Foam behind rear shock tower replacement source?
Doing a cleanup in the back while the engine is out. The foam seal that fills the void between the shock towers and the firewall is all deteriorated. What is being used these days and a source please.
Thanks, Thor ![]()
1978 SC coupe #1834 |
Thor,
Pelican sells it: they call it "engine compartment sound mat" there is a few different types, just do a search on the parts section. -Rutager
Rutager West 1977 911S Targa Chocolate Brown |
Fleabit peanut monkey
Parts PDF calls it a "Strap"
Here is the same part number that PP sells. Pelican Parts - Product Information: 911-504-930-00-OEM |
Taking it apart is easy
Maybe our host sells it, but I used something else. I bought a dense, black foam rubber pad that is made for the reduction of noise and vibration caused by window-mounted air conditioners. The air conditioner sits on top of this one-inch thick material, which can be purchased in any hardware store.
I figured that the idea of the original material in the car was to cut air intrusion and to reduce noise, so the identical looking rubber slab I bought should do the job, too. Just cut the pad to fit, using two layers as necessary. Mine has stayed in place perfectly with just a friction fit.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Thanks for the answers! Thor
If it is not gonna be concours - I like Jeromes idea.
are 2 different things being discussed here? don't the blocks shown on the PP link install from under the car? and the OP posted photos which seem to be something that goes in the engine bay (like below the engine pad?) In previous threads I read the purpose of the blocks was to block heat.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
The picture is what the blocks in the link look like after 33 years. Pelican Parts - Product Information: 911-504-930-00-OEM
As discussed the foam pad in the engine compartment and the foam blocks are different. The blocks are installed from underneath the car. The factory "straps" have an addhesive strip 0n one side that faces the shock cross member. The engine capartment pad is glued in and fits in the same cavity, just from above.
I replaced my engine pad and foam "straps" when i had the motor our for a rebuild. I ordered the foam blocks from Pelican.
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Thor, I guess what is confusing me is that you posted photos of the engine bay, which I took to mean that's where you found the disintegrated foam. The blocks install from underneath the car, not in the engine bay. Stevie, that is a clean engine bay.
Member 911 Anonymous
I placed 7/8" ID Plumber's Insulation Foam, cut to about 10 inches and jammed it up there. Left a 6" gap as per OEM but my sound pad took up the gap
![]() Checked it on my second engine drop and it was in place, nice and tight. $5.99 at ACE. It will fail Concours, oh well
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I'm about to replace the sound pad AND the "blocks". It seems like the blocks, along with the bottom of the sound pad, are designed to seal the gap at the front of the engine bay. I'm assuming Porsche has some reason for this but not sure what it is. Maybe it has some effect on engine cooling by not pulling hot air from around the engine and exhaust into the engine bay?
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Mark
1979 911SC Targa |
I used HVAC insulation foam on the same spot while i was refurbishing the heat valves. i cant tell the
difference from before , but if the factory did it , they had to have a reason |
