Missing Sway Bar 911SC 3.0 1,980.
Hello everyone.
Would like to get feedback from you all to make this a nice project car.
Just bought a 911SC 3.0 1,980. My first POR-shuh. I would like to fix it really nice for street daily use but I want the feeling of a real bad-a.....; fine piece of machinery!!!
Working it one-stage-at-a-time. Funds are limited but not necessarily unrealistic.
Need advise.
We are missing the rear sway bar and before I purchase an original PP I wonder what choices I have to make it; tight and a good feel driving it.
Would like to upgrade as much as possible by sections and in this case starting with the rear suspension.
Mounts,
Torsion bar
Sway, etc, etc...
I am looking for excellent handling. Little racer, maybe?Help!!!!!!!!
I already done one quite a handful of upgrades recommended by Wayne R. Dempsey book 101 Projects for your Porsche 911 and I want to go all the way or no-way.
Your comments before hand greatly appreciated.
Old 06-22-2012, 05:50 AM
Max Sluiter
Flieger's Avatar
Most will reccommend the WEVO mounts but reinforced factory ones work too (additional reinforcing sheet metal that you put on there). Tarett anti-sway bars are my preference.
Old 06-22-2012, 12:57 PM
Thank you Max. I am looking into it. I have written to Tarett to see what they recommend
RSR or
Regular.
22mm or
19.3mm
but I wonder; if my mounts are still good (not broken) should I replace them?
or will they work with the Tarett?
Thanks for your feedback
Old 06-23-2012, 05:11 AM
petevb's Avatar
First, someone should mention that you want to be careful upgrading the rear suspension without doing the front. If you do the car may be dangerous. So you need to come up with a plan for your entire suspension, then work towards it in careful stages if that's what your budget demands. Some ideas of combinations that work well:
ELEPHANT RACING Suspension Packages for Porsche 911/912/930
Smart racing used to make a quality swaybar... I understand those products are still available through other sources?
The issue with the factory mounts is that they were never designed for stiff rear swaybars, and can fail if you upgrade the swaybars without addressing them.
69 w 997 GT3 3.6L
Old 06-23-2012, 05:50 AM
My car came this way so I'm no expert discussing stock to modified, but here's what's on my car. It's a Weltmeister adjustable 19mm rear sway bar. It has mounts that are attached to the torsion tube with large U-bolts. Maybe one of the resident experts can chime in on this bar vs. stock.
Mounted to Torsion Bar Tube:
Ends are adjutable:
Old 06-23-2012, 11:54 AM
Laneco's Avatar
I have never seen a swaybar setup like that one in the above post. Is that what a Weltmeister adjustable looks like?
angela
Hello
Old 06-23-2012, 02:02 PM
Petevb; you have given me a rude-awakening
Tidybuoy great pictures, thanks.
Angela thanks for your post.
You guys are awesome. Thanks for the info, I little set-back here now that I realize what needs to be done and I definitely want it done the right way or no-way.
I think that for now I am going with original PP for the time being until I have a budget set-in mind for the total suspension upgrade.
Many, many thanks to all of you for your advise and posts.
Many thanks for your time and sharing your thoughts. Keep-it-up!!!!!!
Old 06-24-2012, 06:34 AM
