .... the more the better. Pelican Parts - Product Information: PEL-GR-KUVNT Or simply crank up the volume with higher out put blower motor. Pelican Parts - Product Information: 911-624-899-00-M207 |
