Discseven's Avatar
Engine Drop
Am dropping 1985 Carrera engine to replace a number of parts for general maintenance. I’ll list these parts below.
If you have any suggestions as to what I should look at and what I should do while the engine is out, I’d welcome your input.
I was going to replace all the oil seals but have grown fond of adding 2-3 quarts monthly and changing the filter every other month. No leaks are over the manifolds. I drive under 1,000 miles per month. I'm planning to dump the sump and tank once a year. I've been checking the oil consistently, placing a few hot drops from the stick on a sheet of brilliant white, glossy paper. It's very clean. (Cannot say the same for garage floor.)
Replacing:
  • Front crank seal (was told that oil leaking here may interfere with the flywheel sensors)
  • Guide rails
  • (Check chains – possible replacement)
  • Trans oil - synthetic
  • (Check clutch pad – possible replacement)
  • CVs, boots & gaskets (not the shafts)
  • Fan housing (alternator mount has begun to crack – fan rubs housing on occasion on starts)
  • Fan (blistering crack is growing near inside edge of fan where fan meets center hub - photos below)
  • Fuel pump
  • Fuel pump relay
  • Fuel filter
  • Fuel pressure regulator
  • Ox sensor
  • Oil warn switch
  • Oil pressure sender
  • Spark plugs
  • Air filter
  • Oil
  • Oil filter
  • Belts (Fan & AC)
Notes:
Engine has turbo valve covers and collapsible return tubes.
Valve clearance was set a few months ago.
Flywheel sensor, cylinder head temp sensor, starter, distrib cap & rotor, ignition wires were recently replaced.
Blistering/cracking fan:
Old 10-31-2012, 09:23 AM
You have a pretty good list. I say replace the internal oil thermostat while you have the engine out too. Mine was stuck open.
Old 10-31-2012, 10:04 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Rear main seal, any external seals and gaskets that are hard/impossible to get to with the engine in..
Gary R.
Old 10-31-2012, 10:13 AM
kodioneill's Avatar
How many miles on the engine? If over 100,000 check for head stud (lower) breakage and possible valve guides and valve grind.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-31-2012, 10:14 AM
Discseven's Avatar
Thanks guys ~
Engine has 230,000 miles.
Old 10-31-2012, 10:27 AM
French Import
zippy_gg's Avatar
Post
I am going through a similar maintenance and would suggest the following:
  • Check/replace S hose out of oil tank
  • Check/replace heater hoses
  • Check/replace clutch cable
  • Check/replace starter
  • Check/replace fuel lines in engine bay
  • Check/replace engine and transmission mounts
  • Check/replace crankcase breather hose and replace gasket
  • Replace oil cooler thermostat o-ring
  • Replace Oil cooler seals (3)
  • Replace rocker arm seal
  • Check/replace distributor o-ring
  • Check/replace main shaft seal underneath crankshaft pulley (as already mentioned)?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 10-31-2012, 10:31 AM
GaryR's Avatar
2-3 qts for each 1000 miles, 230K on a 3.2, your valve guides are most likely toast. You should plan on a top end rebuild at the least.
Gary R.
Old 10-31-2012, 10:57 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Synthetic Gear Lube? Are you sure?
'85 Carrera Targa
PCA/POC
Old 10-31-2012, 11:01 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Vaccum lines
Replace the vacuum, and fuel lines:
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-31-2012, 11:31 AM
GaryR's Avatar
Positive, nothing is better in the 901.6
Gary R.
Old 10-31-2012, 11:33 AM
AutoBahned
RWebb's Avatar
my suggestion is to do a search on engine drop and you will find many ideas
a 1985 trans. will be a 915 - so do NOT put a synthetic gear oil in it; use Swepco
I dunno how the above opinion was arrived at but it conflicts with everything else
Old 10-31-2012, 12:27 PM
GaryR's Avatar
Relax RW, I was just playing off Draco's out-of-nowhere comment.. no such thing as a "901.6" as far as I know!
And I say use Kendall in a 915!
Gary R.
Old 10-31-2012, 12:29 PM
Discseven's Avatar
Synthetic Trans Oil
A mechanic (Richard Danvers) that used to work on the car put the synthetic in when I first got the engine at 62,000 miles. (It's in a 1980 Targa. At the time I had the option to rebuild my existing '80 engine or get the 85 Carerra -- I chose the latter.)
I wast told that once synthetic has been run in a trans, it's not good to put fossil oil in afterwards --- stay with synthetic.
Old 10-31-2012, 01:10 PM
midnight911's Avatar
^this is very exciting!!!
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 10-31-2012, 01:18 PM
GaryR's Avatar
902's will immediately eject all the dino oil onto the ground if they are used to synthetic!
Gary R.
Old 10-31-2012, 01:22 PM
DRACO A5OG's Avatar
Either way change the gear lube after 1000 miles to get most of the synthetic out.
'85 Carrera Targa
PCA/POC
Old 10-31-2012, 01:48 PM
