Can I fit 16X7's Fuchs under my unmolested 1974 911?
I didn't want to hijack the other thread regarding 15x7 fuchs on an unmolested 74 911 so I decided to start my own thread. I am new to the forum.
introduction I tried the search feature but didn't find anything specific about my question so here goes: Will 16x6's and 16x7's Fuchs fit under my unmolested 1974 base model 911 without modification? I have no flares or wide body. Would getting a certain tire size make any difference? I currently have steel wheels (15X6), am in need of new tires and want to upgrade to Fuchs but want to make %100 sure that they will fit before I purchase them. I appreciate any input and information you all can provide for me. Thanks for your help! Ross p.s. My 911 is currently in storage in NM and I am in CO. I will get and upload photos as soon as I can.
1974 911 Coupe-one owner Northern Colorado "My reading of history convinces me that bad government comes from too much government" Thomas Jefferson Last edited by Workhorse; 02-14-2012 at 09:35 AM.. Reason: updated |
Location: behind the redwood curtain, (humboldt county) california
I've got the standard 6x15 Fuchs on my 74 and 205/60 tires rub on the left wheel well on bumps, (stock, not rolled fender lips).
On the right side, i installed the factory thermostat and brass lines for the front cooler and have about 1/2 inch clearance from the inside of the tire to the oil lines, so I don't think you can play with the offset much - Maybe. Tire section will also need to be considered. I dropped a size to 195/50 Dunlop Direzzionales and am happy with that. God luck, chris |
First, why do you want to run staggered wheels, but yes both will fit just fine, but tires play a part as well, what size were you thinking?
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 02-14-2012 at 11:55 AM.. |
The fronts will be fine. In the rear, you should be able to fit 7x16s with 205/55-16s tires. The "standard" 225/50-16s that are typically on the 7s in the rear are going to be a tight fit. I've seen it done, but it required "rally" ride height.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Flat Six
As Chris and Mike indicate, tire size/brand and ride height will make a difference, as will alignment (particularly camber).
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Thank you for the replies!
I need to purchase new tires and I was curious about whether Fuchs would fit at all. I like the Fuchs. I have been told via PM that if I run 205/55/16's all the way around, I will be just fine with 16x6/7. He sent me a photo and everything looks good fitment-wise as well as overall. I haven't quite made up my mind about which tire brand just yet. Does anyone have any brands/model to "absolutely stay away from" or brands/model that they are very happy with? My 911 is a tourer and part time daily driver weather permitting. Thank you for your input, I appreciate it. Ross
1974 911 Coupe-one owner Northern Colorado "My reading of history convinces me that bad government comes from too much government" Thomas Jefferson |
I justdid this to my 69. 215/55/16 on the rears and 205/55/16 on the fronts. Fit fine. You can use these links to size different combinations.
Tire size calculator Wheel Offset Calculator
69 911 2.3Ez 85 928S |
I have 16 x 7 on the rear of my 73.5.....Right rear will rub on a bump with a passenger on board. Ok if by myself.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Just out of curiosity (don't mean to hijack the thread either) but would it even be possible to do 16x7's in the front of a '74?
Thanks, Panos |
Yes. The front fenders are basically the same from '69-'89 and many people are running 7s and 9s on later cars. I have 8x16s in the front of my '76 with 245/45-16s. They fit fine.
Wow u run 16x8s in front. I didnt tihnk they would fit. was thinking of putting 8's in the rear but have heard many people say it won't fit on a narrow body
1975 Aubergine 911S - Barney "When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson |
8s will fit in the front with the right offset. I think there are people who have also fit 8s in the rear (again with a custom offset), but generally Porsche factory 8s will not fit on a narrow body.
