dimps8's Avatar
Part number for early sunvisor pivot
Trying to find the part number so I can complete my pelican order. 65 built 66 912 RH sunvisor plastic pivot. Screw holes look to be 5mm. Thanks.
Damon Harris
66 912 coupe
Old 08-05-2012, 04:04 PM
Iowa911's Avatar
I think those are NLA. Is the one you need just like the unbroken one you show here? Or is it a fatter shaft? The inboard and outboard were different diameters.
Dean T
1984 Cab White/Blue
Cat bypass, B&B muffler, Steve W. Chip
1966 912 Red/Black
1963 356B --sold--
Old 08-05-2012, 06:43 PM
dimps8's Avatar
Dean it's the same as the pic, ones still good and the other is broken, same part. I think its' this?
OEM-90173103421 Ships in 5
Business Days
[why is this?] Genuine Porsche Part: SUNVISOR MOUNT
- This is a special-order OEM part and is non-returnable except for warranty replacement.
[More Info] $19.25 $19.25
Damon Harris
66 912 coupe
Old 08-05-2012, 06:49 PM
Iowa911's Avatar
I'm not sure that's it. I think they only made the skinny inboard pins 1 or 2 years and I don't think they are available anymore. I had a heck of a time finding a used replacement for mine. I could be wrong, but I think the one you are looking at is the thicker pin. Any experts out there know for sure?
Dean T
1984 Cab White/Blue
1966 912 Red/Black
1963 356B --sold--
Old 08-05-2012, 07:06 PM
dimps8's Avatar
I'll check the other ones Dean, these are 5mm, the bigger shaft is 8mm.
Damon Harris
66 912 coupe
Old 08-05-2012, 07:17 PM
RETIRED
Joe Bob's Avatar
So what are people using if that part is NLA? Are 75-85 targa/cab pivot pins usable? If they are, I have a few available. I can mike the shafts....
2012 ML350 3.0 Turbo Diesel
Old 08-05-2012, 08:13 PM
dimps8's Avatar
Ok I rechecked, It is the larger 8mm one I need. Looks like it's four separate part numbers, the outers are 8mm and the inners are 5mm.
Damon Harris
66 912 coupe
Old 08-05-2012, 09:11 PM
Iowa911's Avatar
If you can't find one, I have an extra one.
Old 08-05-2012, 09:15 PM
RETIRED
Joe Bob's Avatar
In case you are interested and plan to convert in the future...the later shafts on BOTH sides are 8mm. BOTH sides have a tensioner screw while it appears the early ones have only one.
Old 08-05-2012, 09:21 PM
RETIRED
Joe Bob's Avatar
Old 08-05-2012, 09:25 PM
