break fix drive repeat
Necessary to replace trailing arm bushings?
I have a very original 84 street-driven carrera that needs a suspension refresh, which I'm about half way through. The complete list (all purchased from ERP) includes:
My question is this: removing the trailing arms looks like a major PITA -- dealing with the brakes, half shafts, etc. I've also been told by my reputable p-car mechanic that the trailing arm bushings are pretty much good for the life of the car, unless you're trying to upgrade for racing purposes (I am not -- just trying to restore stock, or slightly better than stock, performance). So.............. What say you pelicans who have gone through the rear suspension refresh? Would or did you replace the TA bushings when refreshing your rear? And if so, should I replace the rear wheel bearings while I'm in there? (by the way...this project started as just replacing my front sway bar bushings. arg!) Thanks! Rich |
My thought on the matter has been, it's rubber. Rubber bushings don't last 30 years.
I opted to replace them when I did a suspension refresh. The hardest part is getting the trailing arms in and out of the car. Replacing the bushings themselves is a pretty easy process. I also opted to replace the wheel bearings. Why not when you've already gone that far, right? Honestly though, the tie rods gave me more trouble than the trailing arm bushings did. It's up to you if you want to go whole hog. Since you're replacing the torsion bars, you're going to need an alignment anyways. Might as well get all the bushings out of the way to avoid another alignment down the road. |
Garage Queen
If you look at the trailing arm bushings you will see that they can be quite compressed over the last 25 years. The difference can be quite dramatic. On my 930 the bushings were so misshapen that on the top of the bushing was half the size of the bottom. I also found some rust. I think if you are doing the suspension anyway, you should do it. It doesn't take much time. Yes, it can be quite trying reinstalling sometimes but not outside of the realm of what you can do.
Stephanie '21 Model S Plaid, '21 Model 3 Performance '13 Focus ST, Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3, |
Schleprock
Here's my take on your list
Trailing arms bushings do deteriorate with age. I've seen them show a noticeable amount of cracking in the rubber section. So take a look closely at yours. I'd replace them with OEM style "silent bloc" rubber bushings. The aftermarket monoball cartridges have spherical bearings in them that can wear out significantly with age. Be they std. steel races or teflon-lined, they both can wear out and develop squeaking. For street use the rubber is w/out question the way to go. Trailing arm removal is not that bad. Axle shaft removal is just a bunch of M8 bolts and it'll also give you the opportunity to inspect your CVs for grease & wear. Brake line disconnect will be your toughest task IMO. RE rear wheel bearings, I would consider replacing those before the fronts. Rears tend to go bad more often than fronts. That being said, both are very good bearings. Key to bearing life is quality grease. Often times the rears fail simply because of the economical grease used in them.
Kevin L '86 Carrera "Larry" |
+1 on doing it as the others described. You spend all that effort to do a full refresh and leaving out a key component won't make sense.
They do not last the life of a car (a driven one anyway)... ![]() Plus...now you get to clean and refinish everything and your handling will be so much better.
Marlon 1973 911 3.0 MFI |
I guess I knew the answer to my question before I asked it...just needed the moral support I guess.
I am resisting the urge to drop another $$$$$$ on new axle shafts, calipers, rotors, pads all around, as the car really does stop fine and the pads are at least 50%. But I will do the brake hoses and whatever fuel lines I can get to. My car thanks you! Rich |
Chuck doesn't sell stock equivalent replacements, so I got the most mild upgrade I could, and since I upsized the front I had to do the same to the rear to keep handling balanced. After this I'll need an alignment and CB anyway. Quote:
What's the grease you guys recommend? I have the swepco lubri-moly CV joint grease left over from rebuilding the CV joints on my 914...is this a good choice to pack these bearings? Quote:
Schleprock
If the axles are in good shape in terms of CV hub surfaces not pitted, you can just clean out the old grease and repack with your Swepco. It's good for bearings and CVs. Swepco 101 is a really good EP grease with good sticking power.
