Ambitious Outsider
sabeo.m's Avatar
SC rear valence mod (RSR Style) help
Guy's I'm going to be swapping out my single out Dansk for a dual center RSR type muffler, I understand that I either need to modify (cut) or completely remove the lower rear valence. If someone did this to their SC, any tips or pictures would help me out a lot. I did a search, but most of the pictures with this set up are on earlier 911's.
Regards.
1988 3.2 Cab
2005 997.1 C2S
Old 05-31-2012, 05:23 PM
Formerly known as Syzygy
Canada Kev's Avatar
Not mine, but here's one that I got from here a while back. And you will have to modify or remove the rear valence.
Kevin
Old 05-31-2012, 05:32 PM
Northern Motorhead
wildcat077's Avatar
That actually looks pretty good on a G50 Carrera,i would be very curious to hear what it sounds like !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-31-2012, 06:28 PM
Mitch Leland's Avatar
Rear valance...
Sabeo, I'm not sure if your rear valance is any different than my "84"? Rather than cutting on my original valance I bought a F/G reproduction from Raly8 that had no cut outs. I did the cut outs myself... I had the muffler mounted and I took a manila file folder and made a pattern of where the pipes came out. I used the valance mounting holes to locate the pattern. I have about 3/8" clearance around the pipes and so far I've had no burning of the paint.
The biggest problem you might get into is removing the philips head bolts from the valance. In my case I had case harden no. 6 mm philips cheese head bolts. I think there's 5-6 mounting bolts, 4 came out easily, but the other 2 had to be hammered on with a coal chisel. The problem is the aluminum bumper and the steel bolts which creates galvanic action.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 05-31-2012, 07:18 PM
Crotchety Old Bastard
RarlyL8's Avatar
Here is our custom valance with our S muffler and GT3 muffler.
Old 05-31-2012, 07:43 PM
Ambitious Outsider
sabeo.m's Avatar
Excellent guy's, thanks for the help! I just checked out Rarelyl8...
1988 3.2 Cab
2005 997.1 C2S
Old 05-31-2012, 10:15 PM
I'd love to see more of this if you have them Kevin.
Old 06-01-2012, 03:54 AM
Canada Kev's Avatar
Sorry, I don't. I just saw this one day in a thread here somewhere and thought I'd keep a copy of it because of the muffler tips or the bumper. I try to keep interesting pics for later reference. I can't even say which inmate this car belongs to.
Kevin
Old 06-01-2012, 05:01 AM
There are three things you need to do. The first is to cut the hole (or holes) in the valance for the exhaust tips. The second thing is to extend the left side of the valence to fill in the original muffler hole. The third thing is to modify the left rear quarter panel extension, where the original exhasut hole was, to mirror what the right side looks like.
JR
Old 06-01-2012, 06:02 AM
toddu's Avatar
Originally Posted by RarlyL8 View Post
What is this decklid/wing combination? I dont' think I've ever seen a wing grafted on like that....
Todd
'81 SC
Old 06-01-2012, 06:41 AM
Dang. I'd like to see it from other angles. I have the same engine cover and Fuchs, but keep kicking around the idea of IROC bumpers. The fact that it has a sweet muffler helps.
Old 06-01-2012, 08:16 AM
Ambitious Outsider
sabeo.m's Avatar
JR
Thanks JR, I think if I get the complete valence from rarelyl8 that will solve my problem.
1988 3.2 Cab
2005 997.1 C2S
Old 06-01-2012, 11:00 AM
Ambitious Outsider
sabeo.m's Avatar
Guy's, I might just remove the valence and leave it be... I found this picture of a SC with no lower valence. I think I can get use to that set up until I buy an aftermarket one to fill with holes! I don't want to modify my factory valence... RSR muffler on its way!!
1988 3.2 Cab
2005 997.1 C2S
Old 06-01-2012, 11:03 AM
Mmmmmmmmmm. SCRS!
Where did you find that picture? I need a copy.
Brendon
80 911SC "Weissach"
77 930 (in pieces)
Old 06-01-2012, 03:03 PM
Ambitious Outsider
sabeo.m's Avatar
Originally Posted by brendon View Post
Mmmmmmmmmm. SCRS!
I found the photo right here, random 911 picture thread. Page 477
1988 3.2 Cab
2005 997.1 C2S
Old 06-01-2012, 03:24 PM
Ambitious Outsider
sabeo.m's Avatar
Got it on! I cut the center valence, muffler fits perfect. I'm glad I did this swap, this muffler sounds awesome with my SSI's! Only thing to do is touch up the valence with touch up paint.
1988 3.2 Cab
2005 997.1 C2S
Old 06-13-2012, 11:48 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Your license plate sticker is expired......
Just watch your ankles when walking around the car. Those tailpipes look as dangerous as the tow hooks on my racecar that I constantly whack myself on!
Kevin L
'86 Carrera "Larry"
Old 06-13-2012, 12:52 PM
Ambitious Outsider
sabeo.m's Avatar
LOL, new sticker on the way! Yup pipes are a bit long...
1988 3.2 Cab
2005 997.1 C2S
Old 06-13-2012, 01:06 PM
Guardsred911's Avatar
sabaeo.m,
Any issues with scorching the bumperette's with your set up?
J
911 SC - 1980
911 S - 1977
Old 02-15-2013, 08:24 AM
I did this on my car when I got a GT3 style box. I bought a used valance and cut the right hand end off it after some measuring. I then welded it onto the left hand side of my existing one, the shape, radius etc is perfect and once painted it looks like a factory fit. Only thing left to do was cut out a bit of the centre section for the new pipes.
Easy!
Ian
Old 02-15-2013, 01:25 PM
