Member 911 Anonymous
DRACO A5OG's Avatar
Originally Posted by hcoles View Post
I like the sound of this, good thinking. I assume you want the smallest diameter cap where the seal will fit. Do you have a picture handy or maybe take one of the end cap and post? Thanks.
+1 please post a pic. I think the diameter is almost 2" but would love to know for sure.
TIA
'85 Carrera Targa
PCA/POC
Old 07-19-2011, 08:19 AM
The photo below shows the pipe cap and hand screw I used. The size on the pipe cap says 1 1/4" which I believe is the I.D. of the pipe. The size of the opening or the O.D. of the pipe looks to be 1 5/8". I took the dust cap to the store to get the right size. This size works for my car an 86 Carrera. I like the wood hand screw because it won't mar the metal, but I'm sure you could use a c clamp. Hope this helps.
John
'86 911 Coupe
Old 07-20-2011, 06:14 PM
DRACO A5OG's Avatar
Perfect!
I am re-installing the caps now, all rears have popped off again.
Thanks Brother!
'85 Carrera Targa
PCA/POC
Old 07-20-2011, 06:39 PM
OK, I see now, I'll try the pipe cap method next time, Thanks.
Old 07-20-2011, 07:20 PM
redridge's Avatar
This method work with me... 2 clamps to keep seal in place, and tap the clip in between the 2 clamps with a piece of wood.... snaps right in.
Old 07-20-2011, 07:23 PM
DRACO A5OG's Avatar
OK trying this method right now:
Will post an update , It was yummy
'85 Carrera Targa
PCA/POC
Old 07-20-2011, 07:31 PM
DRACO A5OG's Avatar
Update:
Gerber Cap is too weak, it gets warped.
Made a SST out of Black PVC 1.5" Connector, Cut out spaces for my Wood Vise.
It seemed to slip on but as soon as I loosen the vise one side pops out. Tried again, with a bit more pressure. BROKE thru the rubber at the connection of the Barbed Wires.
WHAT A POS!!!
'85 Carrera Targa
PCA/POC
Old 07-20-2011, 08:57 PM
Tsunamiboy's Avatar
I do most of my own maintenance and upgrades but when it comes to brake calipers I use Eric at PMB Performance. Awesome restoration complete with original plating.
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 07-20-2011, 10:02 PM
DRACO A5OG's Avatar
Here is the tool I made, took a break and tried again, it actually worked but will need to do it two inner one again. Thanks FAG ( that's what is says on the boot )
It would have been easier and more accurate if it was off the car, . Live and Learn.
1.50" PVC, used a dremel to cut out the section for the wood clamps:
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 12:20 AM
rnln's Avatar
Only a dust boot clip. This is totally crazy. Why don't they make it so that they can be as easy as the front?
Fat butt 911, 1987
Old 07-21-2011, 01:08 AM
DRACO A5OG's Avatar
Yeah, RIGHT? WTF FAG?
I was thinking there must be more than just me with this issue and I bet most or even shops that installed these boots probably popped off???
In any case, If I need to service just the boots, I am thinking I can place a slight groove with a dremel around the rim to make the CRAPPY FAG Boot to bit into???
I mean that is all that needs to be in place is a lip to catch those silly barbs, right?
or is there better boots or pistons for the rears out there???
'85 Carrera Targa
PCA/POC
Old 07-21-2011, 09:49 AM
