nippy's Avatar
ER Polybroze just started squeaking after 4 months,normal?
The drivers rear spring plate bearing/bushing just started squeaking today and man its bothersome,I herd they squeaked but it never did in my car until today,is that normal?Just getting broken in or do I need to gease them already?
Old 08-20-2011, 07:40 AM
KNS KNS is online now
Hmm... mine never squeaked and I only greased them once a year - sometime even a little longer.
Kurt
Old 08-20-2011, 07:47 AM
I am considering this upgrade and wondering if humidity/rain is a factor? You don't get much dryer than N. Phoenix, AZ. NYC has seemed a lot like the PAC. NW lately. Would love to hear others' experiences too.
'88 Sunroof Coupe
'95 900 CR
Old 08-20-2011, 08:09 AM
ivangene's Avatar
my polygraphite bushings started to squeak after a few months....sucks donkey d!K
Ed M
86' Coupe
Old 08-20-2011, 08:15 AM
175K911's Avatar
My ER Polybronze front and rear have been squekk free for several years. But I hit them with a grease gun twice a year.
Weltmeister polygraphite will all squeak and you have to disassemble to grease them.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 08-20-2011, 09:08 AM
Did you contact ER for support? I'd think the manuf. would provide a good answer.
Sherwood
Old 08-20-2011, 09:35 AM
For you guys with rear ER polybronze springplate bushings - what do you use to grease them? I cannot get the tip of the grease gun into the narrow space to grease them.
Marv Evans
'69 911E
Old 08-20-2011, 09:46 AM
GaryR's Avatar
Send a message via ICQ to GaryR
http://www.amazon.com/Plews-05-025-Needle-Grease-Adapter/dp/B000CCIM1A
Gary R.
Old 08-20-2011, 10:26 AM
I got this one handed grease gun at Harbor Freight Tool for about $8 on sale and the adjustable angle tip at the same place for $3.
Pull back a ring on the tip and it pivots around 360 degrees to change it's angle where it will lock in place when releasing the ring and it will fit the grease fittings on front and rear ER polybronze bushings easily.
ER says to jack the car up to take the weight off the control arm or spring plate bushings so grease flows all the way around them top to bottom while greasing them every 3000 miles. Makes sense.
Old 08-20-2011, 10:52 AM
gunlover05's Avatar
had mine for about 15K miles...i did have just a little squeaking early, but kept lubing every 3k and after the 5k or so the squeaking left and has never returned...i can guess that it wears itself in after a while...i need to buy one of those 360 grease fittings though...the Elephant PB bushings are a very good product imo.
85 Carrera
2011 Cayenne Turbo
Old 08-21-2011, 07:52 AM
gjs
glennspiegler's Avatar
After 3 yrs, greasing every 5K, the rears began to squeek. Jacked it up, removed spring plate cover and outer bearings The old grease was to thick to allow new grease up the little lubricating tunnels. Cleaned up, regreased and no more sueeks now for about 6mo. Be careful not to loose the shim washers that give u the proper play. Read on Elephant Racing's site for proper install. Good luck, Glenn
88 911 Carrera Cab, SW chip, B&B headers, custom sport muff
2015 Cayman S
1948 Willy's Overland Jeepster
2013 Chev Sub
2004 Nisson Xterra
Old 08-21-2011, 01:20 PM
Typically, "pressure-lubed" grease joints have an escape path for old grease to exit as fresh grease enters w/o exposure to the elements. Can such a path be created in the ER bushings?
Sherwood
Old 08-21-2011, 03:29 PM
Chuck Moreland's Avatar
Properly fit and lubricated, they do not squeak. By far the most common cause of issues with spring plates bushings is inadequate spacing beneath the cover plate. Be sure to follow the instructions that explain how to space the cover plate to achieve some lateral play. Without this, you will have problems.
If you need more help, feel free to call or email me directly.
Chuck Moreland - elephantracing.com - vonnen.com
Old 08-21-2011, 09:02 PM
onboost's Avatar
And this my friends is what is known as customer service!!
Thx Chuck
RGruppe #180
Old 08-25-2011, 01:57 PM
Hodgey's Avatar
I didn't use the PB ones but I did use the rubber ones that were replacements for the originals and they squeak really badly until I have been driving for a while.....any suggestions???
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 08-25-2011, 03:01 PM
moneymanager's Avatar
I have noisy ER polybronze spring plate bushings. They were installed about 600 miles ago. We have lubed them (wheels dangling as recommended,) checked the free play as recommended by Chuck, even added extra free play to see if that would help. The bushings are still noisy, not squeaking but generating a fairly loud scraping/grating sound particularly when turning. I have pulled the shocks and anti roll bar to be sure the sound was not coming from those sources. Anyone have any suggestions not already aired above? Thanks, Jim
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 12-15-2014, 07:39 PM
chapo's Avatar
Have delrin bushings on mine, spent a little time front and rear sanding and fitting the bushings and arms, put anti seize on them, no binding, no noise, no problems. Two cars, ten years. Low buck is ok on these cars sometimes.
Patrick
Old 12-15-2014, 07:50 PM
jittsl's Avatar
Had ER poly bronze for almost 10 years on my 70 911 and never had a peep out of them. I lube them about every 2 years. Love them so much I just installed them on my backdate.
Laurence
1998 Specbox racer / 1998 Boxster / 1984 RSR tribute
1970 911E Coupe / 1970 911E "speedster" / 1969 912 Targa
1963 356B T6 Coupe / 1962 356B T6 Cabriolet
Current projects - 1955 356 pre-a Speedster / 1964 356C
Old 12-15-2014, 08:36 PM
I have been good for a few years- I grease them every 6 months- gets messy but it works
Old 12-15-2014, 08:44 PM
Given proper clearances as recommended, can we assemble a list of lubes that minimize/reduce squeeking, moaning and peeping?
Sherwood
Old 12-15-2014, 08:46 PM
