djk_wff's Avatar
Disconnecting a 911 connector 101
Desperate need for help on how to disconnect these 3 connectors on my '88 911 carrera. These are on supposedly the ign sensors and i can't figure em out .. They are mounted on the left side of the engine, on the intake manifold. There's a rubber boot on the plastic conn mounted to the manifold bracket.
I'm troubleshooting a no spark issue and am going to bypass the head sensor, according to the troubleshooting posts. thanks in advance to an embarrassing question, but a serious situation!
1988 Porsche 911 Carrera
triple black
VA coast
Old 09-16-2012, 11:38 AM
white rabbit
Send a message via Yahoo to Don LaVance
If you mean that, when you pull on one of the 3 connectors they will not seperate , they are being retained in place by the wire clips that you see circling each of them. Insert a small screw driver or a pointed probe and gently pry it outward from the connector as you simultaneously wiggle the connector to pull it out. when re-installing Ensure that the wire clips are seated fully in their respective recessed area to ensure good solid retention.
Be gentle.
Old 09-16-2012, 11:48 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Sensors.
triple black
VA coast
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-16-2012, 11:56 AM
Technically, if you reach in and pull hard enough, the spring slips over and comes out.
However, it is much safer so that you will not break anything by getting a pick and lift the spring over the retainer ears.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-16-2012, 01:20 PM
donagain1's Avatar
Before prying the spring clips you might drape a rag beneath them to prevent a clip from disappearing forever should it fly off. Probably not necessary, but better to say "What did I do that for?" than wishing you had.
Old 09-16-2012, 02:49 PM
Virginia Rocks!
VaSteve's Avatar
Those have been through a million heat cycles by now. Do yourself a favor and pick the wire clips off first. It should come right apart. If you pull hard, it could crumble. Asl me how I know these things.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 09-16-2012, 03:18 PM
Chain fence eating turbo
I pry only one side and once far enough the connector will wiggle off with a little effort.
Old 09-16-2012, 03:34 PM
djk_wff's Avatar
Thanks for the comments !
was able to wiggle those connectors off w/o breaking 'em,
on 1988 3.2 Carrera ...
Still have not figured out my no spark problem though, perhaps a new thread?...
after the engine shutting off on a drive,
good fuel flow (at least smells like it's getting fuel)(new DME)
replaced the distributor & rotor,
rerplaced the coil,
inspected the sensor connectors (above),
shorted across the CHT sensor,
still no spark ...
Any additional suggestions?
Old 09-20-2012, 05:47 AM
dshepp806's Avatar
Without question, remove the wire clips FIRST.....
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-20-2012, 03:26 PM
Tags
1988 , carrera , connector , ignition
