'86 3.2: Bouncing idle after pushing in clutch.
I have an '86 3.2 with about 66,000 miles on it. Occasionally, if I press the clutch in to come to a stop, the idle starts bouncing between say 800rpm up to 1200rpm. The frequency of it is about once per second or maybe a bit less and goes away if I give it a bit of throttle. The car runs great otherwise with no issues.
It is due (well, past due) for new wires, cap and rotor but the plugs are new as of last November.
Any ideas?
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 04-19-2012, 11:00 AM
Originally Posted by PabloX View Post
I have an '86 3.2 with about 66,000 miles on it. Occasionally, if I press the clutch in to come to a stop, the idle starts bouncing between say 800rpm up to 1200rpm. The frequency of it is about once per second or maybe a bit less. The car runs great otherwise with no issues.
Any ideas?
As the most common problem affecting the 3.2 engine, the answer might be concealed inside the "Search this Forum" key.
Old 04-19-2012, 12:23 PM
Yes, I did search first. Since posting this though, I've since tried other terms which didn't immediately occur to me (like "hunting idle"). However, the posts I've found don't describe the exact problem I'm having, though they give me something to try.
Since you seem to be the master of the search engine, I also have an occasional, random click from behind the gauges. It sounds like it's from a relay. What search terms would I use for that oh master?
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 04-19-2012, 12:38 PM
Chain fence eating turbo
Rennlist has the "DAFS" emotocon. It means Do A F-ing Search.....
Yes, there's is lots of threads on this with lots of different solutions that hasn't been a one-size-fits-all.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 04-19-2012, 12:39 PM
Give it a few hours and the motor heads will chime in "
Everyone is at work or prepping for Hershey...
Old 04-19-2012, 12:58 PM
The problem with this problem is that nobody has ever come up with the end-all and be-all solution. A ton of us have had this issue, yet it will sometimes be fixed, only to rear its ugly head and come back. Start by unplugging your O2 sensor.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 04-19-2012, 01:41 PM
muck-raker
kidrock's Avatar
common "hunting idle" issues: bad O2 sensor, dirty or bad Idle Control Valve, and/or improper air/fuel mixture. Start with the tune up issues, you need to replace that stuff anyways.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-19-2012, 01:49 PM
Thanks, the idle control valve and O2 sensor were my first items to check.
I'm more used to modern cars. With this one, are there any downsides to not plugging the O2 sensor back in?
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 04-19-2012, 01:54 PM
Don't unplug the O2 sensor. Find the root cause, which could be low fuel pressure, but most likely you have a vacuum leak. You'd fix this by tightening the hose clamps, replace cracked hoses, and tighten or replace the intake manifold gaskets/ bolts.
Old 04-19-2012, 02:13 PM
Do U have the original single wire cht sensor? Asking because of the low mileage of your car. If its determined to be your problem I have a like new updated 2 wire sensor for $50.
Old 04-19-2012, 02:15 PM
If it were a vacuum leak, would it settle down by giving it a bit of throttle and letting off gently?
Basically, I can induce the effect by quickly blipping the throttle. If I let off more gently, it's fine.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 04-19-2012, 04:33 PM
Good question, I'll check this weekend.
If I go to the two wire version, do I need to run a new cable to it?
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 04-19-2012, 04:34 PM
Nope, plug-and-play
Old 04-19-2012, 04:53 PM
The O2 Sensor for your car is actually a 3-wire. 2 wires are for heat, and the third obviously the dme feedback wire.
Blipping the throttle does not work to correct vacuum leaks. The reason the idle is hunting is that the DME is trying to maintain lambda with false air data from the afm, which is impossible.
Old 04-19-2012, 05:38 PM
So clean the air flow meter? Sounds like I should clean the idle control valve while I'm in there.
Thanks.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 04-19-2012, 05:51 PM
No, find and eliminate vacuum leaks.
You may want to wipe the oil from inside the intake boot if you have the AFM out to test it. You can clean and check the operation of the ICV too.
Old 04-19-2012, 06:04 PM
I forgot to report back on this thread. I replaced the O2 sensor a couple of months ago and so far, the problem hasn't come back.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 08-06-2012, 03:45 PM
Thanks for giving your fix. Lots never report back.
Did you clean the idle valve too?
Old 08-06-2012, 04:13 PM
Rescuer of old cars
Arne2's Avatar
My 3.2 does this, but only on cold start. Will settle to normal idle after 15-20 seconds. Never does it warm. PO replaced the O2 sensor a few months (read as a couple hundred miles) before I bought the car. Since it never does it warm, I'm assuming that it's not a vacuum leak. I suppose the new O2 sensor (correct Bosch) could be bad, maybe contaminated during install. Haven't dug into it in depth yet.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 08-06-2012, 04:31 PM
No problem. Hopefully this builds the body of knowledge.
I did inspect the idle valve and it didn't look too bad, so I didn't clean it. Also, I didn't want to do both at the same time so I could deduce what the correct fix was. However, I do plan on cleaning it anyway as the idle can be a bit rough when cold.
2016 VW Golf R
2021 Kia Telluride
2020 BMW R1250RS
Old 08-06-2012, 05:24 PM
