Help! Wevo shifter install problems!
Guys, I can't seem to be able to remove this effen Nut from the shifter housing assembly....is there a trick to this?!?
![]() Alex
Alex '80 911SC Targa '06 997 C4S Coupe - SOLD '07 997TT Coupe |
Senior Advisor
it's effing tight! it will pop when it breaks so be aware
08 Cayenne Turbo |
88 911 cp
looks like it will take a thin wall socket to engage all the way. You could grind the OD of a socket so it fits down in the nut clearance flat. But dont make it so thin it cracks when torquing.
88 Carrera 3.4 smile making fun mobile |
Try to tight the screw on a vice , and move the body to unscrew.
I've proceeded like this , i had the same problem.
LIGHTER = FASTER !!! |
I read a hint in one of the short shifter install tech articles on the forum. It said that you should loosen that nut while the shifter housing is still bolted in the car. I did it that way on my car with no problem. You might just bolt the housing back in, instead of trying to hold the housing in a vice or the like.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Phil
78 911 SC 89 Range Rover 91 318IS 95 Ducati 916 86 Cagiva Elefant 5 bicycles |
uwanna and phiba, yes that worked! I re-installed the housing with the three 6mm allen bolts and it finally gave way! Who the H**l did they hire to torque that nut on....ARNOLD!!!
Cheers!...on to the next step! Alex
Retired, finally
Maybe it's the length of time the nuts and bolts have been torqued, leading to some kind of metal to metal adhesion? I don't know, but I do know that I have been getting close to getting a hernia getting some loose on my '84 Targa.
According to the book, the transmission fill plug is supposed to be torqued to 17.6 ft-lbs if I remember correctly. Ha! It took a 100+ ft-lbs to get that sucker loose. I actually used a 1/2" torque wrench set on max, because my 1/2" breaker bar only has a 18" handle. And after all that, it didn't need any fluid.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
SiberiaDVM, I hear ya! I went to change my gear oil on the 915 last year and had to go out and buy an impact wrench to get that sucker off. I was concerned that with my longer ratchet, I was slowly "stripping" the inside thread of the plug, as I kept "slipping"! Oh, well, taking off wheels for future jobs will be easier, so it's money well spent in the end!
