Dme
For a 1985 911 Carerra 3.2, there is either no spark or no fuel reaching one cylinder. I'm wondering if it is possible for the DME to be doing this in either case? And is it possible to diagnose a DME to determine if the problem is the DME?
The DME fires all injectors together. The ignition events are identical for all 6 cylinders and the energy is routed by the distributor.
Rick 88 Cab |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
No Spark.
Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Jim Paps
always carry a spare I say...
Member 911 Anonymous
Check the OHMs on the ref/speed sensor
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
You might consider swapping the plug wire, maybe plug too. Ohm out the injector to make sure it isn't open, or check/swap it to make sure it isn't clogged.
And like Gerry suggests, checking the connections. Check the large bundle of injector returns (ground wires) which are tied to the same point on the intake. Look inside of the distributor. It wouldn't be your DME if the other 5 are working.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
To answer your question, it can be diagnosed. With a strong magnifying glass check the solder joints for cracks and if cracked re-flow.
You do this at your own risk.
Thanks for all the good input! I'll post what I discover.
Doesn't sound like the dme RELAY as differentiated from the dme which would be the box under the left seat. I would continue the trouble shooting procedures as above.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
