I have a similar crack (~1 inch), starting at one spoke close to the outside of the wheel.
7x15 forged original Fuchs, fully polished. Have them since ~8 years and discovered it after a 600mls tour through the alps. jens |
Rescuer of old cars
Those old tire changers broke the beads by applying a bunch of force from the side, while the wheel was retained by the cone through the center hole. The stress was all concentrated on the edge of the center, exactly where this wheel is cracked. Modern changers do not apply this force against the center.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max Sluiter
This. Aluminum fatigue fails after cyclical loading no matter how little stress it sees (unless it is zero). It just takes longer to fail with less stress.
Schleprock
I'd be willing to bet that the lug areas are more dinged up than the hub area. The studs dish out more abuse on the lug holes than the hub gets from the wheel carrier.
The tire changer theory is a very good one! I'm not saying the metal doesn't have a finite life. I'm just agreeing that those older tire machines are brutes and the leverage they can place on the wheel is an incredible amount of force.
Kevin L '86 Carrera "Larry" |
Max Sluiter
Yeah, but the ball seat area seems pretty good.
