Discseven's Avatar
Dme
For a 1985 911 Carerra 3.2, there is either no spark or no fuel reaching one cylinder. I'm wondering if it is possible for the DME to be doing this in either case? And is it possible to diagnose a DME to determine if the problem is the DME?
Old 10-25-2012, 03:00 PM
The DME fires all injectors together. The ignition events are identical for all 6 cylinders and the energy is routed by the distributor.
Rick
88 Cab
Old 10-25-2012, 03:03 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
No Spark.
Have a look at the disributor/rotor/wires, and all conections.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-25-2012, 03:18 PM
Jim Paps
mr 911's Avatar
always carry a spare I say...
Old 10-25-2012, 07:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check the OHMs on the ref/speed sensor
'85 Carrera Targa
PCA/POC
Old 10-25-2012, 08:21 PM
steely's Avatar
You might consider swapping the plug wire, maybe plug too. Ohm out the injector to make sure it isn't open, or check/swap it to make sure it isn't clogged.
And like Gerry suggests, checking the connections. Check the large bundle of injector returns (ground wires) which are tied to the same point on the intake. Look inside of the distributor. It wouldn't be your DME if the other 5 are working.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-25-2012, 09:47 PM
DRACO A5OG's Avatar
To answer your question, it can be diagnosed. With a strong magnifying glass check the solder joints for cracks and if cracked re-flow.
You do this at your own risk.
'85 Carrera Targa
PCA/POC
Old 10-25-2012, 10:11 PM
Discseven's Avatar
Thanks for all the good input! I'll post what I discover.
Old 10-26-2012, 12:04 AM
Doesn't sound like the dme RELAY as differentiated from the dme which would be the box under the left seat. I would continue the trouble shooting procedures as above.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 10-26-2012, 07:11 AM
