Unsafe at any speed
Slow window fix
My power windows have been slow and grabby for about 10 years. Passenger side motor finally failed, so I decided to refurbish both sides.
Passenger side had a stiff main pivot in the regulator, and one of its arms was out of the window's track. Didn't get pics of that since it was nothing special. But I did take pics of the driver's side since it had a failure of the spring tensioner. I've seen this happen in other people's posts when searching this topic. The motor has to struggle a bit getting the window up without the spring assist (kind of like garage doors). The peg that holds that spring coil is some kind of non-ferrous pot metal that was peened into the slot in the middle of the regulator. Strange because it's holding a lot of tension, especially with the window down. ![]() ![]() So I used a combination of a stainless button head bolt and a coupler nut to recreate the peg. Loctite red makes it semipermanent. Had to use a button head for the low clearance between the regulator's arms. ![]() ![]() Cut to size and painted the cut end for rust protection. There, spring tension restored. ![]()
87 Carrera Coupe |
Unsafe at any speed
Irony in the slow window fix
The combination of corroded, chunked up window felts and stiff, malpositioned regulator killed the passenger side window motor. I didn't want to spend nearly $200 for a new stock motor (Sorry Wayne), so I took a chance on another cheaper Bosch window motor I found on eBay. It's listed for some Mercedes sedans from the '90's, but it looks nearly identical to the Porsche motor, including the right number of teeth on the gear. And it's only $65.
![]() Upon closer inspection, the castings are not identical. The mounting holes in the gear case (attaching the assembly to the window regulator) are taller in the replacement motor, and the male plug is on the wrong side of the motor. So I merely switched the actual motor from the newer unit to the old stock gearcase. Perfect fit, and the pinion gear turns smoothly. ![]() The irony fixing the slow, struggling window occurs because the replacement motor is not as fast as the stock unit. Now I'm not even sure that this replacement motor is a genuine Bosch product versus a Chinese knock-off. But it's running smoothly, and at a third the cost of the real deal, I can live with a slightly slower but healthy and smoothly functional power window. I was satisfied enough with the passenger window motor fix that I bought another motor to prophylactically replace the driver's side as well.
87 Carrera Coupe |
The Dude abides...
![]() One question, it appears from your photos that the spring tensioner, having lost its pot metal post, would have only rotated ~20 degrees until it rested on the far mounting post. Would that have caused significant loss in spring tension? Steve
Steve '03 Carrera 4S |
1987 Carrera
I worked on my Window regulator today as well. Are replacing the felt? How do you do that?
Ace123 1987 Porsche 911 Coupe |
Unsafe at any speed
Steve, if you look at the very first picture you'll see it closer to 100 degrees of travel before reaching the post. The spring tension at that far post's point was minimal. And that picture of me holding the spring in the second photo is about as far as I could push it myself. Those last few centimeters of spring movement are really strong.
Ace, the outer felt is held to the door frame with metal snaps. You can pry them out with a pick or small slotted screwdriver. The inner felt is a rubber channel that slides over the inner sill. Here's a pic of the driver's side felt, which was in much better condition than the passenger side, which crumbled into a pile of rust flakes during disassembly. ![]() I learned that a misaligned window frame may be another hindrance to smooth window operation, if it's putting undue pressure on the window glass. You can realign the window frame by loosening the bolts that hold it to the door. Here's a couple that hide under black rubber plugs. There's another down low on this side, and a couple more on the other (forward) side, as well as a couple accessed through the uncovered door panel. You can figure it out when you get everything apart. I loosened the bolts, then slid the window up and down and closed the door a few times to further loosen and knock everything into place. It may not be the right way, but it seemed to work for me. ![]()
87 Carrera Coupe Last edited by Nader; 03-10-2012 at 08:43 PM.. |
1987 Carrera
Yanks for the info.
1987 Carrera
How tough is it to replace the squeegee rubber part on the outside part of the window. Is it just held bt pressure? Is removal just prying it out? Where should the window be when I do it?
Pry it up. Doesn't matter what position the window is in.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
This is a great post, I now can fully understand why I found this piece floating around inside my door when replacing the speakers, and it also explains why the window moves so slowly!!
