911 tweaks's Avatar
Where can i find the 20 degree brake caliper piston alignment tool...??
CAN ANYONE ADVISE WHERE TO GET THIS TOOL AS PELICAN DOES NOT OFFER IT...IF I AM CORRECT = PELICAN DOES NOT CARRY THIS, CAN SOMEONE PLEASE POST UP WHERE TO BUY IT or post an attachment or email me THE EXACT DIMENSIONS/FILE SO I CAN PRINT IT OUT AND USE IT AS A STENCIL TO CUT ONE OUT...THX IN ADVANCE...BOB
I live for 911 tweaks...
Old 06-27-2012, 06:39 PM
brake tool
take the bentley's manual, a protractor, a piece of thick construction paper, and make it.
Old 06-27-2012, 06:41 PM
20 deg. caliper alignment template - Rennlist Discussion Forums
Old 06-27-2012, 06:44 PM
911 tweaks's Avatar
ok...I'll check out bentley to see if I can find it...is the shape more than a 20 degree wedge...??
I believe the tool is designed to be able to engage & rotate the caliper piston to correct its alignment if its off, right...??
Old 06-27-2012, 06:45 PM
911 tweaks's Avatar
thx for this speedy help mtb...I cannot access the rennlist site...so, can you post up here on this thread what ever is there that will help me...thx in advance...Bob
Old 06-27-2012, 06:46 PM
Navin Johnson
TimT's Avatar
make it
Make one....
The dimensions are in my old Bentley, Clymer, Chilton manuals and are described in the factory manuals... and have probably been posted here at some point
'69 911 GT-5
'75 914 GT-3
and others
Old 06-27-2012, 07:20 PM
ROW '78 911 Targa
timmy2's Avatar
Here ya go.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-27-2012, 07:21 PM
pete3799's Avatar
+1 make one
Pete
79 911SC RoW
Old 06-27-2012, 07:24 PM
20° Template..........Using trigonometry
Draw or make a triangle with equal sides. The corners would have 60° each. Divide the arc into 3 equal parts and connect the corner to the point/s on the arc. Now you have a 20° angle template without using a protractor. Or contact Ed Mitchell (evangene). HTH.
Tony
Old 06-27-2012, 07:40 PM
1980 911 SC
If I recall, I eyeballed this 4 years ago and have never had any issues.
Life's a Beach
Old 06-27-2012, 08:11 PM
vash's Avatar
if you make one..make it out of clear rigid plastic. kinda makes it easy if you can see thru it.
i admit, my last rebuild was on some turbo calipers..it got confusing, so we eyeballed it. brakes are quiet.
poof! gone
Old 06-27-2012, 08:32 PM
Can't it just be eyeballed? Looking at the caliper diagram above, the bottom edge of the slot on the piston is at the 9 o'clock position. Just line it up by sight and gently push the piston in. The "tool" is not designed to rotate the piston in the caliper. A piece of cardboard will serve to check it, but you can also do it by sight. Just make sure you have the orientation correct relative to the rotation of the rotor.
Old 06-27-2012, 08:41 PM
AutoBahned
RWebb's Avatar
No!
It MUST be made out of Ti!
Old 06-27-2012, 10:51 PM
Diss Member
Quicksilver's Avatar
Tin snips and a chunk of sheet metal.
To turn pistons I use a set of heavy duty snap ring pliers used on transmissions.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-27-2012, 10:54 PM
Diss Member
Easy way to make a 20° triangle...
Cut the corner from a rectangular piece of metal so one side is 2.5" long and the other is 0.9" long. That will give you a more then accurate 20° angle. (19.7989°)
Old 06-27-2012, 11:07 PM
Smoove1010
Smoove1010's Avatar
This isn't rocket science - I made mine from some stiff cardboard to match the line drawing above with a protractor, ruler, and a razor blade. You could also print the image and trace it out onto the cardboard. You'll need to gently turn the piston by hand or with pliers to meet the angle of the guage. Worked fine - the car stops almost every time I press the brakes, and no noise...
Old 06-28-2012, 06:57 AM
911 tweaks's Avatar
thx guys...I found out that Ed M. the coupler guy made some of these in the past...I am awaiting to hear back from him to see if he has any more so I can get one...
Old 06-28-2012, 07:02 AM
vash's Avatar
Let me know. I can mail you mine. Clear plastic and cut to a perfect 20. My OCD took over. I can't see a rebuild in my near future.
poof! gone
Old 06-28-2012, 07:21 AM
+1
I rebuilt all four about seven years ago, and just did a second rebuild on the rears. I just eyeball it and have never had an issue. And Gitano is correct. The photo in the Bentley shows the positioning.
Easy-Peasy.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 06-28-2012, 07:23 AM
Senior Advisor
James Brown's Avatar
the templet is in the instructions for the caliper rebuild kit
08 Cayenne Turbo
Old 06-28-2012, 09:07 AM
