1974 911 w/ 83 SC engine
Torque spec for the intake runner nuts?
I have my CIS re-installed on the engine and am about to bolt it down. Can anyone tell me the torque specs on the 2 nuts on each intake runner? I couldn't readily find it in the bentley or 101 projects book. Thanks!
Old 09-22-2011, 12:53 PM
Member 911 Anonymous
DRACO A5OG's Avatar
HWM,
Not familiar with an intake runner do you have a pic?
Jim
'85 Carrera Targa
PCA/POC
Old 09-23-2011, 12:04 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Since I'm not sure 100% the one you referring too... I wont give you the number in case we are not taking about the same.
But if its the one I'm thinking, check one of those page (they both give the same torque value):
Bentley 911SC page 102-39
Bentley 911 Carrera page 102-38
Who Will Live... Will See
Old 09-23-2011, 02:32 AM
18 ft/lbs.
Paul
Old 09-23-2011, 03:17 AM
DRACO A5OG's Avatar
Originally Posted by psalt View Post
18 ft/lbs.
Is it me or is almost any fitment connected to the engine block is 18ft/lbs
'85 Carrera Targa
PCA/POC
Old 09-23-2011, 08:10 AM
It's not you. 18 ft-lbs is the normal spec for 8mm bolts/studs. Don't try it with 6mm fitments to the engine CASE.
Old 09-23-2011, 08:42 AM
Originally Posted by DRACO A5OG View Post
HWM,
Jim
The six aluminum tubes that run from the CIS airbox to the intake valves. They house the fuel injectors. I call them intake runners. I don't know what their technical term is.... They're bolted to the engine with 2 nuts each.
Old 09-23-2011, 01:01 PM
JJ 911SC's Avatar
Intake Manifold
25 Nm (18 ft-lb) as found in Bentley 911SC page 102-39
Old 09-23-2011, 02:10 PM
NotoriousDAN's Avatar
i know this threat is old but is there a particular sequence to follow? Work inside to out side?
1978 911Sc
Old 04-23-2012, 07:22 PM
JJ 911SC's Avatar
Not that old...
Both side are independent from each other so you are left for 6 nuts in 2 rows on each side.
So I did front, rear and middle in torque steps; a run at 10, 15 and 18 ft-lb.
Old 04-23-2012, 07:36 PM
Fleabit peanut monkey
Bob Kontak's Avatar
There are two nuts per runner. No special sequence but snug both nuts before final torquing.
Old 04-23-2012, 07:39 PM
