embacpa
Carrera 3.2brakes
too much brake fade. anyone have constructive advice on cooling stock brakes vs. 930 upgrade? current mods include ssi, m&k 2in2out, lsd, ER suspension upgrade. continued DE seat time, great feedback from instructors, and progressing with incremental mods. thanks for sharing your relevant experience.
What pads and fluid are you using?
Jess 1980 911SC Euro 1993 Audi CSQ |
Member 911 Anonymous
Pagid Orange, Remove Splash Guards, Install Air Diverters ( I think they are 993 or 996 part ) ATE Rcing Blue Brake Fluid
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Northern Motorhead
Stock brakes can be an issue if pushed hard ... Friend of mine has an 88 with stock brakes,sticky tires and PFC race pads and his rotors were blue after our DE this past weekend !
I think the glue from the rear pads transfered onto his rear discs ... Like Draco says,air diverters will help a lot,although there's nothing much one can do for the rear ! Lots of good reading on this forum ! Cheers! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
subscribed!!
84 Carrera Cab - ROW Thanks to this Tech forum!!!!!!!!! Tranny rebuilt etc.. Fresh Konis, Lowered front,, R&R injectors, Wonged, Valve Adjust, Electrical solutions, Next; Lower rear, Corner balance |
lighten the car as much as possible I'd use a modern pad, PFC97 seems to be very popular as does Pagid yellow use the best freshest fluid you can afford, SRF, Motul, Prospeed, Endless are all excellent the ultimate fix of course is 930 brakes
porsher
I run my 86 on a wide variety of tracks with zero brake fade or boiling fluid, here's the run down:
stock rotors PFC-97 pads motul 600 brake ducts in front rotor block off plates car lightened to 2,450 caliper piston seal replaced every time rotors are changed no caliper dust seal master cylinder catch tank braided brake lines bleed brakes before every event hose off brake/rotor dust after every event I think that's everything! Front pads and rotors last about 700 track miles, rear about twice that.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Bill hit it first, lighten the car!! Pagid Oranges are an older compound. Yellow's or PFC97 are a good alternative. Make sure you brake HARD initially, then come off the pedal as you approach turn in. Brakes work the most efficiently while the wheels are spinning faster.
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
Schleprock
Agree with everybody else. Get as much cooling as you practically can. Don't underestimate the benefit this provides, especially considering the Fuchs wheels don't do much to help with cooling from the outside.
Ditch the Pagid Orange. A lot of people have problems with these and you end up replacing rotors much too frequently due to warping, which is actually a result of uneven pad deposition due to overheating. Our local group has run with PF97 for around 5 yrs and never a complaint from them. They're an endurance pad, so they're not extremely aggressive. Which means they last long, resist fade very well and are rotor friendly.
Kevin L '86 Carrera "Larry" |
UFLYICU
+1 My exact setup, no fade, ever, on stock rotors, calipers. I used to use the duck feet scoops, but tried the 993 diverters, and they work great. 2480 lbs SPEC911 car.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
You guys are lucky regarding weight. When I was running my 87 911 in PCA, I had to ballast the car up to 2756lbs without driver.
Is your brake fade an occurance at ALL tracks you visit or just one track?
What run group are you in? My guess is that learning to better manage your equipment (brake less?) would be a better skill to learn than one of jumping on more upgrades thinking that will solve the "problem". My unfounded assumption is that you are overbraking. Perhaps the next skill (comfort) to develop is taking corners better. The faster you can take the corner, the less braking you need to do upon corner entry. For a comparison, I thought my 914 didn't have enough brake. I was in the white group(signed off, solo group at the time) thought "I" wasn't the limiting factor and figured, well, lets change over to 911 stuff. Sure I didn't have any brake issues after that. Time went by, sold the car, then had some even faster ones, then bought another 914 with stock brakes. I was worried they wouldn't be strong enough (they are non vented afterall) and I was as quick as I used to be and had NO brake issues anymore... why? because I learned to brake better.. carry more corner speed, became a more skilled drover. As asked,,, what kind of pads fluid tires are you currently using?
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Try a Bleed with fresh fluid right before the event, it may do wonders for you.
My thoughts after 20 years of running stock Carrera brakes before finally moving to big brakes:
Need lots of cool air! Duct air from the nose of the car to the eye of the rotor. I used the 993 deflectors on the control arm but by themselves that's not enough volume of air. Ditch the Orange and got to Yellow. Or the PFC97 as has been suggested. ATE Super Blue is NOT a racing brake fluid. It's the original equipment fill in street Mercedes Benz sedans. I could cook that stuff in 20 minutes. You need a far better brake fluid with a higher dry boiling point. If you're on a budget, try the Motul 600. Great bang for the buck. If you want the best regardless of cost- it's either Castrol SRF or the new Prospeed 683. But remember that a true racing fluid needs to be blead frequently. As others have suggested, driving style and experience level makes a big difference. Back when I was an intermediate student 25 yrs ago I could boil my fluid pretty easily. As I got better, more experienced and began instructing 20 yrs ago my brake problems diminished. These days I see my intermediate students with all sorts of brake problems because they tend to brake earlier and are thus holding heat into the rotor and fluid longer. Experienced drivers will go in deep, truly threshhold brake, then get off the brakes, so there's more cooling time between turns. The first three are easy to change, the last one of course just takes time.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
embacpa
embacpa
thanks for all the replies. car is now in shop to install brake cooling fans on all 4 corners. will also take advice on learning to carry more speed in corners to reduce braking. heck, that's where all the fun is. i am using super blue racing brake fluid. anyone passionate about something that is really better? what is the boiling point compare?
again, thanks for all the feedback. |
I ducted from front of car with some home made scoups to eyes of rotors. My braking skill likely has significant room for improvement, I tend to over brake.
Certified User
Click on Thread Tools / Subscribe to suscribe this thread.
Once "subscribed" you will get an email notification when new posts are added. The thread also gets added to your list of subscribed threads at Quick Links so you can find it easily.
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
imho, it is the wet boiling points you'll not want to overlook. As soon as you open a bottle of brake fluid and expose it to moist air, it slowly begins to loose its effectiveness. Why "dry" boiling temps are often touted, for a car that sits a lot and may not be subjected to fequent fluid changes, look at the WET number too.
Castrol SRF: Dry 590/Wet 518) Motul 600: dry boiling point of 593F and a wet boiling point of 420F ATE Super Blue (Gold) : Super Blue (DOT 4) has a dry boiling point of 536F and a wet boiling point of 396F. (this info was taken from here:Castrol SRF, ATE Superblue / TYPE 200, Brembo LCF 600 and Wilwood 570 Brake Fluid - RACEShopper.com )
Agree with what others have said. Stock brakes can be made to work, but the other things have to be right (ie, pads, fluid, cooling) and you have to brake later / less, scrubbing off speed in the corner. Even with that, your brakes will see temps that will cook the dust boots...which is probably ok on a race car because you're only driving on the track and inspecting everything often, but some would say isn't the best idea on a street car.
- '72 911T - '81 911SC Euro |
