Engine weights
Can anyone out there tell me how much a 911 motor weighs- which motor? Heck I'll take any info I can get. A friend and I are having a debate about power output vs engine weight as to which motors are more efficient. Thanks!!
Street engines, stock? IN 2002, I'd guess something Japanese. No idea which. Back up 30 years or so, I'd guess either German or Italian?
Somewhere in the Midwest
When I picked up my '78 3.0 from the shipper, I asked them to put it on the scale, pallet and all. It came out to about 450 lbs. So the motor probably weighs about 425 lbs +/-.
The early (69-71) 911T engines weighed 176 kg / 387.2 lbs and the 911 E/S engines weighed 182 kg/400 lbs.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Irrationally exuberant
I weighed an 1989 3.2 with muffler and it came to 418# on the pallet. The pallet was 40# so the engine weighed 378lbs.
-Chris |
Crotchety Old Bastard
My California smogged 930 weighed in at a trim 529 pounds.
I like to bring this little tidbit up every time someone knocks the SBC conversion. Engine power to weight ratio? I'd vote motorcycle or anything supercharged/turbocharged.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Unregistered
Speaking of HP to weight ratio, the engine in my waverunner puts out 125 hp and I can pick it up and carry it around. I figure that is less that 1 pound per HP, that is going to be tough to beat.
Is that a 2 stroke or 4 stroke motor?
My Carrera 3.0 weighed ~#405 with cis/ssi no muffler and sachs clutch & p/p the M64 3.6 that replaced it weighed ~425 with motronic/ssi no muffler, centerforce clutch & p/p sans ac
A 2.7 with cis/ssi no nmuffler, sachs clutch & p/p was ~390# A 3.2 with Motronic/oem exhaust with muffler,ac, stock clutch & p/p weighed ~440# all were weighed with electronic corner balance scales
