OsoMoore's Avatar
Importance of Leakdown and Compression Test in PPI
I'm getting a PPI done, and the company (European Performance in Raleigh, NC) doesn't do leakdown or compression tests by default, but I could request it.
The car I am looking at has a good history and a rebuild about 40K miles around 9 years back, done by a well-known pelican. How important is it to get leakdown and compression? I don't mind paying for it if its necessary, but saving money is always good - more funds for tools later.
Old 03-29-2012, 08:26 AM
without compression and leakdown, you have no idea as to the actual health of the engine. even if its been rebuilt by a reputable person, things do go wrong. Worth the $'s
Old 03-29-2012, 08:30 AM
Northern Motorhead
wildcat077's Avatar
You mention saving money is good ... by doing a leakdown and compression test you could save yourself a LOT of money should the engine have any issues before you buy the car
Definitely a wise investment !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-29-2012, 08:41 AM
what kind of PPI is that??
206 637 4071
Old 03-29-2012, 09:02 AM
OsoMoore's Avatar
Hmm, I re-checked my handy PPI link and noted the following:
25. If no broken studs/pulled studs are found proceed with a leak down test. (Although some disagree, I feel that a compression check on a 911 is often useless, while a leak down test is invaluable. A knowledgable mechanic can use the leak down test to assess the condition of several important engine components, like valves and rings.)
I'll make sure to have at least the leak down test.
Old 03-29-2012, 09:15 AM
Chain fence eating turbo
I LOL'd. What is the point of NOT doing them in a PPI? Those are the most important checks and if not done will probably cost the most money if there is an issue.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-29-2012, 10:19 AM
Mo money = mo parts
Yeah, other than a screwed up tub, a bad motor will have the biggest bite.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 03-29-2012, 10:23 AM
When I recently had a PPI done for a Carrera, the mechanic didn't think the leakdown was all that vital, because it doesn't tell you anything about worn valve guides, which is the weak link on the 3.2 motor.
I know Peter Zimmerman writes in his book that the leakdown is essential, but I wonder if compression check and an inspection of the valve guides does not give a sufficiently good sense of the overall health of the motor?
How much extra does a leakdown add to the PPI?
Old 03-29-2012, 10:57 AM
Friend of Warren
I would get another mechanic.
Kurt V
Old 03-29-2012, 11:13 AM
<insert witty title here>
Christien's Avatar
Maybe $1-200? It's a no-brainer, IMO. Most PPIs I've had done run $250-400, including compression and leakdown. I can't imagine doing otherwise on a 20+ year old engine.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 03-29-2012, 11:20 AM
Yes
Old 03-29-2012, 11:24 AM
leakdown tests don't tell you if the guides are worn, but they show the results of worn guides, ie: worn valve seats. valves tend to be thrown onto one side of the seat when the the guides are sloppy, which wears that area more than the rest of the seat, so, out of round/eccentric seat plus round valve = higher leakdown results. 911s don't burn valves much at all. the seats wear out instead.
206 637 4071
Old 03-29-2012, 11:51 AM
dshepp806's Avatar
Get both leakdown and compression tests. JW and others have often mentioned why, as they test different things, actually.
Any mechanic who knows these cars, knows that (period).
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-29-2012, 02:27 PM
