arbita1's Avatar
Alternator Ground Wire - Fix or Replace
What do I do with this? Wrap with electrical tape or replace?
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-27-2011, 05:27 AM
prschmn's Avatar
Bad insulation doesnt matter a lot on a ground.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 09-27-2011, 05:38 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Clean it (and wire brush the ends), wrap it in tape, fugettaboutit.
Gary R.
Old 09-27-2011, 06:08 AM
Hi
Targa Me's Avatar
with the gap in the insulation, possible hidden corrosion; I'd replace it with new. why wouldn't you?
These cars can do odd things when it comes to a bad ground.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 09-27-2011, 08:55 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Its probably very stiff and showing some resistance. Here is some info: While you are in there * Alternator Cable
Who Will Live... Will See
Old 09-27-2011, 09:16 AM
Somatic Negative Optimist
Gunter's Avatar
If it's still flexible, re-use. Or make a new one with minimum size 10. The bigger the wire, the least resistance.
The alternator has one brown ground wire in the harness on the back and the thick wire to the case is an additional ground wire.
This came about with the change to an internal regulator around 1980-81 with a Tech Bulletin from Porsche.
To ensure ground, open the nut on the case, use some Vaseline on the connector and re-tighten. I use either dielectric grease or Vaseline on all electrical connections.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-27-2011, 09:40 AM
