Je Ne Sais Quoi = Targa
Mikey83835's Avatar
SC cold idle problem
Car simply dies when idling going downhill when cold, and will not restart, anybody else run across this? CIS injection, new (rebuilt) WUR, runs like a charm when warm,
My driveway is steep and I do not like to have to let it warm up for 5 minutes and stink up the garage,
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018,
'81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust,
Had a '71 911S Targa in the 80's, miss it,
Had a '61 Roadster in the 70's, miss it also,
Old 08-05-2012, 12:55 PM
aux air regulator work ? should have high idle after initial start 1400 rpm for a few minutes what year is car? 82,83 models have enrichment computer under passenger seat along with oxs control unit. check fuse for oxs system same as dome light fuse. do dome lights work? a few things to try.
Old 08-05-2012, 10:25 PM
RETIRED
Joe Bob's Avatar
CHT or fuel pressure.
2012 ML350 3.0 Turbo Diesel
Old 08-05-2012, 10:29 PM
ROW '78 911 Targa
timmy2's Avatar
Check your cold control pressure, WUR may have moved out of spec.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-05-2012, 10:44 PM
Mikey83835's Avatar
Motor is in a '74, and is an un-numbered motor, (which I understand indicates a warranty replacement motor?)
It is going back in the shop soon, but the dying going downhill is the confusing part,
Old 08-06-2012, 11:08 AM
76 911S Targa
What cold start set up do you have, the original hand enricher or the SC set up with cold start valve? If you have a hybrid, this could be the source of your problem.
Also in NI, 83801.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 08-06-2012, 11:53 AM
Fleabit peanut monkey
Bob Kontak's Avatar
What could a change of gravity direction impact?
Air flow sensor that has a little sideways play?
Fuel location in tank?
Wire that gets grounded from moving?
Seems those all would happen when warm as well.
Old 08-06-2012, 11:57 AM
Dumb idea - could it be a motion sensor? I know that my old MGB had this thing under the dash that was supposed to cut off the fuel supply if the car tipped over.
A long shot at best, but stranger things have happened.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 08-06-2012, 01:27 PM
