ShakinJoe's Avatar
No you will not work the 915 too hard. Tyhe 84-86 Carreras used a 915 with a 3.2L engine.
I am just about to sell my 3.2L if you are looking for one.
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 07-29-2012, 10:48 PM
ROW '78 911 Targa
timmy2's Avatar
Originally Posted by maui44 View Post
Timmy2
The vehicle is a 1977 911S Targa.
Will I work the 915 to hard with a 3.2
No, if you drive it normally it should last a long time especially as your's was recently rebuilt.
If you are doing 6000 rpm clutch drops from a stop as mentioned in the Wheeler Dealer show, it will break eventually like any other transmission.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-29-2012, 11:29 PM
Porsche Crest 915
Thank you all for the great replies.
Based on what everyone has said, I use the 915 with the 3.2.
Old 07-30-2012, 06:44 PM
Based on the feedback, it sounds like the 915 should work well with a 3.2.
Old 07-30-2012, 06:54 PM
Brando
quattrorunner's Avatar
My 915 is running with a 930
I have a 91561 as well, it's a good one and if you run a 3.2-3.6 youl be fine
Turbo powa!
1977 911s. it's cool
Old 07-30-2012, 06:59 PM
Porsche Crest
If you can run a 915 with a 930 I am sure I be fine with a 3.2
For 930's, are most of the early Transmissions 4-speed?
Old 07-30-2012, 07:14 PM
Brando
930's used 930 boxes(4 speed) till 88 I think when they used the g50 box. 930 boxes are great if you have enough torqe to turn those tall gears. Not good unless you have a turbo.
Turbo powa!
Old 07-30-2012, 07:21 PM
Could someone tell me the main differance between my 915/61 and a 915 /68 and 915/73?
Porsche fanatic
jager911's Avatar
Agree with prior posts, I would not bother with the headache and expense of installing the G50. At that point, I'd sell what I have and buy a G50 Carrera already done.
A 915 with good syncros and adjusted linkages works just fine with a 3.2L. I upgraded from a 3.0L to a 3.2L and stayed away from the 3.6L due to cost. BTW, it's a simple upgrade, bolt-in, some minor mods to fuel lines and 14 pin connector.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 07-30-2012, 07:47 PM
efhughes3's Avatar
Buying a used motor is a risky, and potentially expensive endeavour. I'd do the take your time route suggested by Grady, and plan a rebuild.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-30-2012, 08:12 PM
Ed,
I am in no rush at all. I am looking at doing this down the road sometime. The trigger will probably when my rebuilt 2.7 has issues that some issues.
Old 07-30-2012, 08:31 PM
Speed Dog's Chauffeur
Dodge Man's Avatar
Keep Driving It
IMHO Why change the motor? The mid 70's 911s are finally seeing an increase in value for clean rust free cars with matching numbers. I went down the motor change road and I spent a lot of $$$ and I lost a lot of $$$ in resale value for my 73. To make your 2.7 live a long & happy life, you may just need to look at a SSI and maybe an oil cooler to help with the heat dissipation issue. Since 1977 is still under CA SMOG regulations, that is another thing to consider for a few years. You have the solid 77 motor & trans in your car which is pretty darn good. Enjoy. When the time comes, bigger, better motors will still be available.
Old 07-30-2012, 10:02 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
maui44:
I say a little "Forced Induction" is in order here. Not much boost 5-7psi is safe. A supercharger or turbo would do it well.... It is do-able.
Later
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 07-30-2012, 10:16 PM
