Plavan's Avatar
Fuchs are getting old- Check them for cracks.....
I was bolting this a 15x8 Fuch up on my race car and look what I found.....
These wheels have only been on the track maybe 4 weekends (I have two sets). These were not even my curb hopping set. Be safe and check regularly.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 03-30-2012, 05:51 PM
ratpiper71T's Avatar
Wow, good catch. Out of curiosity, have these been refinished in anyway?
Old 03-30-2012, 07:58 PM
Plavan's Avatar
When I recieved them, they were just old- I bead-blasted them for the correct RSR texture then just painted them. (RSR Economy Finish). The other 3 I have are fine- I'm just going to check them everytime I touch them.
Old 03-30-2012, 08:12 PM
Wash. State
nesslar's Avatar
Are those real "forged" Fuchs"? They look cast.....
Old 03-31-2012, 01:38 AM
Plavan's Avatar
Yep- real Fuchs. I would not race on fakes.
Bead blasting them gives them the RSR texture you see.
Old 03-31-2012, 04:30 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Its weird that the crack starts from the center bore and moves inward. Intuitively, i'd think it would start at the lug hole and move outward?
Kevin L
'86 Carrera "Larry"
Old 03-31-2012, 05:55 AM
300hp 1800lbs is the goal
pksystems's Avatar
I picked up some used fikse centers, and found similar cracks in the spokes of one.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 03-31-2012, 06:11 AM
cmpski's Avatar
Can that be repaired?
Old 03-31-2012, 07:50 AM
Wash. State
nesslar's Avatar
I see. I've not seen such a close-up of the RSR finish. And wow...good eye for catching that!
Old 03-31-2012, 09:15 AM
Rescuer of old cars
Arne2's Avatar
Looking at this with 20+ years experience in tire and wheels service (prior career), to me it looks like stress from the hold-down cone of an old Coats tire changer. Probably not recent stress, either. More likely from back in the '70s & '80s.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 03-31-2012, 09:28 AM
safe's Avatar
Only if your going to use them for peaceful Sunday cruises.
Magnus
Old 03-31-2012, 02:54 PM
I ROC!
mpeastend's Avatar
I've heard and seen cracks like these but I can't recall ever hearing about a Fuchs actually failing? Anyone have pics / info?
There was the case of Matteo's Lindsays that came close to failure on a track day outing in England. He was cornering and heard noises...turned out the rim center was so badly cracked, the entire center was flexing and the rim was rubbing on the calipers. He was really lucky it didn't fail at that moment.
It started some discussion on the prior life/load cycles that the donor 6x16 wheels had before being cut out and welded up by Lindsay racing. I have a set for my IROC clone & check them often but would like to get a modern set to use on the track like the Zuffenhaus ones.
I'd include a link and/or pics he posted but any search for Matteo's thread came up empty. Don't know why. I remember he posted pics of them...pretty badly cracked. Lucky, he was through enough with that car!
Old 03-31-2012, 10:39 PM
haycait911's Avatar
is it possible that was caused by trying to hammer in a cap crooked, or wrong caps?
Old 03-31-2012, 11:19 PM
Plavan's Avatar
Unlikely, plus We don't run with caps.
Old 04-01-2012, 07:22 AM
Plavan's Avatar
I will not try and repair it. The wheel will now become a Wall Clock, some type of Art, or a cool hose reel.
Old 04-01-2012, 07:27 AM
KTL KTL is offline
Schleprock
KTL's Avatar
cstreit had some crack like this a number of years ago.
Fuchs wheels cracking?
Now that I think about it, it makes sense to start at the center. The wheels are hub-centric and the center bore is what secures/supports the wheel to the axle. The lugs of course hold it tight. So the lugs are like secondary support?
Kevin L
'86 Carrera "Larry"
Old 04-02-2012, 07:26 AM
Administrator
Jack Olsen's Avatar
A Fuchs wheel has a finite lifespan, and that lifespan is measured in the amount it has been forced to flex more than chronology.
Every time the metal is stressed adds to the cumulative effect.
Old 04-02-2012, 07:47 AM
Craig T's Avatar
Chad, during the POC Spring Mountain event in 2010 a time trialer had a catastrophic Fuch failure in Turn 2 (high 3rd gear turn). The wheel broke completely off at the spokes. The left over star made a nasty cut in the track. That event touched off some controversy with the tech shop and a closer exam of the Fuchs on POC cars. I believe at least one other cracked Fuch was found.
Craig T
I like this thought on the root cause, something to the watch when getting tires changed, e.g. no reason to hammer the wing nut pushing the cone, a firm push by hand should hold it.
Sold: 1989 3.2 coupe, 112k miles
Old 04-02-2012, 08:07 AM
