'86 3.2: Bouncing idle after pushing in clutch.
I have an '86 3.2 with about 66,000 miles on it. Occasionally, if I press the clutch in to come to a stop, the idle starts bouncing between say 800rpm up to 1200rpm. The frequency of it is about once per second or maybe a bit less and goes away if I give it a bit of throttle. The car runs great otherwise with no issues.
It is due (well, past due) for new wires, cap and rotor but the plugs are new as of last November. Any ideas?
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS Last edited by PabloX; 04-19-2012 at 12:41 PM.. |
Since you seem to be the master of the search engine, I also have an occasional, random click from behind the gauges. It sounds like it's from a relay. What search terms would I use for that oh master?
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
Chain fence eating turbo
![]() Yes, there's is lots of threads on this with lots of different solutions that hasn't been a one-size-fits-all.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Give it a few hours and the motor heads will chime in "
Everyone is at work or prepping for Hershey... |
The problem with this problem is that nobody has ever come up with the end-all and be-all solution. A ton of us have had this issue, yet it will sometimes be fixed, only to rear its ugly head and come back. Start by unplugging your O2 sensor.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
muck-raker
common "hunting idle" issues: bad O2 sensor, dirty or bad Idle Control Valve, and/or improper air/fuel mixture. Start with the tune up issues, you need to replace that stuff anyways.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
I'm more used to modern cars. With this one, are there any downsides to not plugging the O2 sensor back in?
Don't unplug the O2 sensor. Find the root cause, which could be low fuel pressure, but most likely you have a vacuum leak. You'd fix this by tightening the hose clamps, replace cracked hoses, and tighten or replace the intake manifold gaskets/ bolts.
Do U have the original single wire cht sensor? Asking because of the low mileage of your car. If its determined to be your problem I have a like new updated 2 wire sensor for $50.
Basically, I can induce the effect by quickly blipping the throttle. If I let off more gently, it's fine.
If I go to the two wire version, do I need to run a new cable to it?
Nope, plug-and-play
The O2 Sensor for your car is actually a 3-wire. 2 wires are for heat, and the third obviously the dme feedback wire.
Blipping the throttle does not work to correct vacuum leaks. The reason the idle is hunting is that the DME is trying to maintain lambda with false air data from the afm, which is impossible. |
Thanks.
No, find and eliminate vacuum leaks.
You may want to wipe the oil from inside the intake boot if you have the AFM out to test it. You can clean and check the operation of the ICV too. |
I forgot to report back on this thread. I replaced the O2 sensor a couple of months ago and so far, the problem hasn't come back.
Thanks for giving your fix. Lots never report back.
Did you clean the idle valve too? |
Rescuer of old cars
My 3.2 does this, but only on cold start. Will settle to normal idle after 15-20 seconds. Never does it warm. PO replaced the O2 sensor a few months (read as a couple hundred miles) before I bought the car. Since it never does it warm, I'm assuming that it's not a vacuum leak. I suppose the new O2 sensor (correct Bosch) could be bad, maybe contaminated during install. Haven't dug into it in depth yet.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
I did inspect the idle valve and it didn't look too bad, so I didn't clean it. Also, I didn't want to do both at the same time so I could deduce what the correct fix was. However, I do plan on cleaning it anyway as the idle can be a bit rough when cold.
