Ball joint installation socket
The Ball joint installation socket for the lower front strut mounting point says that it is for installation only. Part can be found here on pelican parts..
Ball Joint Pin Wrench Socket, 1/2 Drive, NOTE: For INSTALLATION ONLY, 911 (1965-89), 914 All, 912
Question is why is this for installation only.....looking at the socket it would appear to be a simple design with no unidirectional specific fittings...
I know what it says. ....but why?
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 06-03-2011, 10:03 AM
Picture of the tool
Old 06-03-2011, 10:05 AM
Oh wow, check it out. They must be reading my posts.
Old 06-03-2011, 10:13 AM
schumicat's Avatar
because it is made out of soft metal and will probably deform/break if you try to use it to untorque a nut which is corroded in place.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-03-2011, 10:25 AM
I wondered the same thing. It apparently the tool usually just breaks removing the nut.
When I did my ball joints I just used a dull tipped air hammer. Just put the tip of the hammer on one of the teeth of the nut and pull the trigger. It loosed right up. It was a very easy and fast way to get them loose.
My ball joints came with new nuts so the old ones were trash anyway. They go on with something like 160 ft lbs of torque.
Old 06-03-2011, 10:36 AM
well.........
Rusnak......I have never been accused of reading other peoples post
Maybe I was just looking for a conversation on a boring friday......
But I guess you guys did provide some insight.....I would not think that it would break...It seems to be beefy enough....but I could be wrong.
Wow, thanks guys I guess I will go with the air hammer idea and proceed...
Old 06-03-2011, 10:49 AM
The nut and the balljoint flange where it fits into the control arm should be greased before tightening it to 183 foot pounds.
The grease lubricates the threads so it screws on easier and gets torqued properly and helps keep it and the ball joint moint flange from rusting as quickly.
Use a hammer and chisel to remove the nut when it's been there a while, but if you wanted to remove it right after installing it for some reason you could probably use the expensive special ball joint socket without damaging it.. I havn't tried it though.
With the car on jackstands use a floor jack with rags or a piece of carpet on the lifting pad to hold the torque wrench snug up against the nut so it doesn't slip.
Old 06-03-2011, 12:05 PM
Garage Queen
PorscheGAL's Avatar
That tool is pretty much a one time use. It gets deformed in the process of torquing. Use the hammer and chisel as JFairman suggested to remove.
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 06-03-2011, 12:18 PM
No, not you. I was talking about Pelican. No such warning existed when I bought mine. I ruined the pins the first time I tried to loosen the balljoint nut. I was looking at it and going "wtf, what do I do now?" Well, lightbulb went off, I realized that I have a 3' long pipe wrench and a 4' long box steel tube. I used the pipe wrench on the nut, and it came off so cleanly it didn't leave a mark on the nut.
I re-installed the same balljoint nuts with new balljoints (didn't come with nuts), with some copper grease, and used the fancy tool with a torque wrench, placing one foot against the inside fenderwell.
Old 06-03-2011, 12:21 PM
Pelican Parts - Product Information: PEL-TOL-P210
It's a quality SIR tool made in Germany and will last a long time if used properly.
I borrowed a practically new one from a friend when I replaced my ball joints and the 4 dog teeth in the socket looked exactly the same before and after I used it.
If you only get one time use, you're not using it correctly.
Did it with the car on jack stands and a floor jack holding the torque wrench and socket up on the bottom of the ball joint nut so it wouldn't slip. I sat on the ground with one leg up over the torque wrench handle and foot against the inner fender well to push against so I wouldn't pull the car off the jack stands or slide myself closer to it.
Lower back does most of the torque work in that position and was a little sore the next day.
Old 06-03-2011, 01:03 PM
steely's Avatar
I used a pipe wrench /with an extension to get mine off and had the garage torque the new ones on the C/As.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 06-03-2011, 01:23 PM
My Back
Well, the info is good.....I guess I need a larger Torque Wrench...
Im glad to see so many other people have been in the same spot.....meaning Im not going at it alone.
Thanks guys...will let you know how it goes..
Chris
Old 06-05-2011, 07:28 PM
Wildman Emeritus
I used a Dremel with a cut off wheel and they were off in no time. Just cut and pry apart so they slip off or cut twice and let the 2 halves drop. No sore back, no busted knuckles, no torn up tool.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 06-06-2011, 08:59 AM
Member 911 Anonymous
DRACO A5OG's Avatar
The Rusnak Technique:
Pipe Wrench
We had the proper service tool but all it did was strip the nut and ended up using Rusnak's recommendations, worked like a charm. Installed it too with the Pip Wrench
'85 Carrera Targa
PCA/POC
Old 06-06-2011, 09:15 AM
tobluforu's Avatar
Pipe Wrench
This is what I used as well, that POS tool I bought would not bite enough.
Old 06-06-2011, 09:19 AM
DRACO A5OG's Avatar
We even tried the "using the spare floor jack for support technique to no avail
Car was too low to use a 600lb ft SNAP ON impact gun.
'85 Carrera Targa
PCA/POC
Old 06-06-2011, 09:25 AM
175K911's Avatar
I use the cheap 4x4 tool from NAPA with air gun to take off, then reassemble with the good tool and torque.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 06-06-2011, 09:46 AM
Draco: ouch! I hope more people just use the pipe wrench to start with - it would save a lot of folks a lot of trouble.
Old 06-06-2011, 11:11 AM
DRACO A5OG's Avatar
Agreed Dr Rusnak .
My buddy was doubtful but he in now a Believer, Thanks Again!
'85 Carrera Targa
PCA/POC
Old 06-06-2011, 11:13 AM
I did not have air hammer in my arsenal, started with liquid wrench, dremel, heat, after 1 hour made some calls, borrowed an air hammer and had both sides off in a few minutes.
Air hammer is the way to go.
Old 06-06-2011, 11:26 AM