If you can rebuild the suspension, you can rebuild the calipers. Pretty easy with some compressed air and a block of wood to block the opposing piston. And your brake lines should be no different than the 914. Just use some penetrant (i've heard tobasco sauce is incredibly effective too...) and patience. The most important fuel lines to look at are in the engine bay under & behind the intake manifold. There are three lines you need to inspect: 1. Small line at the driver side fwd (rear) of engine. It's a tight bend radius short hose that splits over time. Very dangerous. 2. Y-shaped line that runs from the fuel filter in rubber, goes to the center, rear of the engine, becomes solid steel, goes under the manifold toward the fan, hits a tee at the fan and connects to the fuel rails with two more sections of rubber. This line is a notorious leaker if it is original single crimp swivel fittings. The later updated fuel line is non-swivel with double crimps. A lot of people choose to have hose repair shops rebuild this line with new hose & fittings. Amazon Hose in Tampa, FL and Len @ Autosport Eng (BoxsterGT here on the forums) do a nice job of rebuilding this hose. 3. Same thing as number 2 above applies for the rubber hose that connects the fuel rails at the front of the engine, between the fuel pressure damper and fuel pressure regulator. If your pads and rotors are in fine shape, no reason to replace them. Replace later when they're worn out. For street use, decent rotors and ample pads are more than sufficient. Stock Carrera brakes are very good brakes. Good call on the T-bars if that's the smallest Chuck makes. Stock torsion bar sizes are plenty suitable for street use, so I don't see that the incremental size increase makes a huge difference. Once you get into much larger torsion bars for only street use, the ride harshness tends to outweight the handling benefit IMO.
I will be replacing the rear rubber bushings in the coming year on my '74.
My thoughts on bushings: Every car I have ever owned, I have replaced the rubber suspension parts and the ride quality has always improved - no matter the prior condition. I just finished the front bushings on my car and I was surprized how bad the old bushings were. See photo below. I would think that with the fronts being this bad and the front is lighter, the rear will be just as bad - even though they look ok from the outside.
This is good thread for me to follow...I have an '84 that I recently acquired in the spring, and at some point I'm sure I'll need to go through the suspension. Can you give me a ball park of the $$ you have into the parts listed above?
I'm fairly handy so I'm quite confident I can do this myself...any specialty tools required? |
abides.
I replaced my '84s trailing arm bushings last year at ~300,000 miles. They still had some life left. The A-arm and spring plate bushings, however, were shot.
Graham 1984 Carrera Targa |
French Import
ELEPHANT RACING Suspension Packages for Porsche 911/912/930 Suspension1 I bought my components over time from both vendors, some directly and others through PP.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
For the front: you will need the pin wrench socket to install and torque the ball joint nut, plus a torque wrench that can measure 233 ft lbs. I also used this socket to remove the ball joint nut. I also highly recommend a tie rod separator. Both tools are sold by our host and come up for sale occasionally in the classifieds. If you buy the Elephant Racing A arm kit, Chuck includes some special tools to properly install them. A press makes it easy but a large pipe or bar clamp also works (I'll be going that route). For the rear: The spring plate bushings are bonded to the spring plates. You need to cut or burn them off. Chuck sells a spring plate bushing cutter, which I purchased for that job. To replace the rear wheel bearings, there's a special porsche tool but others have assembled similar bearing pullers using hardware store parts. I'm going to take the trailing arms to my p-car wrench and have him install the bearings and bushings. That's pretty much it I think except for a MAPP torch and a BFH. There are many threads on this site documenting suspension refreshes to guide you. |
The only special tools you need are to replace the rear wheel bearings, and a special socket for the ball joints. The A arm bushings from ERP come with their own tool. Don't bother buying the tool for the spring plate bushings, it was useless. I ended up using a torch and a razor to take them off. |
I am doing the front suspension currently. Went with rubber bushings from elephant, new torsion bars, bilstein shocks, sway bar bushings, ball joints, tie rods. The bill was just north of 1k.
the unexamined life is not worth living, unless you are reading posts by goofballs-Socrates 88 coupe |
Recreational Mechanic
Add to that list rear sway bar drop links. Getting the old ones out was not easy, I had to use an impact wrench and alot of penetrating oil on the lower nut/bolts on them to get them to break loose. The upper bolts (into the rear trailing arm) came out easily w/ a breaker bar and not too much effort.
Below is a photo of my rear drop links. The improvement in handling with new links was significant, much less "initial turn in" lean from the rear end. Granted one of them was damaged from impact, but even the 3 non-damaged connections were very loose and rubber was totally disintegrated.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing |
French Import
Mine were old and shot too , now very happy with the Tarett adjustables (can take out preload).
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
French Import
If you are going to upgrade to more robust ones, you may want to consider installing the reinforcement kit for the rear sway bar to body attachment points, which have been known to bend on the 911SC at least, not sure if they were made more robust by the factory on the later models (Carrera-on).
