86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Steering column "buzzing" vibration-Update (Resolved)
A very slight intermittent "buzzing" vibration has developed in the steering wheel/column at 40+ MPH,
and is more prevelent on the freeway when changing lanes.
All has been checked:
1. Alignment.
2. Balance.
3. Tire pressure(s) 29F/36R.
4. Tire wear is correct.
The tires are Pirelli P-Zero Nero M+S with 8K miles.
The car does not pull while braking, and drives straight with momentary "hands off" on the steering wheel.
Any thoughts?
Thanks in advance.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-15-2012, 12:52 PM
might want to check your wheel bearings for play, adjustment.
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 02-15-2012, 03:54 PM
ROW '78 911 Targa
timmy2's Avatar
Steering column bushing worn? Mitch Leland to the rescue?
Porsche 911 & Carrera Steering System - Page 5
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-15-2012, 04:40 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey Dr Gerry,
Buzzing, hmmm. I had buzzing too but is was the wiper/horn switch and ring. You see over time and use, the copper ring will create groves on the copper switch, when deep enough it will start rubbing against the plastic housing of the ring and start buzzing on turns or side to side motion. I removed and sanded the sharp ridges to a more rounded off feel and it fixed the buzzing.
If it is buzzing when driving straight, it could be one or both linkages in the steering column. Both of mine were sloppy as heck and it cause annoying vibration while driving straight. Swapped with an used good ones from 20th Street Auto and vibration is gone.
Hope it is one of these sollutions for you
If you like we can meet up in Southbay somewhere and I can verify for you :-P email me
Jim
'85 Carrera Targa
PCA/POC
Old 02-15-2012, 07:06 PM
Wheel Bearing Adjustment.
Thanks all for the inputs.
I'll have a look at the front wheel bearing play/adjustment this weekend
as per 401-12 of the Bentley, and post my findings if any.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-17-2012, 11:09 AM
"buzzing"
Subsequent to posting this thread, while searching for further possible leads.
I found this post:
Having the issue when changing lanes (left-right),
I pulled the L/F (driver's side) outer bearing, and found this:
Any thoughts on the cause?
And, as always, thanks in advance.
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-03-2012, 11:09 AM
Drop it again, in the trash can.
Larry
Old 03-03-2012, 12:40 PM
Bearing.
Larry
My very former wrench.......
1986 911 Targa.
Only in L.A.:
Old 03-03-2012, 12:44 PM
Among the other suggested items to visually inspect, look at the steering column and u-joint connection to the steering box. Besides mere visual inspection, yank and push and otherwise put force on the parts in question. Could reveal something loose, cracked or broken.
Sherwood
Old 03-03-2012, 01:15 PM
Wheel bearings.
Front wheel bearings it was.
All is quiet.
Thanks to all for the help.
Gerry
1986 911 Targa.
Only in L.A.:
Old 03-21-2012, 04:05 PM
dshepp806's Avatar
I found this post:
Gerry
GOOD ONE! Thanks for sharing Zimmy's stuff......
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-21-2012, 04:20 PM
dshepp806's Avatar
Now,..what the hey CAUSED that"-especially the "bend"....a bearing failure?
Thanks,
Doyle
Middle Georgia
Old 03-21-2012, 04:28 PM
Bearing failure.
Thanks,
Doyle
I have showed those bearings to several folks,
all just threw their hands in the air. "Weird".
The only conjecture, is that, at some time, the bearings were dropped.
Another conundrum.....
1986 911 Targa.
Only in L.A.:
Old 03-21-2012, 06:05 PM
dropping it wont do that. that damage is caused by the screwdriver when checking the washer for freeplay. its easy to grab the edge of the bearing if ur not careful.
look at the goofball in that video hackin away at the washer. his method of setting preload is absurd
Jason
81 SC
97 328is
Old 03-21-2012, 06:15 PM
Correct!
I deleted the link/video from my post.
Although for the 944 these might be a bit better:
http://www.youtube.com/watch?v=PjFY7-IHgvQ
http://www.youtube.com/watch?v=O2lUqvga0n0
1986 911 Targa.
Only in L.A.:
Old 03-25-2012, 08:33 AM
