Atlanta- CDI Check out (part 2)
I am still fighting a no start issue. i cross posted my most recent thread from the 930 forum below. Would anyone be willing to put my newly rebuilt CDI in their car to see if in fact it is ok? I would be more than happy to come to you at your convenience. Also is there another bench test, other than checking resistance on the primary and secondary winding, to confirm the coil is ok? me resistance #s are in spec.
Pelican Parts Technical BBS - Powered by vBulletin
Charles
88 911 Cab
74 TR6
88 CRX Si
79 930 #632 (sold her and survived her)
Old 08-21-2012, 05:13 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
can you tell me the range of year models that it fits?
Old 08-21-2012, 05:22 PM
6 prong CD is all SC s besides 78 and later Turbos
Old 08-21-2012, 06:26 PM
Elombard's Avatar
I am trying to remember there is a relay that is notorious on the 930s but I think it is for the fuel pumps. Its back in the engine compartment, i was helping a friend with an 87 and that turned out to be the problem.
I wonder if you call the folks who fixed the CD box and explain if they can walk you through a test. I suspect they will want it back though.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 08-21-2012, 07:37 PM
The 87s have a yellow fuel pump relay next to the CDI that controls the rear pump. it is notorious for going bad. guys will jumper that relay to test it/get he car fired. i do not have that relay in my 79. I'm geeting fuel to the cylindars just no sparky. A 930 guy outwest said he would send me a good spare CDI he has to put in my car to see if it will fire, i just don't want to fry his CDI if there is something else wrong w/ my car that could potentailly fry it. if i could plug my CDI in another car and it is bad, i would send it back to ECU drs.
Charles
88 911 Cab
74 TR6
88 CRX Si
Old 08-22-2012, 05:11 AM
anyone up for me pluging my "pro-rebuilt" 6 pin CDI in their car to see if the CDI is actually working?
Charles
88 911 Cab
74 TR6
88 CRX Si
Old 08-24-2012, 04:54 AM
rattlsnak's Avatar
what about 84 and newer? or only SCs?
Old 08-24-2012, 09:51 PM
Certified User
billjam's Avatar
I got sick of trying to test individual parts both in and out of the car so I put it all together on a jig on the bench and hooked it up with some temporary wiring.
The pic shows a Permatune CDI and an MSD coil, but I also ran this with the Bosch parts to check that they were OK as well.
I managed to confirm that all my components were OK and narrowed the problem down to wiring and a dodgy speed relay.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 08-24-2012, 10:49 PM
$ Short's Avatar
I'm liking the jig. Well done Bill
Old 08-25-2012, 04:54 AM
Elombard's Avatar
wow that is clever. Argh, wish i could help
Old 08-25-2012, 05:10 AM
Nice set up Bill. i like the flex boot on the green wire on the end where it plugs into the distributor.
where is the speed relay you found to be bad?
Charles
88 911 Cab
74 TR6
88 CRX Si
Old 08-25-2012, 06:17 AM
Certified User
billjam's Avatar
The speed relay is under the seat if your car is 86 or later. Earlier models don't have it.
It is in the fuel pump circuit, so doesn't affect the ignition. It cuts the fuel pumps if it isn't feeling well!
Bill
2024 Macan S
Old 08-25-2012, 06:26 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
It is perfectly save to put another CDI into your car as long as your battery is OK and alternator doesn't go up to 17 volts when you rev the engine.
Test-firing a 6-pin can be done with a AA battery. Negative to the trigger wire and positive to GND of the car. Hook up GND, +12V and coil primary to the CDI. Spark plug to secondary of coil.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 08-26-2012, 07:50 AM
Chris let me put my CDI in his car and it did start so i can rule it out. someone on the 930 board sent me a spare coil, rotor, green wire to try out.
Charles
88 911 Cab
74 TR6
88 CRX Si
Old 08-26-2012, 01:02 PM
