wreckah's Avatar
hi Todd,
- volt gauge = to check if your charging system works as it should. I had a broken regulator before and fried a couple of components without knowing (charging at 18V instead of 14V).
- afr gauge (air/fuel ratio monitor): this is to protect my full engine rebuild investment. After spending 15K, i don't want to damage the engine by running too lean or something else. After i installed it, it was immediately obvious that my CIS was running like crap...hence the swap to EFI.
cheers, Jan
before: '69 Porsche 911T bahama yellow
now: 1981 911 SC Targa winered
Old 06-07-2018, 01:07 AM
Thanks wreckah and Trackrash.
Trackrash - do you have a name or link or something where you found that gauge?
Originally Posted by wreckah View Post
hi Todd,
cheers, Jan
Old 06-07-2018, 06:43 AM
82 911 SC - Ancora Imparo
For my 82 SC I’m looking for a sportier, more aggressive exhaust. I have a stock setup besides the test pipe. My mechanic recommended M&K. What do you guys think?
Old 06-07-2018, 07:22 AM
BuddaLun's Avatar
Rennshift + Wevo Coupler
SSIs w/ 2 in 1 out sport muffler of your choosing (ideal for street)
16x7/8 Wheels and 205/225 good tires
Momo Prototipo w/ eccentric spacer
All maintenance/wear items
These changes have made the biggest difference to my SC.
Old 06-07-2018, 07:48 AM
Still here
pmax's Avatar
Base line performance.
Old 10-25-2019, 11:00 AM
Fleabit peanut monkey
Bob Kontak's Avatar
States pressure cast light alloy rims. I thought Fuchs were forged?
1981 911SC Targa
Old 10-25-2019, 04:03 PM
Bill Verburg's Avatar
They are but for SC's, but Cookies were standard and later for 3.2 C's Phone Dials, both are cast wheels
Bill Verburg
Old 10-25-2019, 04:21 PM
Reiver
Reiver's Avatar
It'll go faster with an SC 930-10 after you lighten it...mucho.
De Oppresso Liber
Strength and Honor 5th Legion
Old 10-25-2019, 05:05 PM
MichaelSJackson's Avatar
Did vanos ever state his goals?
Old 11-04-2019, 04:56 PM
Matthew_VA's Avatar
Changes that I have made that I would definitely recommend:
1) 7&8 x 16 Fuchs
2) Karsten spring
3) 930S steering wheel
4) H4 Headlights
5) a/c delete
I would also recommend the following--original owner already did these prior:
- exhaust (B&B tri-flow headers and 2 in / 2 out exhaust
- strut brace
- F/R sway bars
TBD
Prior: '84 911 3.2 Carrera, '83 911SC Targa
IG: @heuersandcarreras
"I want to use it. That's what 911s are for." - Richard Hammond
Old 10-25-2021, 06:53 AM
The early SC’s tested quite a bit faster, check out the Car & Driver 1978 911SC targa road test, that car would run with a 3.2 Carrera! 0 to 60 in 5.5 sec if I recall correctly, I think primarily due to a higher flow fuel distributor and large port heads.
I plan on “backdating” my ‘82 SC to an early CIS set-up with matching large port heads (among other mods). My Stock ‘82 “dies” around 5500 rpm and it drives me nuts, if I want big block torque I’ll drive one of my pushrod V8 cars…
Old 10-25-2021, 08:08 AM
Halm's Avatar
Originally Posted by G450X View Post
. . . My Stock ‘82 “dies” around 5500 rpm and it drives me nuts, if I want big block torque I’ll drive one of my pushrod V8 cars…
964 cams will take care of that.
'17 Cayenne
Old 10-25-2021, 08:14 AM
I wouldn't put too much faith in that piece of literature. It also says the engine layout is "Air-cooled, four-cylinder, horizontally opposed"
_______________________________
1982 911 SC 240,000mi and counting
Old 10-25-2021, 08:29 AM
I agree with all of this. The SSI and exhaust made the biggest difference for me. I'd add continually looking for ways to remove weight and replacing worn-out comfort seats with something more appropriate to the list as well.
Old 10-25-2021, 08:32 AM
Reiver
Reiver's Avatar
Old thread but relevant info...I've lightened m '83 SC to 2300 and have a Euro 930-10 with SSI's etc....10.45 lbs per HP. That moves pretty nicely.
I found some cloth Recaro's w/ headrest that are very light...put some Pascha on the center sections so looks good too. They wear well also...have had them for some years now.
De Oppresso Liber
Old 10-25-2021, 10:41 AM
shoooo32's Avatar
For me, there's no better cheap and easy mod for an SC than plugging the decel valve. Having the engine drop RPMs slowly is not cool lol.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 10-25-2021, 10:52 AM
GothingNC's Avatar
Prior owner of my 82 Targa
Plenty of power to redline
Ported intakes and runners to 36mm
Replated Nikasil's w/ JE Pistons - effective static CR 9.7:1
Elgin SC330 cams timed at 2.0mm
SSI's with Dansk Sport 2/1
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Reiver
Reiver's Avatar
Originally Posted by trond View Post
do nothing except tires that fit the car and keep it original. Most improvements will not make it better
How so...'better' is a relative term.... the mods I've done have made mine 'better'...now, if you are talking about owning for a short period and selling...a flipper...then you are correct.
De Oppresso Liber
Old 10-25-2021, 11:58 AM
I think location should govern your mods somewhat.
I tried a few of the tricks for SCs incl. 2021 cams, SSIs and CR CDI box. Definitely made a difference but it’s not the “silver bullet” power wise. Most of what I have around me in close proximity are freeway on ramps. For that, I think an SC is inherently undergunned and the exhilaration of a turbo would be A-plus.
I took ~150lbs of weight out, refreshed the suspension (and increased TBs), added 9x16s to rear and drove to California. The exhilaration of flowing through corners and being able to use all pro forma 200hp all of the time was priceless. That’s the hook for me. That I could comfortably and reliably cruise all the way back home fills me with admiration for CIS (I’m ashamed to say).
I’m going to try and continue to take more and more weight out on the sly, without changing the cars appearance as a stock car. If my ship comes in, I may think engines or a stable mate but it’s getting pretty good as is.
Old 10-25-2021, 08:23 PM
No, it says 4 cycle engine, not four cylinder. That is the official Porsche spec sheet. They are always conservative of HP and performance figures. Unlike many manufacturers of the time that would flat out lie about HP or torque.
Old 10-26-2021, 09:22 AM
