How to Fill A/C compressor stand hole
I've removed my A/C compressor and stand (what a bear!), and now have a a small rectangular hole where the stand went through the tin. Should thgis be filled, and if so, how could I do it. I'm thinking of the heater blower delete next, so maybe these could segue somehow. Any ideas? TIA,
Don Ivey
'87 Carrera
'13 Scion FR-S
My Porsche tinks, therefore I am.
Old 05-22-2012, 03:06 PM
Bump. Any help?
Don Ivey
'87 Carrera
'13 Scion FR-S
Old 05-23-2012, 04:41 AM
Josh D's Avatar
Maybe a picture would help? I can't think off the top of my head where the compressor bracket mounts below the tin.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 05-23-2012, 07:39 AM
ROW '78 911 Targa
timmy2's Avatar
Small rectangular hole, cut a small piece of sheet metal, paint it and silicone it for now. When engine is out have it welded if you need to for cosmetics.
Old 05-23-2012, 08:06 AM
Senior Advisor
James Brown's Avatar
it won't effect the cooling if that is your question. the small tin is the best bet.
08 Cayenne Turbo
Old 05-23-2012, 08:11 AM
gtc gtc is offline
abides.
gtc's Avatar
Are you talking about the tin down near the crank pulley? I didn't worry about it.
Graham
1984 Carrera Targa
Old 05-23-2012, 08:12 AM
Actually, that was what I was concerned about. I should have asked it that way, as I'm ok with cutting a piece of tin and attaching it. Thanks,
Don Ivey
'87 Carrera
'13 Scion FR-S
Old 05-23-2012, 01:39 PM
Cooper911SC's Avatar
I cut out a piece of sheetmetal to fit and drilled holes to utilize the adjacent M6 tapped hole in the chain cover and the nut on the sheetmetal. Sprayed it satin black to match. Just need two more of the bolts for the engine tin.
Cooper
Old 05-24-2012, 07:00 AM
