Question on Pully Size - for increasing cooling
I've read somewhere on this site that you can aid cooling by changing the size of the pully.
My question are: 1) which pully gets changed - top or bottom 2) what is the stock size and what is the new size (I want to check to see if this has already been done). Thanks............Vern |
Use the 77 to 79 crank pulley and the 80 to 89 fan and pulley half and a 9.5x725 belt of the 77 through 79 911.
Bruce |
The small fan pulley sizes are 3.125" or 3.25" (80 vs. 83 mm). The pulleys consist of "pulley-halves". You can't simply change one fan “pulley-half” without also changing the other "pulley-half".
1965-74/75.. 110 mm crank pulley..95 mm fan pulley 1976-77... 130 crank...83 fan 1978-79....130 crank... 80 fan 1980-89.....120 crank....83 fan for fan sizes / blades / air flow: 1965-74/75....245 mm / 11 blade... 1.3:1 ratio..1390 liters air/sec 1975/76- 77.....245 / 5 blade.......1.8:1 ratio....1265 l/sec 1978-79...........226 / 11 blade ...1.8:1 ratio...1380 l /sec 1980-89.........245 mm / 11 blade...1.67:1 ratio...1500 l/ sec fan belt sizes: 1965-75....9.5 x 710 1976-77.....9.5 x 725 1978-79....9.5 x 725 1980-on.... 9.5 x 710 BTW....aftermarket will sell fan belts at 9.5/10 x 710 as being "equal" to 9.5. Don't buy it. There have been reported problems with this. If possible, buy from dealer or Pelican and ask for the right size. Early 911 245 mm fan with 1.3: 1 pulley ratio 1390 ltr/sec @ 6100 rpm 1976-77 five bladed fan with 1.8:1 pulley ratio 1265 ltr/sec @ 6000 rpm 1978-79 226 mm fan with 1.81:1 pulley ratio 1380 ltr/sec @ 6000 rpm Fan Tip Speeds: diameter (mm) rpm pulley ratio speed (ft/sec) early 911 245 6100 1.3 334 76-77 5 blade 245 6100 1.8 462 SC 226 6100 1.8 426 930 245 6100 1.68 431
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Does anyone know what length belt for an early crank pully (110mm) and a 78sc (80mm) fan pulley? Thanks, Mark
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
Perhaps the Porsche specialist at our host would have a quick answer via the 800 number :=)
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
I have the early pulley mated to an 80-89 fan (83mm) and am using 10x695 belt.
Mark S. '70 914-6 |
Thanks Mark!
Functionista
PO installed 130mm crank pulley on my 74. OE was 110mm.
Fan pulley is still 95mm. Belt size: 10 X 740.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
The 74 still had the larger fan pulley. I think I need the 695 or 700.
A few more ideas for the Fan debate.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Yet another reason for using 2 12 volt radiator fans to help cool the rear lid condensor....and.. The engine.
Chain fence eating turbo
I have MegaSquirt and can read CHT's at anytime. On 90-100 degree days, once fully warm, the CHT usually stays around the 300 degree F mark give or take 5 degrees.
Fan speed seems to not matter much. Last edited by Tippy; 09-18-2012 at 02:56 PM.. |
Moderate traffic.
I should add I'm 7.5:1 CR so my data may not be accurate for most. Last edited by Tippy; 09-18-2012 at 07:01 PM.. |
Wer bremst verliert
I spin my fan and alternator at 2x normal speed and have stable voltage, good CHT, no knocking and good oil temps. I have ~20 track days with that setup with no issues.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
