83 911 Production Cab #10
JJ 911SC's Avatar
Which Oxygen Sensor?
For an 86 3.2, cat delete, SSI and SW chip 93 Octane.
Who Will Live... Will See
Old 05-07-2012, 06:49 PM
JJ 911SC's Avatar
Anybody?
Old 05-09-2012, 06:43 AM
Diss Member
Quicksilver's Avatar
Stock Bosch.
The "cat delete, SSI and SW chip 93 Octane" part makes no difference. The O2 sensor is there to tell the computer when the mixture is at "lambda". That doesn't change with modifications, it is simply a function of air/fuel ratio.
See -> Graphs
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-09-2012, 06:53 AM
Member 911 Anonymous
DRACO A5OG's Avatar
You can use a 1996 Ford Taurus O2S, same exact fitment with 3 wires, just cut and splice. Much cheaper the OEM spec. it is also BOSCH
'85 Carrera Targa
PCA/POC
Old 05-09-2012, 09:28 AM
JJ 911SC's Avatar
Thanks guys
I got a new (fitted less then 1000 miles ago) Bosch 13924 Oxygen Sensor, OE Type Fitment but someone mentioned that I maybe running a bit rich (very black muffler pipe inside also less then 1000 miles), so I started to wonder...
Old 05-09-2012, 09:46 AM
cashman's Avatar
I just installed the 13924 on my 89 3.2. I don't think that would be the issue. I checked the voltage by jumping from the sensor to the harness. My voltages while connected was .5V. That tells me the dme was doing its job. When disconnected the sensor had varying readings. I may be wrong but that's my logic.
Maybe the male side is not making contact in the female side?
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 05-09-2012, 10:02 AM
muck-raker
kidrock's Avatar
rich running condition may not be due to your O2 sensor, it could also be an incorrect air/fuel mixture.
IIRC, the sensors on the SC's had crappy connectors. Have you checked all your connections and tested with a VOM?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-09-2012, 10:12 AM
ivangene's Avatar
Jim...do you have the info needed to do the splice (which wire...where)
this is great to know! I might try this
Ed M
86' Coupe
Old 05-09-2012, 11:09 AM
DG624's Avatar
Draco, how much cheaper?
Old 05-10-2012, 02:15 PM
JJ 911SC's Avatar
Originally Posted by kidrock View Post
... IIRC, the sensors on the SC's had crappy connectors...
Stone
Not on this Franken...
JJ
Old 05-11-2012, 04:30 AM
muck-raker
kidrock's Avatar
yeah JJ, I forgot about your 3.2....sorry about that.
Honestly, just my opinion....Pelican has a "plug-n-play" Bosch replacement for our 3.2's, but it's twice as much as the "universal" Bosch replacement.
I used the universal replacement a few years ago. It involves splicing into the existing connector. I feel I did a good job, but after the fact, I just don't feel comfortable with all the splicing involved. Why? Most electricians cringe when you use a lot of splicing when doing an electrical job, I guess the opinion is that you just have that many more "breaks" in your circuit.
I never pass smog, but I also don't have any idle issues. Maybe one of these days I'll do a quick disconnect while the motor is running and warm, just to see if there's any change in the idle. That would probably tell me a lot.
Just my .02 cents, JJ....carry on.
STONE
Old 05-11-2012, 01:13 PM
HFR_Racer's Avatar
Be careful guys.. All O2 sensors for various applications are not setup with the same base sensing range.. Example... Pre-2004 Subaru is ~5 ma sensing where as post 2004 is 0.5 ma at A/F= 18.
Simply taking a sensor off another OE model may not give you the same end result.
Old 05-11-2012, 02:41 PM
I've always wondered about the splices. The voltage generated by the sensor is not much, less than 1V DC, so I'd think any change in the resistance of the wire would have an effect on it. I'd wonder what some of the splices I've seen would do to the wire resistance...
What's the cost of a correct O2 sensor, less than half a cent a mile?
JR
Old 05-11-2012, 03:09 PM
grateful user
don gilbert's Avatar
Bosche one wire at o'riellys, 20 bucks.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-11-2012, 03:10 PM
JJ 911SC's Avatar
Is that like a Rotex watch for 10 bucks on Canal Street in NYC?
Old 05-11-2012, 04:19 PM
DRACO A5OG's Avatar
$40, at FLAPS, I doubled checked with the assistance of a DME guru we all know and love. I would have never done that otherwise.
Simply cut and solder/heat shrink, for us 3.2's try very hard not to crumble the OEM sensor connector if at all possible. If not no biggy just get a female/male bullet connector. I used a 3/8" rubber hose to help it mount on the OEM holder
'85 Carrera Targa
PCA/POC
Old 05-11-2012, 08:53 PM
