Valve cover tightening torque/and sequence
For the lower 11 stud valve covers anyone know the proper tightening torque and tightening sequence.
It's a 77 911 Also the proper tightening torque for the round sump plate on the bottom of the engine. Thanx L |
Valve covers are torqued from the middle out, alternating top / bottom. I think the torque is 8 ft-lbs, but not sure. Get a Bently manual.
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
ok thanx doug
Chain fence eating turbo
Or think of it as a spiral going outward starting with the inner nuts first if that makes sense.
Keep the Shiny Side UP! Pete Z. |
88 Carrera, Guards Red
tightening sequence
For the tightening sequence non of these answers make me feel very good. Is this why so many people have valve cover leaks. Using an oem gasket I would think that the sequence would be something like upper then lower center, upper right next to center, lower left next to center, lower right next to center, upper left next to center. Moving outward. I can't find any reference to sequence in Bentley or wayne. everything on "other engines" taught you torque from center out in a star pattern. and of course for very high torque items like heads you do it in two stages. I can see people starting at one end of the cover and just moving along to the other end. Like I said, if I did not see so much about cover leaks I would say I was being over complicating. ps.. three valve adjustments and I have never had a leak on my 88. tear me up...
Just keep in mind it's not a pressurized seal. That is all you need to know.
I think I read somewhere in here that you just turn until it stops, and then maybe a very light tug. With a tiny 1/4" ratchet, you don't generate much torque to overkill it.
1986 Bosch Icon Wipers coupe. |
Member 911 Anonymous
Go over the nuts several times to insure they are snugged to torque spec
+1 get a 1/4" drive torque wrench if you plan to diy your valve adjust |
Mighty Meatlocker Turbo
Dracholio, you actually use a torque wrench for fasteners like those - holy jebuz, I didn't think you were such a noob?!?!?! ![]() Last edited by Rawknees'Turbo; 01-16-2017 at 08:02 PM.. |
So...why so many comments about reoccurring, persistent leaks. it can't be layed at the feet of warped covers.
My guess is that it is from people being too lily-livered with their tightening torque (aka - not getting them tight enough after reading about the original, dainty torque specs), so the gasket gets wet and then no amount of further tightening stops leakage after the fact - similar in a way to how people experience rocker shaft walking when tightening old fasteners/shaft assemblies to original "new" torque specs (not nearly enough torque for old, used gear). |
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
/ˈpɔrʃə/ PORSH-ə Fan
In ~40 years of existence, several owners and varying degrees of skill/attention to detail from said owners or mechanics, the valve covers can easily be bent. I am guessing Turbo valve covers are a popular upgrade because of this. Doesn't matter what tightening pattern you use if the covers aren't true.
1984 ROW Carrera Sunroof Coupe Schieferblau 1982 US SC Targa Moosgrun 1977 US 911S Sunroof Coupe - SOLD |
get a die die and clean the threads really good.
also use the reusable gaskets and just snug them. if you think they are tight enough then they are too tight. if the gasket squeezes out they are too tight. they are WELL worth the money
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
