Sway bar recomendation
Car is my 72 it didn't come with a front sway bar. Should I go with 19mm or 22mm. Also want to upgrade shocks. sport or HD? I don't want a harsh ride so should I go for HD?
72 911 82 911 70 GTO ![]() 97 GT Ragtop 74/76 Jeep cj's |
My car is used for street, Autocross and (maybe) a DE every year. For years I drove with stock torsion bars, 19 mm front and rear adjustable bars, Bilstein HD front/Sport rear shocks. Due to a rubbing issue, I recently added turbo torsion bars to reduce squat and improve autocross handling. what are your goals? Steve Weiners Web site offers some ideas here: Suspension | Rennsport Systems | Porsche Performance Systems and Support and here: 911 Suspension and Handling Packages | Rennsport Systems | Porsche Performance Systems and Support
Just spirited street driving
Get a 19mm, I have a 22 and it's to much bar. If you are talking about bilstein shocks, get HD, sports are stiff as hell.
72 911 Although it is done at the moment, it will never be finished. |
my stock 1977 came with 19mm front and rear
bilstein HD is plenty for street adjustable front sway bar is the cat's ass a stock 19mm front should be available used for $50 or less
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks for the replies Where can I find that 50.00 bar?? lol
Thanks to all. Any recs on what particular setup? Rennline, Weltmeister, Elephant? Too many choices I think...
Sniff around. Many consider the market for stock 19mm worthless as SC and Carrera front bars are out there floating around I paid $75 for an SC front bar last winter. The seller was a Long Island guy. I didn't even negotiate with him for $10 or $20 off
Max Sluiter
Tarett.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
before you buy a stock sway bar, make sure you have the 'U' brackets welded onto the A arm. If your car does not have them then I would suggest the through the body adjustrable sway bar. A decent set up is a Carrera front bar and an adjustable rear sway bar.
Tony G 2000 Boxster S |
My car does have the tabs and has the factory block off plate for the through the body bar. I just have to unbolt the plate and i believe i am good to go. I am looking at the adj Weltmeister bar. 19mm/ I won't be tracking the car i just want a simple upgrade.
I have the welt and it will work just fine, you can change the drop links to make it even better if you like. Tarett, etc make a much better bar, but since it's a street car, why bother. But if money is no object, get the the best.
Max Sluiter
The Taretts have nicer bushings than the Weltmeisters. That means quiet, smooth operation. My Welties squeak. Since it is just a canyon toy I don't need to replace them just yet and can save up some money for the nicer Taretts.
I have Weltmeisters without any issue and working fine on my 930. The only thing I can say is that the rust protection is way to thin, so after a few years without any rain contact, they look like other after 20 years...
However I ordered some Taretts mainly because of the nicer look and less weight.
Roland 930 Turbo '81 Too many modifications to list |
