72 four door's Avatar
Sway bar recomendation
Car is my 72 it didn't come with a front sway bar. Should I go with 19mm or 22mm. Also want to upgrade shocks. sport or HD? I don't want a harsh ride so should I go for HD?
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 08-24-2012, 05:55 PM
HarryD's Avatar
All depends on planned use. Are you street only, some track, mostly track?
My car is used for street, Autocross and (maybe) a DE every year.
For years I drove with stock torsion bars, 19 mm front and rear adjustable bars, Bilstein HD front/Sport rear shocks. Due to a rubbing issue, I recently added turbo torsion bars to reduce squat and improve autocross handling.
what are your goals?
Steve Weiners Web site offers some ideas here: Suspension | Rennsport Systems | Porsche Performance Systems and Support and here: 911 Suspension and Handling Packages | Rennsport Systems | Porsche Performance Systems and Support
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-24-2012, 06:12 PM
Just spirited street driving
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 08-24-2012, 07:15 PM
tobluforu's Avatar
Get a 19mm, I have a 22 and it's to much bar. If you are talking about bilstein shocks, get HD, sports are stiff as hell.
Old 08-24-2012, 07:28 PM
my stock 1977 came with 19mm front and rear
bilstein HD is plenty for street
adjustable front sway bar is the cat's ass
a stock 19mm front should be available used for $50 or less
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-25-2012, 01:17 AM
Thanks for the replies Where can I find that 50.00 bar?? lol
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 08-25-2012, 04:12 PM
Thanks to all. Any recs on what particular setup? Rennline, Weltmeister, Elephant? Too many choices I think...
Old 08-26-2012, 06:17 AM
Sniff around. Many consider the market for stock 19mm worthless as SC and Carrera front bars are out there floating around
I paid $75 for an SC front bar last winter. The seller was a Long Island guy. I didn't even negotiate with him for $10 or $20 off
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-26-2012, 12:16 PM
Max Sluiter
Flieger's Avatar
Tarett.
Old 08-26-2012, 12:44 PM
before you buy a stock sway bar, make sure you have the 'U' brackets welded onto the A arm. If your car does not have them then I would suggest the through the body adjustrable sway bar. A decent set up is a Carrera front bar and an adjustable rear sway bar.
Tony G
2000 Boxster S
Old 08-26-2012, 12:54 PM
My car does have the tabs and has the factory block off plate for the through the body bar. I just have to unbolt the plate and i believe i am good to go. I am looking at the adj Weltmeister bar. 19mm/ I won't be tracking the car i just want a simple upgrade.
82 911
70 GTO
97 GT Ragtop
74/76 Jeep cj's
Old 08-26-2012, 04:54 PM
tobluforu's Avatar
I have the welt and it will work just fine, you can change the drop links to make it even better if you like. Tarett, etc make a much better bar, but since it's a street car, why bother. But if money is no object, get the the best.
Old 08-26-2012, 05:53 PM
Max Sluiter
Flieger's Avatar
The Taretts have nicer bushings than the Weltmeisters. That means quiet, smooth operation. My Welties squeak. Since it is just a canyon toy I don't need to replace them just yet and can save up some money for the nicer Taretts.
Old 08-26-2012, 06:06 PM
proffighter's Avatar
I have Weltmeisters without any issue and working fine on my 930. The only thing I can say is that the rust protection is way to thin, so after a few years without any rain contact, they look like other after 20 years...
However I ordered some Taretts mainly because of the nicer look and less weight.
Roland
930 Turbo '81 Too many modifications to list
Old 08-26-2012, 11:43 PM