Can you tell me what size screw and coupler you used? I wanna swing by the hardware store on to grab these parts while I still have the door panels off. Any tricks or anything to removing that whole assembly? I can't even see the spring, so I'm assuming this all has to come out to fix it. Thanks! |
I found one of those in my door years ago but it was not broken. I guess I'll need to put it back!
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Unsafe at any speed
Apparently, this happens to the mighty 959s as well.
I used a 6mm screw and coupler. No reason you can't go with 1/4" if metric is harder to find. To remove the regulator, you have to first remove the window motor. And tape the window in the up position once you've detached the regulator from the window's bottom track. Or else it'll slide down and get in the way. Be patient in wiggling out the regulator. It's awkward with the parts dangling and stuff getting caught on the door innards. Good luck.
87 Carrera Coupe |
Member 911 Anonymous
My Compliments, Been meaning to tackle this on my passenger side window.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
What causes these problems are, Old felts,dry filthy regulators & frames out of adjustment & bent. Pull the frame out check for bends,clean all the tar & gue out of the channels. Replace the felts,clean the regulator & lube it,i use Aero Shell 5 & LPS 3. Make sure the window rail attached to the bottom of the glass hasn't moved or loose. Disassemble the motor,clean the gearbox & relube & clean the commutator with a fine scotch pad & check the brushes. If the brushes are worn,trash the motor. I have use this procedure on all my 911's,works every time . If its a clients car do all of the above,except you must replace the motor.
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
Good stuff. My passenger window has been slow so I opened it up and found this peg lying in the bottom of the door. I guess I know my next project. I'll order the window channel felt and do this next weekend... Way too nice today! Thanks!
One small tip is if you replace the door frame mount bolts make sure they are exactly the same length as the factory bolts. If they are a few mm longer they push on the door channel felt runners and you jam up the window operation giving you, slow windows. Great thread.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
Great thread!
The passenger window on my 87 Carrera coupe moves much slower than the driver's side window. Is this most likely a motor issue? When I roll down the driver's side window an inch or two something rattles inside the door. This only happens after the window has been lowered a few inches. Any thoughts on this mystery? Thanks.
---------------------------------------- 87 Grand Prix White 3.2 Carrera Coupe |
My passenger side window was slow and I cleaned up the felts which helped somewhat. Its still slower than the drivers side though. Is there a reason why the passenger side seems to suffer more than the drivers side?
Window Regulator...
Talk about timing... I was just ready to install my new re-upholstered door panels after replacing the door arresters when I read this post. I had cleaned out the bottom of my doors and found these parts, but couldn't figure out where they came from. Unfortunately now I know... So another "while I was there project".
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
This might help...'82 SC coupe with agonizingly slow passenger window.
1. The book really doesn't show when to remove/install the motor. I did it with the reg in the bottom of the door. 2. I put a new felt guide in the frame - don't glue the side pieces, only the top. I used 3M black weatherstrip cement. 3. Don't forget to grease the drive gear on the new motor. 4. Don't forget to align the frame for clearance to the body before you shut the door. 5. Grease the regulator wheels and their channels - be very careful that no grease gets on the weatherstrip inside the top of the door - you will never get it off the glass. Work clean, and wear latex gloves! When you slide the glass back into the door, be sure that it is spotless! And, yes, in a "race" between the driver and passenger window, even with all the new parts in the right side, it's still about one second slower, bottom to top, than the left side. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 08-03-2012 at 02:10 PM.. |
After reading this post and finding out that the coil spring post on both doors of my car had fallen out I removed the driver's side this afternoon. I looked up the regulator removal in Bentleys, but they didn't say to remove the "L" bracket on the forward lower window channel so you can remove the regulator.
I bought a 1/4-20 coupling nut and I already had a S.S. button head bolt of the same size. If the hole isn't big enough in the regulator plate I'll drill it out for the 1/4-20 bolt. I'll follow up after completing the work...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories Last edited by Mitch Leland; 08-03-2012 at 07:17 PM.. |
Thread Tools | |
Rate This Thread | |
