Scott that just does not look incorect . Can you humour me and just loosen that allen screw at the front of the housing ? does it allow the lever to go back at all ? I am just curious about the geometry
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Iceman, I will definitely try loosining that up tonight to see if it will allow it to pass.
BTW, I meant bending the arm that's welded on the lever (if that's the issue), not the lever itself. Sherwood |
Sherwood, nothing to do with spring compression, The lever is locked into position as the pawl is rotated all the way back until it bottoms out and the tabs won't clear one another.
S |
Wayne, something else to note, the locking pawl on the FSS pawl plate looks a bit different than my old one (which I have no idea of knowing whether is stock or not). The general shape is the same but it appears to be a bit larger than the other one. I am not sure if the lock pawl plate is supposed to be different than stock but assume so since it is part of the kit.
What's the part number on the top of it?
JR |
Schleprock
I had this same problem on the short shift kit I bought from Pelican earlier this year. I did the same thing. Fiddled with it for awhile with the entire housing removed from the car and sitting on my bench/lap. Not a coupler issue whatsoever. It's the width of the gate tab on the shift lever.
Kevin L '86 Carrera "Larry" |
I measured the width of the lever arm from a short shift lever and it's 19.24mm. Other standard factory lever arm widths were in the following range: 16.83mm, 16.76mm and 16.69mm For reason known only to WM, their short shift lever arms are really thin. I'd guess in the neighborhood of 10mm wide. If the current lever arm in question is much wider than 19mm as suspected and that's the only issue, I'd take John Walker's sage advice and trim the width accordingly. Hope this helps, Sherwood |
I too recently upgraded with this same kit, purchased from Pelican. I had the exact same problem. I took my Dremel tool and trimmed back the forward side of the tab welded onto the shift lever, just enough to clear the blocking tab on the gate when shifting back to neutral, and then cleaned it up with a hand file. Works great now. I figure if I ever find a factory-correct shift lever, this part is relatively easy to change out. I'd say it is a manufacturing defect. Wayne, if your vendor offers to provide corrected parts, I'd sure like to get one too.
Phil
78 911 SC 89 Range Rover 91 318IS 95 Ducati 916 86 Cagiva Elefant 5 bicycles |
Try replacing the newly-installed "FSS" carrier plate with the previous carrier plate and see if that works. If indeed the reverse lock pawl on the "factory" short shift carrier plate is the culprit, please contact your parts source and let them know. This will avoid many customer relations issues now and in the future. Sherwood |
Iceman, I backed the adjustment screw out so it had maximum play and it did not solve the problem. But, the tabs almost cleared. That was certainly very clever geometric thinking!
guess you are getting the dremmel out now
I installed a factory SS kit a month or so ago and used my old top plate becuse the new plate was still laying in the box when I was done. After looking over my "mistake" , I concluded there was no reason to take it back apart, as it worked perfectly! Give it a try! As for backing off the hex screw that adjusts the "cage", the screw was an update to the older shift tower to allow adjustment of the cage. The early tower only had a couple of tension washers to keep the cage clearence minimal, but they became sloppy over time, ergo the adjustment hex screw. The screw should be adjusted for a minimum of play without the cage binding up.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 09-19-2011 at 04:26 PM.. |
You also might want to check the part numbers on both of your top plates. The only number in PP is 911 424 063 04. Catalog states fits all '74-'86 shifters.
I looked at mine, and the new SS plate and the old stock one are the same number! If your new one has a different looking pawl than the old stock one, as you stated, perhaps there was a manufacturing defect in the new pawl assy.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Voila!
I finally got around to replacing the new lock pawl plate (left in image) with the old lock pawl plate and the tabs clear by about 2-3mm, Yes! The new plate has B+H stamped on it which I know to be a german stamped sheetmetal supplier and has the correct porsche number stamped in 911 424 06304. The old plate, unfortunately, does not have a number stamped in anywhere, so not sure if it is aftermarket or original Porsche????? As you can see from the pictures, the lock pawl looks similar but is actually quite different in its geometry. My best guess is that the lock pawl changed at some point in time, because it seems from what others have reported, that the width of the tab on the factory short shifter has been pretty consistent over the years. In any event, the current FSS kit has a problem that needs to be resolved. Thanks everyone for their help. Wayne, glad to help out where I can, you know how to contact me. PS. to Uwanna serindipitous that you forgot to replace the top plate, lucky you! Scott
The lock pawl plate I took out of my '78 I'm fairly certain is the factory original, and like yours, it has no part number on it. I would question why the kit would include another one of these if it is supposed to be exactly the same as the standard one. Unlike bushings, pivot pins, and springs, it is not a high-wear item. Ah well, I suppose the main thing is that it works. As JW suggests, no point in over-analyzing things.
78 911 SC 89 Range Rover 91 318IS 95 Ducati 916 86 Cagiva Elefant 5 bicycles Last edited by phiba; 09-20-2011 at 08:13 PM.. |
![]() Hey, this is a tech forum. Forum participants, as demonstrated by their high post count, are afflicted with OCD and over-analysis. We revel in it. Visit PARF and see grown men, in effect, argue at length with a blank wall. ![]() Sherwood |
Author of "101 Projects"
I personally think that the tab may be slightly off, although your experiment with the lock plate swap seems to go counter to this. I'm really not sure about the differences in the lock plate - I think maybe at one time there were different versions of this over the years. The only way to know would be for me to check the microfiche (which I do have tucked away). Right now, the lock plate is the same for all the 915 cars, PN: 911-424-063-04.
The only solution for me as a supplier is to take back the kit and send a complete new one (or we might be pulling these off the shelf, so it would just be a refund and no exchange). I can't mix and match parts, as these are sold as a complete kit. So, we can do that if you'd like. Honestly, if it were me, I'd chalk it up to a fluke and simply grind the tab and be done with it - it's a bear to take these things apart with the springs and everything. I called my supplier on this, and he would like to get the complete kit back (every single piece), so that they can take it to a shop and test install it in a car. But I told him that was probably not the best solution for the customers because that would require removing the kit from the car and installing a whole new one that may or may not have the problem fixed. He mentioned that they have sold a ton of these over the past several months with no complaints, so this problem may be intermittent. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
One more thought - just because a 30+ year old lock plate on the shifter all of a sudden works with the new kit doesn't necessarily mean that the problem is with the new lock plate. The old one may be slightly worn out from years of use, and the new one may be in the "proper" position (hinting at a tab mis-positioning).
-Wayne
I've noticed that the mounting holes on the new lock plate are elongated, not round, as the originals were. Perhaps this allows the plate to be mounted far enough to the left that it hinders the lever movement.
That's the only difference that I could see. JR |
